However! I've never moved a prop unless someone was standing on the
brakes, and since if I'm propping the plane it's usually because the guy at the controls is a stranger who probably knows little about Cubs, I always prop from behind. Blue skies! -- Dan Ford I flew cubs for awhile 30+ years ago. If there was no one around to prop yours, the drill was to stand behind the prop on the right side and flip it with your right hand, The left was poised to adjust the throttle when it caught. I recall that they were amazingly easy to start (usually on the first or second try). David Johnson |
On 16 May 2007 17:22:39 -0700, Dave wrote:
I flew cubs for awhile 30+ years ago. If there was no one around to prop yours, the drill was to stand behind the prop on the right side and flip it with your right hand, The left was poised to adjust the throttle when it caught. I recall that they were amazingly easy to start (usually on the first or second try). They still are, if the engine is warm, and that's the only occasion when I have to prop the plane myself. I hold onto the window frame with my left hand and, like you, pull down with the right hand. I bounce it lightly a couple times in advance, and one knows exactly when to pull down hard after it springs back up. At a minimum, I have a pair of chocks on a length of parachute cord. I can climb into the back seat, give the cord a tug, then reel in the chocks. Blue skies! -- Dan Ford |
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
