PSA: Don't be rude on the radio
Old May 10th 07, 06:56 PM posted to rec.aviation.piloting
RST Engineering
Default PSA: Don't be rude on the radio
"Cessna Seventy-three Charlie Quebec is departing runway 25 at Grass Valley
on a 2300 mile final for runway 9 Oshkosh."
"Allen" wrote in message
Which does nothing to define what "final approach" is. If you are aligned
with the runway and intending to land does final begin 5 miles from the
threshold? 10 miles? 15 miles? 50 miles?
Old May 10th 07, 07:21 PM posted to rec.aviation.piloting
On May 10, 1:46 pm, John Godwin wrote:
wrote roups.com:
Landing. Aircraft while on final approach to land or while
landing, have the right-of-way over other aircraft in flight or
operating on the surface, except that they shall not take
advantage of this rule to force and aircraft off the runway
surface which has already landed...
... and I believe that the AIM defines "Final Approach" as:
A flight path in the direction of landing along the extended
runway centerline from the base leg to the runway.
"FINAL APPROACH -- ICAO. That part of an instrument approach
procedure which commences at the specified final approach fix or
point, or where such fix or point is not specified:
a. At the end of the last procedure turn, base turn or inbound
turn or a racetrack procedure, if specified
b. At the point of interception of the last track specified in the
approach procedure; and ends at a point in the vicinity of an
aerodrome from which:
1. A landing can be made; or
2. A missed approach procedure is initiated.
FINAL APPROACH -- IFR. The flight path of an aircraft which is
inbound to an airport on a final instrument approach course, beginning
at the final approach fix or point and extending to the airport or the
point where a circle-to-land maneuver or missed approach is executed."
From that definition, "final approach" would be from the marker
inbound on an ILS, or wherever the arriving traffic happens to get
lined up with the final approach course. I'm sure you're aware that
traffic arriving IFR is often vectored onto 5-10 mile final, so that
"base leg" may have been flown, just 10 miles from where you're used
to turning base-final. Faster, high performance aircraft often take
time to slow down and transition from the terminal phase to approach
and landing.
Old May 10th 07, 08:20 PM posted to rec.aviation.piloting
Allen[_1_]
wrote
roups.com:
and landing.
So you are saying that 10 miles is where final approach begins? The AIM
says you should complete your turn to final at least 1/4 mile from the
runway; it does not specify a maximum distance. It also defines "final" as
the term commonly used to mean that an aircraft is on the final approach
course or is aligned with a landing area.
Old May 10th 07, 08:29 PM posted to rec.aviation.piloting
Montblack
("Steven P. McNicoll" swrote)
If you're able to run from a shark you're on land and there's no need to
run at all.
Let alone searching for a shark's ass, to kick.
Mont-black-in-the-water-everyone
Old May 10th 07, 08:39 PM posted to rec.aviation.piloting
Dudley Henriques[_2_]
"Montblack" wrote in message
run at all.
They must have one. Otherwise they'd just eat all day and night and keep
getting bigger and bigger wouldn't they? :-))
Dudley Henriques
Old May 10th 07, 08:46 PM posted to rec.aviation.piloting
wrote
roups.com:
and landing.
I'm saying the official definition of "final approach" is vague with
regards to distance from the end of the runway. Realisticly, I would
argue that "final approach" would begin at the point you can see the
runway. Outside of that, I'd call distance and intention; ie- "Twin
Cessna 3AB, 15 to the west, straight in runway 9.... Twin Cessna 3AB,
10 mile final, runway 9" etc.
Old May 10th 07, 09:20 PM posted to rec.aviation.piloting
Jim Logajan
keep getting bigger and bigger wouldn't they? :-))
Really, no ****?
  #28
Old May 10th 07, 09:46 PM posted to rec.aviation.piloting
"Jim Logajan" wrote in message
Really, no ****?
OUCH!!!
What's REALLY troublesome to me about this is that I have to reason to
myself how 50 odd (and odd is indeed appropriate here :-) years in
professional aviation has finally come down for me to this thread.
Dudley Henriques
  #29
Old May 10th 07, 09:56 PM posted to rec.aviation.piloting
Allen[_1_]
wrote
roups.com:
and landing.
as
No, I am with you on this! I just think there should be some (even if it is
arbitrary number pulled from a hat) distance to define when you are on
"final". What if you are approaching an airport from the wrong side and
make a right-hand turn to align with a runway with a left-hand traffic
pattern. There should be some distance from the airport you could do this
and then make a "straight-in" approach without violating any regs or the
AIM.
  #30
Old May 10th 07, 10:43 PM posted to rec.aviation.piloting
Matt Barrow[_4_]
Default Don't be rude on the radio
"buttman" wrote in message
On May 10, 10:20 am, "Peter Dohm" wrote:
Lemme get this straight! You are in instructor, which means you are
instrument rated, which means that you should know that outer markers are
typically at least five miles from the landing zone--so, if you can not
recall for a specific airport, you can still guess five miles. In
addition,
you did not bother to maintain familiarity with the procedures at an
airport
where you typically instruct, you failed to understant that the Cirrus
had
travelled a substantial (probably between a third and a half) of the
distance to the runway, and then you turned in front of known traffic
which
you did not see.
First off, I never said I did nothing wrong. I know I made a mistake
by turning in front of him. We all make mistakes, whether you're an
instructor or not. THE WHOLE POINT of the post was that the Cirrus guy
had to act like a pumpus ass.
Sounds like a typical childish response (ie, making excuses).
The only pompous ass here is yourself.
Matt Barrow
Performace Homes, LLC.
Colorado Springs, CO
Old Radio Clint Soaring 0 January 17th 06 11:01 AM
Talk About A Rude Company, NW_PILOT Owning 48 December 25th 04 10:51 PM
Talk About A Rude Company, NW_PILOT Piloting 44 December 24th 04 03:30 AM
Have you been to an airport where the people in the tower are consitently rude? LowApproach_SoCal Piloting 15 August 23rd 04 04:19 AM
FA OLD AIRCRAFT RADIO TRANSMITTER STANDARD RADIO Ron Restoration 0 October 26th 03 12:02 AM
