![]() "Kobra" wrote: While flying to FL from NJ last week I did what I always do and fly ROP by 75 to 100 degrees. This is how I was trained and my CFII is also my A&P / IA. I know enough about LOP to know I will not operate LOP without an engine analyzer and probably GAMI injectors which I do not yet possess. You are wise to err on the side of caution, but it is possible to run LOP without fear of damaging the engine if you limit power. At 65% or below, it can be done safely without an analyzer. During the trip I was looking at my fuel computer and seeing an average FF of 10.5 to 11.5 GPH at 6 to 7 thousand feet at about 22 to 23 inches MP and 2400 RPM at 75 degrees ROP. What model engine? I often run LOP at those settings with a Lyc. O-360 F1A6. I pulled my POH out and looked up the cruise performance numbers for those parameters and those altitudes and I saw the recommended FF's. If I leaned to the recommended FF's I was usually at peak EGT. So my question is: Does Cessna advocate running at peak EGT in cruise? Or if "advocate" is a strong word, are they at least saying "you can if you want to" run at peak EGT in cruise? I've always heard that running at peak EGT is bad for the top end of the engine. Depends on the % power you're making. -- Dan C172RG at BFM |
F1A6. I have an IO360 A1B6. I am embarrassed to say that I did not know, nor was I ever taught, that below 65% power you could lean to peak without hurting the engine. I have been wasting gas and money now since June of 2002. I am really ashamed that I did not open my eyes. I just dismissed talk of LOP and running at peak as bad advice without an engine analyzer. This is because my instructor/A&P always said to run the engine 100 degrees ROP and never to run LOP "because gas is cheaper than cylinders". I took his word as gospel and have flown 75 to 100 degrees ROP ever since I bought my plane. Even my type club said to me recently, "about 65% power and lean until your hearts content..." Thanks for all your help. Kobra |
First off gas is not cheaper than cylinders so that's a dumb argument
from the get go. At 65% you want to be leaner than peak EGT or richer than 100 ROP for best engine health. At 75% you want to be leaner than 40 LOP or richer than 180 ROP. There are other power settings with their own combos but these are the two most used. At your stated 65% get yourself about 15-20 LOP. That's good for the engine and the loss of airspeed is negligible. You can go leaner but you'll start to notice a speed loss. Kobra wrote: What model engine? I often run LOP at those settings with a Lyc. O-360 F1A6. I have an IO360 A1B6. I am embarrassed to say that I did not know, nor was I ever taught, that below 65% power you could lean to peak without hurting the engine. I have been wasting gas and money now since June of 2002. I am really ashamed that I did not open my eyes. I just dismissed talk of LOP and running at peak as bad advice without an engine analyzer. This is because my instructor/A&P always said to run the engine 100 degrees ROP and never to run LOP "because gas is cheaper than cylinders". I took his word as gospel and have flown 75 to 100 degrees ROP ever since I bought my plane. Even my type club said to me recently, "about 65% power and lean until your hearts content..." Thanks for all your help. Kobra |
On Apr 30, 4:17 pm, Newps wrote:
First off gas is not cheaper than cylinders so that's a dumb argument from the get go. At 65% you want to be leaner than peak EGT or richer than 100 ROP for best engine health. At 75% you want to be leaner than 40 LOP or richer than 180 ROP. There are other power settings with their own combos but these are the two most used. At your stated 65% get yourself about 15-20 LOP. That's good for the engine and the loss of airspeed is negligible. You can go leaner but you'll start to notice a speed loss. Kobra wrote: What model engine? I often run LOP at those settings with a Lyc. O-360 F1A6. I have an IO360 A1B6. I am embarrassed to say that I did not know, nor was I ever taught, that below 65% power you could lean to peak without hurting the engine. I have been wasting gas and money now since June of 2002. I am really ashamed that I did not open my eyes. I just dismissed talk of LOP and running at peak as bad advice without an engine analyzer. This is because my instructor/A&P always said to run the engine 100 degrees ROP and never to run LOP "because gas is cheaper than cylinders". I took his word as gospel and have flown 75 to 100 degrees ROP ever since I bought my plane. Even my type club said to me recently, "about 65% power and lean until your hearts content..." Thanks for all your help. Kobra- Hide quoted text - - Show quoted text - Do these 65% v. 75% ROP & LOP temp limits have any relation to compression ratio of the engine? In another words, if my engine is 7:1 CR & running at 75% power, can I run at temp limits for an engine that is 8.5:1 CR running at 65%? |
" wrote in message
ups.com... On Apr 30, 4:17 pm, Newps wrote: First off gas is not cheaper than cylinders so that's a dumb argument from the get go. At 65% you want to be leaner than peak EGT or richer than 100 ROP for best engine health. At 75% you want to be leaner than 40 LOP or richer than 180 ROP. There are other power settings with their own combos but these are the two most used. At your stated 65% get yourself about 15-20 LOP. That's good for the engine and the loss of airspeed is negligible. You can go leaner but you'll start to notice a speed loss. Do these 65% v. 75% ROP & LOP temp limits have any relation to compression ratio of the engine? No, not really. In another words, if my engine is 7:1 CR & running at 75% power, can I run at temp limits for an engine that is 8.5:1 CR running at 65%? Run at the temp limits defined (EGT/CHT) in your POH, where ever that fall on the LOP graph. http://www.avweb.com/news/pelican/182084-1.html (Plus the entire engine series defined in the sidebar on the right). -- Matt Barrow Performace Homes, LLC. Colorado Springs, CO |
fuel flow on the cheap | pittss1c | Home Built | 3 | May 7th 06 10:12 PM |
Fuel Flow instrument | Billc851 | Home Built | 18 | March 19th 05 12:49 PM |
V8 fuel flow | Robert Bates | Home Built | 34 | January 24th 05 03:41 AM |
fuel flow measurement | khanindra jyoti deka | Home Built | 0 | January 5th 05 04:34 AM |
Fuel Flow Monitoring | EDR | Owning | 4 | October 18th 03 03:10 AM |
