Directional control after touchdown...
Old May 20th 07, 11:32 PM posted to rec.aviation.piloting,rec.aviation.student
Dudley Henriques[_2_]
Default Directional control after touchdown...
This brings out the most important point to be made in this entire thread.
"Let the AIRPLANE tell you what the ACTUAL winds are and fly the approach
and landing doing whatever the AIRPLANE tells you needs to be done for the
wind.
This is cardinal rule 1 for ALL landings and supercedes any and all forecast
and radio transmitted expectation for wind condition and direction.
Dudley Henriques
"Kyle Boatright" wrote in message
This simply illustrates why you can't trust ATIS to give you anything more
than a general sense of the conditions you might encounter. Winds change.
ATIS stations sometimes see different wind conditions than the touchdown
point, due to obstacles and wind direction.
With an ATIS reading of a 20 degree off-centerline, and 10 knots of wind,
I would fly a normal approach and make the corrections necessary to keep
the airplane pointed straight down the runway with no drift during the
flare and landing. I would not pre-suppose anything.
On the other hand, if ATIS was indicating a 90 degree crosswind at 10
knots, and the smoke from chimneys, or waves on a nearby lake, or the
windsock confirmed that information, I would *assume* that I had a
noticeable crosswind to deal with, and would be mentally prepared for
it...
BUT, I'd still wait until final approach to crank in gross corrections to
correct drift, and would apply whatever corrections were necessary in the
flare to keep the airplane aligned and kill any drift.
Bottom line.. ATIS gives you an indication of what the winds were at one
point on the airfield at a given time. The conditions at your touchdown
spot may be different.
KB
"Dan" wrote in message
ps.com...
I've got a question for the group. Suppose you find yourself in the
following situation:
You are flying a C182, landing on runway 22. The ATIS lists the winds
as 240 at 10. The windsock is not visible.
You approach at a normal airspeed, full flaps, coming over the numbers
at 65 kts. The mains touchdown, followed by the nosegear. Slight
right aileron is being maintained into the wind. Everything is
aligned properly and on the centerline at touchdown.
After touchdown the plane starts to drift to the right side of the
runway. You try to correct by pointing the nose back to the
centerline with left rudder. The nose seems to be pointed left, but
the plane is still drifting right. It feels like any more left rudder
could result in bad skidding and/or a ground loop.
What are the proper control inputs to correct the situation?
Left aileron would be in the _opposite_ direction of the indicated
crosswind. Increasing back pressure would make the nosewheel even
less effective.
--Dan
Old May 20th 07, 11:59 PM posted to rec.aviation.piloting,rec.aviation.student
Matt Whiting
wind.
Dudley Henriques
Say it again, Dudley! You fly the conditions as they exist, not what
you think they are or wish they were.
Matt
Old May 21st 07, 12:30 AM posted to rec.aviation.piloting,rec.aviation.student
"Matt Whiting" wrote in message
thread.
the wind.
forecast and radio transmitted expectation for wind condition and
direction.
Dudley Henriques
Say it again, Dudley! You fly the conditions as they exist, not what you
Matt
"You fly the conditions as they exist, not what you think they are or wish
they were".
How's that!! :-))
DH
Old May 21st 07, 01:51 AM posted to rec.aviation.piloting,rec.aviation.student
Matt Whiting
thread.
the wind.
direction.
Dudley Henriques
Matt
they were".
How's that!! :-))
DH
That's a keeper! :-)
Matt
directional gyro inlet filter dlevy Owning 2 October 9th 06 03:00 PM
Is every touchdown a stall? Mxsmanic Piloting 84 October 4th 06 05:16 PM
Directional Traffic System Rich Products 3 October 10th 05 10:04 AM
Shipping damage to directional gyro? Marv Home Built 2 April 20th 05 01:34 PM
FA:Directional Gyro 4000C-1 Autopilot Mitchell Joel Stolarski Aviation Marketplace 0 July 18th 04 06:43 AM
