Prop sync and noise in twins
Old May 22nd 07, 03:35 PM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Default Prop sync and noise in twins
Mxsmanic wrote in
John Theune writes:
If you type in prop synch multi-engine planes into the google search
window the first hit you will see is this
The AVSIM Forums - Viewing topic #736 - Prop sync
Out of synch propellers will not be as obvious or as annoying in a
simulator as in a real plane. In most aircraft with prop synch, you
first manually ...
forums.avsim.net/dcboard.php?az=show_topic&forum=189&topic_id=736
&mode
=full - 56k - Cached - Similar pages
Go there , read it and you will know all you want to know.
Thanks. I guess people in the AVSIM forums actually answer questions
rather than just point people to Google.
Ooow 1Teh big flying circle jerk! you must be so happy there..
Bertie
Old May 22nd 07, 08:04 PM posted to rec.aviation.piloting
Erik
Bertie
You are one small and unhappy person. Find a hobby.
Cheer yourself up. Life can be better, you know.
Old May 22nd 07, 09:37 PM posted to rec.aviation.piloting
Erik wrote in news:1356fn0ndo1r1f3
@corp.supernews.com:
Bertie
Got one thanks.
Cheer yourself up.
I'm happy as a pig in ****, actually.
Thank some little net nanny? I know.
Berti e
Old May 23rd 07, 02:23 AM posted to rec.aviation.piloting
EatMe
Bertie
Got one thanks.
Cheer yourself up.
Berti e
Amazing synchronicity that you're here, on a prop sync thread, making
mosquito noises. Sync up your whine fella.
Old May 23rd 07, 11:56 AM posted to rec.aviation.piloting
EatMe wrote in news:1179883402.364740.164620
@p47g2000hsd.googlegroups.com:
Bertie
Got one thanks.
Cheer yourself up.
Berti e
as if i wouldn't
Bertie
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets Jim Macklin Piloting 26 January 13th 07 12:06 AM
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets Jim Macklin Instrument Flight Rules 15 January 13th 07 12:06 AM
CompaqAero1530 sync question Stewart Kissel Soaring 0 February 21st 05 03:15 AM
Prop noise vs. engine noise Morgans Piloting 8 December 24th 03 03:24 AM
