President of our local EAA chapter killed in inaugural flight
Old April 27th 07, 12:38 PM posted to rec.aviation.piloting
B A R R Y[_2_]
Default President of our local EAA chapter killed in inaugural flight
Peter R. wrote:
The source stated that the engine of the
airplane was not running right as the aircraft taxied by the small crowd that
was invited to watch the flight. There was no at-length run-up performed
before takeoff.
Stuff like that, if true, simply blows my mind.
Yet we hear and read it again and again...
Old April 27th 07, 03:57 PM posted to rec.aviation.piloting
Morgans[_2_]
"B A R R Y" wrote in message
that
before takeoff.
Yep. I hope that a record of this whole incident is kept as a record of
what not to do for an airplane's first flight.
Let's see; what can we list, so far.
*Taking a second, unnecessary person along during the testing period.
*Not performing a nose high (climb attitude) extended full power engine test
run.
*Adding to the pressure of taking off on a certain time and place, because
of an invited, interested, significant
person crowd being present for first flight.
*Allowing contaminants to be present in the fuel system.
*Not doing a runup before first flight.
*Taking off with a rough running engine.
*Attempting to do the deadly "return to the runway turn" at too low of an
altitude.
Old April 27th 07, 05:11 PM posted to rec.aviation.piloting
Peter R.
I failed to mention previously that there were at least two if not more video
clips of the entire ill-fated flight so I am hopeful the NTSB will be able to
come to a confident conclusion as to the cause of this accident.
Peter
Old April 27th 07, 05:57 PM posted to rec.aviation.piloting
On Apr 27, 8:57 am, "Morgans" wrote:
"B A R R Y" wrote in gy.net...
that
before takeoff.
run.
altitude.
Man, even back when I was flying RC planes a lot, I always did a full
power extended engine test before flying a new model, and would tilt
the nose of the plane up, and down through the vertical to make sure
that it wouldn't cut out. That was all just to keep from wrecking a
plane that I had put lots of hours into. Now if my ass was going in
the plane that I had just built, I would want to be at least as
thorough in confirming that the engine was running reliably, and I
would wring out the flight controls and double inspect all structural
elements, and invite as many experienced builders to do the same as I
could find willing to help me...
I just can't understand why anyone would do anything less.
Old April 27th 07, 06:30 PM posted to rec.aviation.piloting
Al G[_2_]
gy.net...
crowd
that
performed
before takeoff.
test
run.
because
altitude.
Also, the EAA has a very successful Flight Advisor Program. Where were
they? Would the Pilot not accept the advice? As you have all said, too
many
things wrong.
Al G
EAA Flight Advisor
Local community college wants to cut flight instructor pay. Jim Logajan Piloting 39 April 24th 07 10:32 PM
Local reporter takes an intro flight Tony Cox Piloting 28 February 25th 07 05:14 AM
Aussie AOPA president reported killed in kit plane crash Skylune Piloting 14 April 12th 06 03:00 PM
Angel Flight gets some good local press Dave S Piloting 21 April 11th 05 06:36 PM
Local flight >227 hours duration Casey Wilson Piloting 4 February 22nd 05 10:49 PM
