Private wrote:
"Dan" wrote in message ps.com... I've got a question for the group. Suppose you find yourself in the following situation: You are flying a C182, landing on runway 22. The ATIS lists the winds as 240 at 10. The windsock is not visible. You approach at a normal airspeed, full flaps, coming over the numbers at 65 kts. The mains touchdown, followed by the nosegear. Slight right aileron is being maintained into the wind. Everything is aligned properly and on the centerline at touchdown. After touchdown the plane starts to drift to the right side of the runway. You try to correct by pointing the nose back to the centerline with left rudder. The nose seems to be pointed left, but the plane is still drifting right. It feels like any more left rudder could result in bad skidding and/or a ground loop. What are the proper control inputs to correct the situation? Left aileron would be in the _opposite_ direction of the indicated crosswind. Increasing back pressure would make the nosewheel even less effective. --Dan "Kyle Boatright" wrote in message . .. This simply illustrates why you can't trust ATIS to give you anything more than a general sense of the conditions you might encounter. Winds change. ATIS stations sometimes see different wind conditions than the touchdown point, due to obstacles and wind direction. With an ATIS reading of a 20 degree off-centerline, and 10 knots of wind, I would fly a normal approach and make the corrections necessary to keep the airplane pointed straight down the runway with no drift during the flare and landing. I would not pre-suppose anything. On the other hand, if ATIS was indicating a 90 degree crosswind at 10 knots, and the smoke from chimneys, or waves on a nearby lake, or the windsock confirmed that information, I would *assume* that I had a noticeable crosswind to deal with, and would be mentally prepared for it... BUT, I'd still wait until final approach to crank in gross corrections to correct drift, and would apply whatever corrections were necessary in the flare to keep the airplane aligned and kill any drift. Bottom line.. ATIS gives you an indication of what the winds were at one point on the airfield at a given time. The conditions at your touchdown spot may be different. KB I agree with the other good responses in this thread and would only add that the ATIS is a periodic and not real time report that could IMHE be 1 or more hours old. I always want to confirm the ATIS by seeing the windsock and monitoring crab and drift on downwind, base and especially on final. A wind sock is nice, but entirely optional. If you can't peg the wind pretty well while flying final, then you need more instruction and more practice. Matt |
directional gyro inlet filter | dlevy | Owning | 2 | October 9th 06 03:00 PM |
Is every touchdown a stall? | Mxsmanic | Piloting | 84 | October 4th 06 05:16 PM |
Directional Traffic System | Rich | Products | 3 | October 10th 05 10:04 AM |
Shipping damage to directional gyro? | Marv | Home Built | 2 | April 20th 05 01:34 PM |
FA:Directional Gyro 4000C-1 Autopilot Mitchell | Joel Stolarski | Aviation Marketplace | 0 | July 18th 04 06:43 AM |
