CTB - LWS : Plane for the mission? Pilot for the plane?
Old May 15th 07, 10:52 PM posted to rec.aviation.owning
scronje
Default CTB - LWS : Plane for the mission? Pilot for the plane?
Hi Folks
I am a relatively low hour PP-ASEL(about 90 PIC, half in C-177 / 152, the
rest in Challenger AUL and gliders, total time, including dual = 160
hours). I have not been flying for several years, but am in the process of
regaining my certification.
As the only way for me to be able to fly from where I am located means
ownership, I am in the process of making a shortlist of airplanes I would
like to consider.
Part of the mission would be fairly regular flights from CTB - LWS and
back. (2-3 souls and luggage). What straight-legged 4 seaters would be up
to the task? (The actual route would be CYBU - CYXH - CTB - LWS )
Crossing those rocks would seem to exclude a C-172 and its friends. It
would seem that something of the order of a C-182 or Piper Cherokee 235
would fit the bill. Does anyone here have experience of flying this kind
of trip in, say a C-177, or PA Cherokee 180?
Would I have trouble finding insurance if I went straight to a C-182 or
PA-235? From what I have read, that should not be a big stretch for me,
and would make crossing the ridge a lot easier.\
All VFR for now, although I intend to pursue a IFR rating later.
Thank you for any and all replies.
Steve
Old May 16th 07, 01:49 AM posted to rec.aviation.owning
Dave[_5_]
You can't go wrong with a 182 - but it is a gas hog. As for complexity
- you adjust the prop RPM a couple of times, and close the cowl flaps
when you level off, and that's about it. No more difficult to fly than
a 150 (IMHO) - but quite a bit heavier.
Faster too (120 - 130 knots).
David Johnson
Old May 17th 07, 12:26 AM posted to rec.aviation.owning
John Galban
I usually fly my Cherokee 180 all around the Rockies (in the summer
no less). I usually try to keep it a few hundred under gross, but
with a usable load of over 1000 lbs., that's not hard. Two guys and a
weeks worth of camping gear filling the back seat is no problem. It's
right at home in the mountains. Sure, 235 hp on the same airframe
would be better, but the 180 hp version will get the job done.
I have flown a few Cardinals in mountains. Forget the straight
C-177 (150 hp, fast wing). At minimum, you should use a C-177A, or
even better would be the C-177B. The B model has the normal wing, 180
hp, and CS prop. All good things for high density altitudes.
Old May 17th 07, 05:00 AM posted to rec.aviation.owning
scronje
Hi John
Thank you for your response.
What sort of climb rates are you seeing at altitude? You don't have any
online flying travelogues do you ;-) I would love to know more about your
flying experiences in the Rockies with the 180. Where you have flown, that
sort of thing.
Steve
Old May 17th 07, 11:23 PM posted to rec.aviation.owning
Dan Youngquist
up to the task? (The actual route would be CYBU - CYXH - CTB - LWS )
I fly a club Tomahawk and 172N (160HP) based at S73, in the hills a ways
east of LWS. I don't have a whole lot of experience flying over the
really serious mountains, but I fly to Missoula occasionally. Doesn't
look like there's anything a whole lot higher from there to Cut Bank, than
there is from here to Missoula. So, based on my experience, I'd suggest
you not completely write off a 172. Something bigger & more powerful
would be nice, but a 172 is cheaper to buy and cheaper to feed.
Of course, it might depend a lot on how big those 2-3 souls are, and how
much luggage they want to take along. But I wouldn't be too concerned
about loading the 172 to gross weight and flying from here to Cut Bank.
Don't know how much mountain flying you've done, but whatever you get,
make sure you know a little about it before you make the trip, and carry
some basic survival gear. Also, whenever practical, I like to select
routes that won't take 2 days to hike into, should rescuers find it
necessary.
-Dan
Old May 18th 07, 04:56 AM posted to rec.aviation.owning
Newps
VFR? No problem with a 172.
than there is from here to Missoula. So, based on my experience, I'd
suggest you not completely write off a 172. Something bigger & more
powerful would be nice, but a 172 is cheaper to buy and cheaper to feed.
necessary.
-Dan
Old May 18th 07, 04:16 PM posted to rec.aviation.owning
scronje
Hi Dan
What altitudes do you typically fly at?
Good point, and already on my "to-do" list. I don't have any mountain
experience. I understand there is an operation out of Calgary that offers
training.
Thank you for your response!
Steve
Old May 19th 07, 01:57 AM posted to rec.aviation.owning
John Galban
sort of thing.
At 200 lbs. under gross and 10,000 ft. density altitude, I still see
400-500 fpm in the climb. The caveat here is that it used to be
closer to 300 before I put gap seals all around and added Hoerner
style wingtips.
Travelogue? I think I have just the thing. You can check out my
website. It's mostly backcountry airstrips and camping locations.
It's at :
http://www.johngalban.com/
Old May 19th 07, 07:59 PM posted to rec.aviation.owning
scronje
Hi again, John!!
That sounds pretty impressive.
It's at :
Very neat site! Thank you. I have spent some time looking at it, and taken
a look at some of the strips you mention. Many of them are rather close
to the route I was discussing
How did you "get into" mountain flying? How much dual did you do before
you went at it alone? Some of those strips look pretty challenging, at
least in the photos.
Regards
Steve
Old May 20th 07, 01:33 AM posted to rec.aviation.owning
John Galban
I used to throw a load of camping gear on my motorcycle and head up
to the norther Rockies on my summer vacations. When I got a plane, I
just kept doing the same, only faster (and more fun).
I started flying to easy, unobstructed fields in mountainous areas,
then slowly worked my way up to the more challenging strips. Along
the way I got a lot of good advice from experienced mountain pilots,
and read as much as I could on the subject. I never really had any
dual instruction specifically for mountain flying. Coming from AZ,
you learn a lot about flying around mountains at high density altitude
as part of your private pilot training. Nowadays, there are
specialized mountain flying programs for those interested in flying
the backcountry, like http://www.mountaincanyonflying.com/ . They
will get you up to speed much faster than my "baby steps" approach :-)
Pilot dies midflight; co-pilot lands plane A Guy Called Tyketto Piloting 0 January 21st 07 07:56 PM
BD-6 article, 9/73 Plane & Pilot [email protected] Home Built 2 March 24th 06 11:15 AM
jan 2003 plane & pilot [email protected] Owning 1 June 16th 05 02:49 PM
Best Single Pilot IFR Plane Charles Talleyrand Owning 57 January 3rd 04 01:02 PM
Best Single Pilot IFR Plane Charles Talleyrand Instrument Flight Rules 64 December 9th 03 07:20 PM
