What if...
Old April 25th 07, 08:27 PM posted to rec.aviation.piloting
john smith[_2_]
Default What if...
"Jim Burns" wrote:
I was taught Chop(power), Prop(full), Drop(nose down), Gear (at gear speed),
Flaps (initial, then full when in white arc), 60 degree bank away from the
fire, holding airspeed at the top of the white arc. It would get you down
fast, add rudder and we'd see over 2500 fpm down. After about 2 turns of
that demonstration, my DE said... Ok, good enough.
Commercial students that I taught this method to needed to be eased into it,
but after one or two attempts, most found it fun.
Thanks Jim.
That gets me to wondering... what about a spin?
A spin will give you a high rate of descent at stall speed.
If the aircraft is not approved for spins, that might lead to an
indecisive moment. Just because it is not approved, does not mean it
will not recover. It just means that it might not have been tested.
Old April 25th 07, 09:02 PM posted to rec.aviation.piloting
Jim Burns[_2_]
Default What if...
Theoretically a spin may get you down faster, but in how many pieces? I'd
hesitate to recommend a spin. The distraction of the fire, smoke, heat,
fear could very easily cause you to forget about the ground rushing up at
you. Properly executed and practiced to proficiency a spin is, of course,
controllable and predictable, but I wouldn't try one blind folded with one
arm tied behind my back.
"john smith" wrote in message
speed),
down
of
it,
Thanks Jim.
Old April 25th 07, 09:45 PM posted to rec.aviation.piloting
flynrider via AviationKB.com
Default What if...
A descent rate in a spin is not that great. You can get down much faster
in a steep spiral dive.
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200704/1
Old April 26th 07, 04:54 AM posted to rec.aviation.piloting
Mortimer Schnerd, RN[_2_]
Default What if...
Particularly after the wings separate. As an aside, back in the old days before
IFR, the poor slobs flying the mail would spin down through an overcast
intentionally, assuming they'd break out high enough to recover before they went
splat. Some won, some lost.
It seems to me that the thing to do with trying to get down rapidly is drop the
gear and the flaps, no power and the prop set full forward for maximum drag (or
at least to max rpm but not over redline), then dump the nose at the maximum
gear extended speed or top of the white, whichever is the lower of the speeds.
mschnerdatcarolina.rr.com
Old April 26th 07, 12:38 PM posted to rec.aviation.piloting
Peter Clark
Default What if...
On Wed, 25 Apr 2007 23:54:18 -0400, "Mortimer Schnerd, RN"
Flaps down? Emergency descent procedure in a Malibu is to chop the
throttle, prop full forward, pop the speed breaks (if equipped), drop
the gear below 165, then go down at max gear extend (up to 195
depending on how rough it is). Top of the white arc is 116. Wouldn't
you get a significantly greater descent rate at near Vne than top of
the white arc?
Old April 26th 07, 01:15 PM posted to rec.aviation.piloting
john smith
Default What if...
The spin is not the problem. The spin is a low speed maneuver as the
inside wing is stalled while the outside wing is flying.
The steep spiral dive at high speed can lead to airframe damage.
This was a topic in the acro community a couple of years ago.
Many pilots believed that the airframe g-loading ratings applied to all
attitudes of flight. It was the T-34 the accident that that had the
Baron wing replacement that set off the discussion.
From that we learned that the g-loadings only applied to wings level
flight.
High angle of bank and high airspeed will result in wing failure below
the manufacturers publish g-loading limit.
Old April 26th 07, 03:11 PM posted to rec.aviation.piloting
Dylan Smith
Default What if...
flight.
Almost but not quite - it wasn't bank angle but roll rate. You can't
pull as many Gs while rolling at the same time.
Yes, the Reply-To email address is valid.
Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de
Old April 26th 07, 09:06 PM posted to rec.aviation.piloting
john smith[_2_]
Default What if...
flight.
I stand corrected. Thank you Dylan.
That is what I meant.
Old April 26th 07, 08:36 PM posted to rec.aviation.piloting
Default What if...
flight.
I was suggesting a steep spiral dive within reasonable flight parameters.
I practice these occasionally and I haven't bent the plane yet. In a
stabilize spiral, the G-loading on the wings should be the same as Gs applied
in level flight.
The reason I prefer the manuever is that it gets you down faster than a
lower airspeed descent (i.e. flaps out). Plus, there is the possibility the
that the higher airspeed could over-oxygenate the fire and put it out.
Old April 26th 07, 12:19 AM posted to rec.aviation.piloting
john smith[_2_]
Default What if...
Thank you, gentlemen!
This is the kind of information I was looking for.
