Recently, Dan posted:
I've got a question for the group. Suppose you find yourself in the following situation: You are flying a C182, landing on runway 22. The ATIS lists the winds as 240 at 10. The windsock is not visible. [...] That is not a lot of wind, and it's certainly not a lot of crosswind (get out the whiz wheel). The result that you were experiencing has to be from some other cause... perhaps ATIS was wrong? So... what I'd suggest is to pay attention to what the plane *is* doing rather than the theory of what it should be doing based on ATIS. Neil |
On May 21, 5:23 am, "Neil Gould" wrote:
Recently, Dan posted: I've got a question for the group. Suppose you find yourself in the following situation: You are flying a C182, landing on runway 22. The ATIS lists the winds as 240 at 10. The windsock is not visible. [...] That is not a lot of wind, and it's certainly not a lot of crosswind (get out the whiz wheel). The result that you were experiencing has to be from some other cause... perhaps ATIS was wrong? So... what I'd suggest is to pay attention to what the plane *is* doing rather than the theory of what it should be doing based on ATIS. Neil OK... However, it does sound like the consensus from the group is that aileron does nothing to correct drift once the plane has touched down... --Dan |
On May 21, 5:23 am, "Neil Gould" wrote: Recently, Dan posted: I've got a question for the group. Suppose you find yourself in the following situation: You are flying a C182, landing on runway 22. The ATIS lists the winds as 240 at 10. The windsock is not visible. [...] That is not a lot of wind, and it's certainly not a lot of crosswind (get out the whiz wheel). The result that you were experiencing has to be from some other cause... perhaps ATIS was wrong? So... what I'd suggest is to pay attention to what the plane *is* doing rather than the theory of what it should be doing based on ATIS. Neil OK... However, it does sound like the consensus from the group is that aileron does nothing to correct drift once the plane has touched down... I agree, if all wheels are on the ground and the wind is light. OTOH, if you are touched down on one main, the ailerons are rather important. If the winds are heavy, they can also keep both of your mains planted on the runway. IMO, there is no pat answer that supercedes paying attention to what the plane is doing. You've gotten some good feedback, and I'd second the suggestion that you to get some more x-wind experience with an instructor. Neil |
![]() "Dan" wrote in message oups.com... On May 21, 5:23 am, "Neil Gould" wrote: Recently, Dan posted: I've got a question for the group. Suppose you find yourself in the following situation: You are flying a C182, landing on runway 22. The ATIS lists the winds as 240 at 10. The windsock is not visible. [...] That is not a lot of wind, and it's certainly not a lot of crosswind (get out the whiz wheel). The result that you were experiencing has to be from some other cause... perhaps ATIS was wrong? So... what I'd suggest is to pay attention to what the plane *is* doing rather than the theory of what it should be doing based on ATIS. Neil OK... However, it does sound like the consensus from the group is that aileron does nothing to correct drift once the plane has touched down... --Dan Saying ailerons do "nothing" to correct drift after touchdown is probably an oversimplification. If you land in a banked condition, the ailerons can help you maintain that condition. Also, even if you've got all of the wheels on the ground, correct aileron input will reduce the aircraft's tendency to raise the upwind wing. To a smaller extent, aileron deflection after touchdown will result in *some* bank angle, because the left and right gear will have different loading. This is particularly true at higher speeds, such as right after touchdown. KB |
directional gyro inlet filter | dlevy | Owning | 2 | October 9th 06 03:00 PM |
Is every touchdown a stall? | Mxsmanic | Piloting | 84 | October 4th 06 05:16 PM |
Directional Traffic System | Rich | Products | 3 | October 10th 05 10:04 AM |
Shipping damage to directional gyro? | Marv | Home Built | 2 | April 20th 05 01:34 PM |
FA:Directional Gyro 4000C-1 Autopilot Mitchell | Joel Stolarski | Aviation Marketplace | 0 | July 18th 04 06:43 AM |
