![]() "Dan Luke" wrote in message ... http://www.liveleak.com/view?i=a1f_1176988138&p=1 As a pilot that fly's 30% over gross weight (Yes, With Proper Permits And Special Airworthiness Certificate) in Piper's and Cessna's and max aft CG turn a 172 in to a tail skid when you get out I can point out a few things wrong with that take off. Main Reason, # 1 Lack of Directional Control #2 Left Ground Effect way to early #3 Had way to much flap max 15 Degrees in a cessna overgross...... |
![]() "NW_Pilot" wrote in message . .. "Dan Luke" wrote in message ... http://www.liveleak.com/view?i=a1f_1176988138&p=1 As a pilot that fly's 30% over gross weight (Yes, With Proper Permits And Special Airworthiness Certificate) in Piper's and Cessna's and max aft CG turn a 172 in to a tail skid when you get out I can point out a few things wrong with that take off. Main Reason, # 1 Lack of Directional Control #2 Left Ground Effect way to early #3 Had way to much flap max 15 Degrees in a cessna overgross...... I got my rating in Amarillo Texas. On a 100 degree summer day (3640 feet elevation), power is at a minimum. I was taught to use 15 degrees flaps as a max and keep the nose down until reaching the desired climb speed. Danny Deger |
Heavy landing 777 | jfp | Piloting | 25 | December 27th 05 10:08 PM |
re heavy landing 777 | jfp | Piloting | 0 | December 17th 05 03:23 PM |
Heavy lifters... | Darrel Toepfer | Rotorcraft | 2 | August 13th 05 10:20 PM |
Cessna 15X for heavy guys | 10Squared | Piloting | 12 | February 20th 05 03:57 AM |
JSF is too heavy for the Royal Navy | Mike | Military Aviation | 1 | May 18th 04 09:16 AM |
