preparing for commercial oral and practical
Old May 14th 07, 10:03 PM posted to rec.aviation.student,rec.aviation.piloting
Mortimer Schnerd, RN[_2_]
Default preparing for commercial oral and practical
Mark T. Dame wrote:
The intricacy's of weight and balance similar to the knowledge test
questions. Load, fly, unload, fly, refuel, load, fly unload, refuel....
what's your weight, where's your CG, what about if you have to hold, when
will you reach bingo fuel and where will your CG be then? Talk to a Bonanza
owner about CG changes with fuel burn.
Additionally, your CG probably changes when you retract your gear.
That's one of my commercial DE's pet points.
While being technically correct (if he says so), what difference does it make?
Are you going to fly with the gear down to keep the CG in the same place that
you used to figure your W&B?
Cocktail party facts....
mschnerdatcarolina.rr.com
Old May 14th 07, 10:17 PM posted to rec.aviation.student,rec.aviation.piloting
Jose
Half an inch in an Arrow.
Jose
Quantum Mechanics is like this: God =does= play dice with the universe,
except there's no God, and there's no dice. And maybe there's no universe.
Old May 14th 07, 10:33 PM posted to rec.aviation.student,rec.aviation.piloting
Mark Hansen
I'm sure it was more a matter of making sure the pilot understood how the
gear affected the CG - and not that it would change the flight characteristics
all that much.
Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot
Cal Aggie Flying Farmers
Sacramento, CA
Old May 14th 07, 11:08 PM posted to rec.aviation.student,rec.aviation.piloting
Matt Whiting
You calculate balance for both gear down and gear up for both takeoff
and landing loading. All four must be within the envelope or you don't go.
Matt
Old May 15th 07, 02:43 AM posted to rec.aviation.student,rec.aviation.piloting
make? Are you going to fly with the gear down to keep the CG in the same
place that you used to figure your W&B?
Really? In the C-210 if I couldn't get the doors closed we wouldn't go, but I
don't recall any other occasions. G
Seriously, I've never been required to do more than one W&B for any flight I've
ever made, and I don't recall that the gear position was ever even considered.
I've never failed a written test or check ride either, including regular part
135 rides.
Old May 15th 07, 12:01 PM posted to rec.aviation.student,rec.aviation.piloting
Matt Whiting
Really.
135 rides.
Some instructors and examiners are more thorough than others. Not all
will test for everything, but checking to see that the W&B aren't
exceeded during all phases of flight is a pretty basic check.
Matt
Old May 15th 07, 01:11 PM posted to rec.aviation.student,rec.aviation.piloting
Mark T. Dame
Not at all. We're talking about a commercial pilot checkride. As such,
you need to know more than for a private certificate. The point of the
exercise is to show the examiner that you understand these concepts and
actually do it.
Additionally, you do have the gear in both positions in flight. You
have it down at take off. You need to make sure that putting it up
isn't going to put your CG outside of the envelope right after take off
when you are still low, slow, and nose high. This could lead to a
departure stall. When you are landing, you put your gear down well
before you touch down, and you will be low and slow on final. The
difference between gear up and down may be a factor.
Now, as Jose pointed out, on the Arrow it's not very significant, but
that doesn't mean that it's that way for all planes.
Finally, as I said, we're talking about a checkride. Checkrides often
have you do things that you may not do in your day to day flying, but
you need to know and understand in case you need it. In any case, I'm
just giving advice on what to expect on the checkride.
-m
## Mark T. Dame
## CP-ASEL, AGI
## insert tail number here
## KHAO, KISZ
"Love is a snowmobile racing across the tundra and then
suddenly it flips over, pinning you underneath. At night,
the ice weasels come."
-- Matt Groening
  #28
Old May 15th 07, 02:02 PM posted to rec.aviation.student,rec.aviation.piloting
Mark T. Dame
135 rides.
For both my private and commercial rides I was required to do a W&B for
takeoff and landing fuel loads. Additionally, for my commercial ride, I
had to account for the gear position, as Matt said, giving you four
different configurations.
This was another point of emphasis for my DE. Different examiners have
different favorite topics. For the purpose of the original question, my
suggestion stands.
I'm not questioning your experience, just relaying mine.
-m
## Mark T. Dame
## CP-ASEL, AGI
## KHAO, KISZ
"Small software companies are always cool."
-- Bill Gates
  #29
Old May 15th 07, 03:09 PM posted to rec.aviation.student,rec.aviation.piloting
Jose
Actually I wasn't implying (half an inch) that it wasn't very
significant - when the CG range is only a handful of inches, it's
significant. And certainly when you're near the edge it bears watching.
Jose
  #30
Old May 15th 07, 03:42 PM posted to rec.aviation.student,rec.aviation.piloting
Mark T. Dame
At the risk of arguing semantics, I wasn't saying "insignificant" only
"not very significant". I don't have my Arrow book here, but I believe
the CG range is around 10 to 12 inches. If you load well within the
envelope, the half inch is not going to have an appreciable affect on
aircraft performance.
But I'm getting off topic: what should someone expect on their
commercial checkride.
Make sure to do a W&B for gear up and gear down with takeoff fuel and
landing fuel. If the examiner doesn't care, then no big deal, but if
the examiner wants to see it and you didn't do it, then you have a
strike against you. On checkrides, you'll get plenty of strikes without
creating ones that could be easily avoided by a little bit of prep work.
Even if the examiner doesn't want or expect it, it can't hurt to have it
(unless you do it wrong).
-m
## Mark T. Dame
## CP-ASEL, AGI
## KHAO, KISZ
"The way to make a small fortune in the commodities market is to
start with a large fortune."
-- Unknown
Oral exam place and questions Mxsmanic Piloting 34 April 18th 07 06:12 PM
Commercial rating: complex aircraft required aircraft for practical test? Marc J. Zeitlin Piloting 22 November 24th 05 04:11 AM
Oral Exam Prep -- recommendations and recollections Nicholas Kliewer Instrument Flight Rules 0 November 15th 04 05:00 PM
Private Pilot Oral Pete Piloting 9 December 2nd 03 05:41 PM
CPL/IR/MULTI ORAL Ian Leslie Piloting 2 July 11th 03 09:32 PM
