Depreciating aircraft parts, dealing with taxes, etc.
Old May 10th 07, 10:29 PM posted to rec.aviation.owning
Andrew Gideon
Default Depreciating aircraft parts, dealing with taxes, etc.
Most owners, I assume, have corporations which do the actual owning and
which provide a liability firewall. But how are taxes managed?
The issue I think I'm facing is we pay money into the corporation against
future events like overhaul, repainting, etc. These monies add up. But
since this is really just a reserve that's going to be spent in a few
years, I'm loath to have this considered "profit" and thereby become
taxable.
The answer, I'd imagine, is to depreciate those things against which the
reserves are accumulating. For example, if I pay $25/hour into the bucket
for engine reserve, I want to depreciate the engine by $25/hour.
Can one do that? What [very!] little I know about taxes has
calender-based depreciation schedules. Can one have a use-based schedule?
Thanks, and any suggestions, corrections, pointers, or ideas would be
welcome.
- Andrew
Old May 11th 07, 12:14 AM posted to rec.aviation.owning
Matt Barrow[_4_]
"Andrew Gideon" wrote in message
news
taxable.
IIUC, it should be set up as a reserve/expense account, not as income to the
corporation. The only income to the corporation should be the management
fees (??)
It sounds like you're trying to depreciate components, rather than the
entire aircraft, on an hourly basis. I don't think that's a good idea. That
takes much more work for your accountant. I can imagine doing a
calendar-based depreciation, but not if the calendar is harder on your
aircraft's value than useage is.
welcome.
Are you a "partner" to the corporation, or is it third party, such as a
partnership or lease back?
(My explanation here is probably NOT technically correct)
My company (LLC) is the registered owner of my aircraft. We deduct expenses
as incurred and take depreciation and make an entry in "Reserves" on an
hourly basis for such things as recurring maintenance and overhaul.
The LLC then "charges"me for any personal use I make of the aircraft. I then
declare that as personal income, just as when I draw from our cash accounts
for "personal income - cash".
You can get into "trouble" if you try to expense your personal usage, so
make DAMN sure you are really doing business and have documentation to back
it up. This is probably (though not sure) more critical when you have
corporate ownership.
Matt Barrow
Performace Homes, LLC.
Colorado Springs, CO
Old May 11th 07, 12:18 AM posted to rec.aviation.owning
Robert M. Gary
taxable.
welcome.
- Andrew
What taxable income are you trying to defer with depreciation???
-Robert
Old May 11th 07, 12:30 AM posted to rec.aviation.owning
Newps
Most owners do not as this provides no protection at all.
Old May 11th 07, 12:35 AM posted to rec.aviation.owning
Matt Barrow[_4_]
"Newps" wrote in message
Depends on "who" the corporation consists of, and for what purpose.
Old May 11th 07, 01:33 AM posted to rec.aviation.owning
Newps
A corporation with the aircraft as the only asset and only one officer,
the owner of the plane.
Old May 11th 07, 01:40 AM posted to rec.aviation.owning
Matt Barrow[_4_]
A corporation with the aircraft as the only asset and only one officer, the
owner of the plane.
That's one scenario. Certainly not the only one.
It sounds to me like Andrew's situation is one of an "Aircraft Management"
corporation.
That may or may not provide liability protection. In the case of an owned
corporation owning the aircraft, it doesn't protect the corporation, but it
does protect the pilot and his personal assets. If the prupose of corporate
ownership is merely to avoid liability, that probably won't work.
Old May 11th 07, 02:50 AM posted to rec.aviation.owning
Andrew Gideon
In my particular case, I'm speaking of a corporation owned by 45 members
which owns four aircraft. But I'm guessing that the difference between
this and other organizations is more of scale than anything else.
Does single owner/single aircraft reduce the protection of the corporate
veil? Is that very different from two owners, or twenty?
- Andrew
Old May 11th 07, 02:59 AM posted to rec.aviation.owning
Andrew Gideon
the corporation. The only income to the corporation should be the
management fees (??)
I guess I'm confused about how payments into the company, to be used in
some future year, are tracked as an expense.
That's what I was thinking.
That takes much more work for your accountant.
That's a good point.
I'm one of the "shareholders", except that it's a corporation that doesn't
issue shares.
(My explanation here is probably NOT technically correct) My company
(LLC) is the registered owner of my aircraft. We deduct expenses as
So you depreciate the value of the entire aircraft by the reserve amount
each hour? And then, at engine overhaul time, you increase the value of
the airplane by the value of the engine?
then declare that as personal income, just as when I draw from our cash
accounts for "personal income - cash".
I don't follow this paragraph at all, I'm afraid. If you're paying into
the LLC, how is that personal income?
- Andrew
Old May 11th 07, 03:00 AM posted to rec.aviation.owning
Andrew Gideon
I'm not sure that it's taxable income (which is part of my problem), but
I'm envisioning this asset called a "reserve account" growing over the
years until an overhaul is required.
- Andrew
Discussion on dealing with future ADIZ Incursions by light A/C Hank Rausch Piloting 47 May 14th 05 02:33 PM
Book Review: "Dirty Dealing: Drug Smuggling on the Mexican Border",et al; Cartwright Paul Piloting 0 January 5th 05 06:36 PM
FS: Aircraft Instruments Parts Avionics Warbird Parts Bill Berle Home Built 0 January 10th 04 02:20 AM
FS: Aircraft Instruments Parts Avionics Warbird Parts Bill Berle Aviation Marketplace 0 January 10th 04 02:20 AM
How to avoid Aircraft Ad Velorem taxes........... ArtP Owning 6 August 27th 03 08:37 PM
