Paul Tomblin writes:
Recent aircraft (like the Cirrus) have a switch that automatically trims off all the control force that you or your autopilot are holding. Sounds like aircraft will eventually go the way of cars, with only a few idiot-light indicators and perhaps an airspeed indicator. I can see trimming off force for the pilot, but I'm puzzled by the autopilot interaction. Don't most autopilots work by adjusting trim to begin with (at least for altitude)? But the sort of aircraft I can afford don't have that - you have to be pretty close to trimmed before you can use the altitude hold. What happens if you are far away when you engage the autopilot? Sure, but it would be more logical to try out the autopilot when you're checking out in the aircraft in the first place. True, but when you're stuck in fog and you don't know anything about flying on instruments, it might be instinctive to reach for something that could fly the plane for you and give you some time to think of a way out of your situation. Instrument Proficiency Check. Were you engaged in unusual maneuvers that made you sick? I don't know what an IPC involves. One of my concerns about ever flying in a small airplane is that the movements might make me sick, although I've never been airsick in large aircraft (apart from some queasiness on one or two flights when I was already sick with something else and we were flying through turbulence). -- Transpose mxsmanic and gmail to reach me by e-mail. |
In a previous article, Mxsmanic said:
Paul Tomblin writes: Recent aircraft (like the Cirrus) have a switch that automatically trims off all the control force that you or your autopilot are holding. Sounds like aircraft will eventually go the way of cars, with only a few idiot-light indicators and perhaps an airspeed indicator. Sounds like you know very little about what it means to pilot an aircraft. But the sort of aircraft I can afford don't have that - you have to be pretty close to trimmed before you can use the altitude hold. What happens if you are far away when you engage the autopilot? It disengages. If you're close but not right on, it flashes a "trim up" or "trim down" light at you. Sure, but it would be more logical to try out the autopilot when you're checking out in the aircraft in the first place. True, but when you're stuck in fog and you don't know anything about flying on instruments, it might be instinctive to reach for something that could fly the plane for you and give you some time to think of a way out of your situation. Part of checking out in a new aircraft is becoming familiar with *all* aircraft systems - and you should do that in perfect weather. If you haven't become familiar with all aircraft systems then you shouldn't be flying it alone in marginal weather. Instrument Proficiency Check. Were you engaged in unusual maneuvers that made you sick? I don't know what Yes. One of the required skills for instrument flight is recovery from unusual attitudes. You close your eyes, your instructor tries to get you disoriented, puts the plane in an unusual attitude - usually either a steep spiral dive or a steep climb near stall. It's the "get you disoriented" part that got me sick - my instructor likes to give you a real roller coaster. The first recovery, I counted four really hard positive G pulls, a couple of hard negative G pushes,some hard slips and skids, and the stall horn went off a couple of times. The second recovery was about the same. -- Paul Tomblin http://blog.xcski.com/ Surely the 98% of DNA we share with monkeys must be enough to stop people from sinking this low. -- Frossie |
Sounds like you know very little about what it means to pilot an aircraft. Wait and see. Cirrus is doing very well. Part of checking out in a new aircraft is becoming familiar with *all* aircraft systems - and you should do that in perfect weather. If you haven't become familiar with all aircraft systems then you shouldn't be flying it alone in marginal weather. And I'm sure every pilot follows that policy religiously. That's why accidents never occur. Yes. One of the required skills for instrument flight is recovery from unusual attitudes. You close your eyes, your instructor tries to get you disoriented, puts the plane in an unusual attitude - usually either a steep spiral dive or a steep climb near stall. It's the "get you disoriented" part that got me sick - my instructor likes to give you a real roller coaster. The first recovery, I counted four really hard positive G pulls, a couple of hard negative G pushes,some hard slips and skids, and the stall horn went off a couple of times. The second recovery was about the same. His technique sounds excessive. -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() "Mxsmanic" wrote in message ... Paul Tomblin writes: Sounds like you know very little about what it means to pilot an aircraft. Wait and see. Cirrus is doing very well. Has "zip" to do with the man's point. Part of checking out in a new aircraft is becoming familiar with *all* aircraft systems - and you should do that in perfect weather. If you haven't become familiar with all aircraft systems then you shouldn't be flying it alone in marginal weather. And I'm sure every pilot follows that policy religiously. That's why accidents never occur. Yes, by far most do. But you couldn't realize this having never flown. Yes. One of the required skills for instrument flight is recovery from unusual attitudes. You close your eyes, your instructor tries to get you disoriented, puts the plane in an unusual attitude - usually either a steep spiral dive or a steep climb near stall. It's the "get you disoriented" part that got me sick - my instructor likes to give you a real roller coaster. The first recovery, I counted four really hard positive G pulls, a couple of hard negative G pushes,some hard slips and skids, and the stall horn went off a couple of times. The second recovery was about the same. His technique sounds excessive. Standard procedure with a good CFI. Clueless as usual. |
Mxsmanic wrote in
: Paul Tomblin writes: Sounds like you know very little about what it means to pilot an aircraft. Wait and see. Cirrus is doing very well. You're an idiot. Bertie |
You're an idiot.
Time for someone to insult his mental state, isn't it? I knew it was too good to last. |
"Morgans" wrote in news:eY_3i.16$Oe2.9
@newsfe06.lga: You're an idiot. Time for someone to insult his mental state, isn't it? I knew it was too good to last. And you were right! I knew he'd be back. K00ks never go far. bertie |
Paul,
Sounds like you know very little about what it means to pilot an aircraft. Please! Not again! How can you possibly feed the idiot? -- Thomas Borchert (EDDH) |
Mxsmanic wrote in
: Paul Tomblin writes: Recent aircraft (like the Cirrus) have a switch that automatically trims off all the control force that you or your autopilot are holding. Sounds like aircraft will eventually go the way of cars, with only a few idiot-light indicators and perhaps an airspeed indicator. then maybe you'll be able to fly! nah. Bertie |
Various flying and training questions (small aircraft) | Mxsmanic | Piloting | 6 | March 7th 07 05:33 AM |
Common instruments on small aircraft | Mxsmanic | Piloting | 245 | November 2nd 06 07:57 PM |
Floats on small aircraft | [email protected] | Home Built | 18 | February 15th 06 11:19 AM |
small partnership questions | TTA Cherokee Driver | Owning | 13 | August 28th 04 04:26 PM |
Small arms locker questions | Red | Naval Aviation | 4 | July 30th 03 02:10 PM |
