Are Planes taking off in Thunderstorms normal?
Old May 6th 07, 10:56 PM posted to rec.aviation.piloting,rec.travel.air
C J Campbell[_1_]
Default Are Planes taking off in Thunderstorms normal?
On 2007-05-05 13:48:33 -0700, said:
http://www.thenewstribune.com/886/story/55281.html
I would not depart in a thunderstorm no matter what I was flying. Hail
can travel up to 20 miles from a thunderstorm. Thunderstorms are often
surrounded by violent downdrafts called microbursts that will force any
airplane down faster than it can climb. The lightning can blind pilots.
The inside of a thunderstorm is darker than night, and the air currents
throw you around like bucking bull.
I have been inside thunderstorms more than once and each time it has
nearly killed me. I stay as far away from them as I can.
Departing in a thunderstorm is especially dangerous. You are too close
to the ground and the thunderstorm can slam you right down into it. You
can't see obstacles in the darkness and you can't maneuver well enough
to avoid them easily. Hailstones will dent up the airplane, get sucked
into the engines and kill them, and break things. Lightning can strike
the airplane and even burn holes in the skin. If you get caught in the
microburst you will hit the ground before you can fly out of it.
Crewmembers can be thrown out of their chairs with such violence that
it breaks bones and knocks them unconscious. Passengers who don't have
their seatbelts fastened tightly can be badly hurt. Anything loose in
the cabin becomes a deadly missile.
I have never been slammed into the ground, but I have come very close.
I have experienced all the other bad effects I have described. A
thunderstorm frequently has all the energy of several atomic bombs. No
airplane can withstand that. It is possible to fly into a thunderstorm
and live -- I seem to attract them -- but they are still very dangerous.
All of that said, it remains to be seen whether the aircraft you are
referring to actually flew into a thunderstorm. A thunderstorm can be
many miles away but it will seem right on top of you because they are
so big. Rain is not a thunderstorm. Hail is caused by thunderstorms
but, as I have noted, the thunderstorm might be 20 miles away.
Waddling Eagle
World Famous Flight Instructor
Old May 7th 07, 07:30 PM posted to rec.aviation.piloting,rec.travel.air
William Black[_1_]
news:2007050614564343658-christophercampbell@hotmailcom...
How many flights have you refused to board because of the weather?
William Black
I've seen things you people wouldn't believe.
Barbeques on fire by the chalets past the castle headland
I watched the gift shops glitter in the darkness off the Newborough gate
All these moments will be lost in time, like icecream on the beach
Time for tea.
Old May 7th 07, 09:09 PM posted to rec.aviation.piloting,rec.travel.air
Mortimer Schnerd, RN[_2_]
I once dumped an Apache in Fayetteville, NC because of collecting a pile of ice
on the approach in. I called my boss, told him his Apache could be found in
Fayetteville, and that I would be boarding a USAir flight shortly back to
Charlotte. It's one thing to pick up ice on the approach; I was headed downhill
anyway. It's a very different situation trying to climb through a freezing
overcast and I wasn't going to do it.
But I did climb on the USAir jet without hesitation. I figured it had
deicing/anti-icing. It must have had something, because we made the flight home
without any trouble.
As an aside, I have launched many times immediately after a cell moved off the
field, as long as it didn't move in the direction I intended to go. But I have
never launched with one overhead. I don't know anybody who would.
mschnerdatcarolina.rr.com
New GNS 530 getting very hot - Is this normal ? Roy N5804F Owning 3 September 2nd 06 04:39 AM
Air France Flt 358 vs. thunderstorms [email protected] Piloting 11 August 4th 05 03:34 AM
Lycoming O-540, "normal" CHT/EGT??? USA Owning 3 August 1st 05 08:00 AM
Is ear-popping normal Piloting 9 April 24th 04 11:25 PM
Normal EGT - Very Low CHT markjen Owning 7 March 4th 04 01:54 PM
