Fuel Flow and Peak EGT
Old April 30th 07, 09:58 PM posted to rec.aviation.owning
JGalban via AviationKB.com
Default Fuel Flow and Peak EGT
Mike Noel wrote:
That brings up an interesting point. I think the Lycoming recommendation
previously was 75% power for unrestricted leaning. Lately I have seen 65%
as a recommendation. Anyone have any background on the two different
limits?
Lycoming has always given recommended limitations on operations. 75% in
cruise was always the common limit for leaning. Other documents have given
lower numbers with the phrase "for maximum service life". Here's an example
from a Lycoming Key Reprint article on leaning :
8. For maximum service life, maintain the following recommended
limits for continuous cruise operation:
a. Engine power setting — 65% of rated or less.
b. Cylinder head temperatures — 400˚ F. or below.
c. Oil temperature — 165˚ F. — 220˚ F.
Available at
http://www.lycoming.com/support/tips...Operations.pdf
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200704/1
fuel flow on the cheap pittss1c Home Built 3 May 7th 06 10:12 PM
Fuel Flow instrument Billc851 Home Built 18 March 19th 05 12:49 PM
V8 fuel flow Robert Bates Home Built 34 January 24th 05 03:41 AM
fuel flow measurement khanindra jyoti deka Home Built 0 January 5th 05 04:34 AM
Fuel Flow Monitoring EDR Owning 4 October 18th 03 03:10 AM
