![]() Matt Whiting wrote: I would say so. The following article has a graph shows the relationship on average between wind speed and height. The difference between the wind at 1m (about the average height of your Bo wing) and at 2m (about the average height of a 182 wing) is about 10%. My Bo wing is 4'2" at the tip. I know that because I installed a furnace in my hangar last month. The code calls for the furnace to be a minimum 10 feet above the wing. I'm 6'2" and coud not walk under the wing of my 182 as it sat on its big tires. So I would say the top of the wing tip there would be at most 6'6". Even according to your generalized graph an 18 meter difference in height brings a 5 kph difference in windspeed, the difference between about two feet is trivial and certainly not a factor at all for the subject at hand which was stability of the airplane because one is a high wing and one is a low wing. |
Newps wrote:
Matt Whiting wrote: I would say so. The following article has a graph shows the relationship on average between wind speed and height. The difference between the wind at 1m (about the average height of your Bo wing) and at 2m (about the average height of a 182 wing) is about 10%. My Bo wing is 4'2" at the tip. I know that because I installed a furnace in my hangar last month. The code calls for the furnace to be a minimum 10 feet above the wing. I'm 6'2" and coud not walk under the wing of my 182 as it sat on its big tires. So I would say the top of the wing tip there would be at most 6'6". Even according to your generalized graph an 18 meter difference in height brings a 5 kph difference in windspeed, the difference between about two feet is trivial and certainly not a factor at all for the subject at hand which was stability of the airplane because one is a high wing and one is a low wing. That is why I said average height of the Bo wing. Most Bonanzas I've seen have a fair bit of dihedral and the wing isn't anywhere near 4'2" at the root. I don't know what the average height is, but is sure isn't 4'2". I don't see how you get a 5 kph difference with 18m altitude difference. The chart expresses the difference as a factor relative to 1 as it can't give an absolute wind velocity difference without knowing the base velocity at 1m which is where the chart starts. It states that the relationship is to the 1/7th power of the altitude. Since it takes 1m as the reference altitude for a wind increase factor of 1.0, an altitude of 18m has an increase factor of 18 to the 1/7th power. This is 1.51 which indicates that the wind at 18m is 51% faster than at 1m. Comparing 1m to 2m which is approximately correct to compare a Bo wing to 182 wing, the increase factor is 2 to the 1/7th power which is 1.1. Thus the wind velocity at 2m is 10% greater than at 1m. So, if the wind at 1m is 20 MPH then the wind at 2m would be expected to be 22 MPH. If the wind at 1m is 40 MPH it would be expected to be 44 at 2m. As I said, 10% may or may not be significant in any particular situation, but to say that the wind doesn't vary with altitude above the ground as you claimed initially is simply false. I realize that you never admit you are wrong and won't this time, but that doesn't change the fact that you are wrong and it doesn't change the physics of wind flow at various altitudes above the ground. Matt |
Recently, Matt Whiting posted:
I don't see how you get a 5 kph difference with 18m altitude difference. The chart expresses the difference as a factor relative to 1 as it can't give an absolute wind velocity difference without knowing the base velocity at 1m which is where the chart starts. [...] The conditions in the original post is that the winds were 10 kts. *reported by ATIS*. I don't know how one would translate that into wind speed at the point of touchdown with any accuracy, but it's a safe bet that the height of the wing doesn't much matter in this scenario. One can be factually correct, yet irrelevant. Neil |
"Neil Gould" wrote: Recently, Matt Whiting posted: I don't see how you get a 5 kph difference with 18m altitude difference. The chart expresses the difference as a factor relative to 1 as it can't give an absolute wind velocity difference without knowing the base velocity at 1m which is where the chart starts. [...] The conditions in the original post is that the winds were 10 kts. *reported by ATIS*. I don't know how one would translate that into wind speed at the point of touchdown with any accuracy, but it's a safe bet that the height of the wing doesn't much matter in this scenario. One can be factually correct, yet irrelevant. Neil It all boils down to: 1. ATIS is only a guide about landing conditions. 2. Use every control available to correct for drift and to keep the plane straight on landing. 3. Use flaps as necessary (you may not want flaps with high crosswinds). 4. You, the pilot, are responsible for controlling the plane until it is parked and the engine shut down -- not the air traffic controller, not the weather observer, not the FBO. |
![]() Matt Whiting wrote: That is why I said average height of the Bo wing. Most Bonanzas I've seen have a fair bit of dihedral and the wing isn't anywhere near 4'2" at the root. I don't know what the average height is, but is sure isn't 4'2". Cessna's have dihedral too. May not be exactly the same but it's there. I don't see how you get a 5 kph difference with 18m altitude difference. Did I read that wrong? The chart said the wind went from 15 kmh to 20 kmh. It states that the relationship is to the 1/7th power of the altitude. Since it takes 1m as the reference altitude for a wind increase factor of 1.0, an altitude of 18m has an increase factor of 18 to the 1/7th power. This is 1.51 which indicates that the wind at 18m is 51% faster than at 1m. Comparing 1m to 2m which is approximately correct to compare a Bo wing to 182 wing, the increase factor is 2 to the 1/7th power which is 1.1. Thus the wind velocity at 2m is 10% greater than at 1m. So, if the wind at 1m is 20 MPH then the wind at 2m would be expected to be 22 MPH. If the wind at 1m is 40 MPH it would be expected to be 44 at 2m. That's a lot of words to prove that the difference is irrelevant for the purpose of this discussion. No way anybody tells the difference from 20 - 22 mph or 40 - 44 mph. |
Newps wrote:
Cessna's have dihedral too. May not be exactly the same but it's there. Yes, but very little. High-wings have more inherent stability since the CG is below the CP. I don't see how you get a 5 kph difference with 18m altitude difference. Did I read that wrong? The chart said the wind went from 15 kmh to 20 kmh. That was a representative example, but didn't apply as we are taking from about 1m to about 2m, not from 2m to 18m. It is the general formula that I was looking at which can be used for any wind speed and altitude difference of interest. It states that the relationship is to the 1/7th power of the altitude. Since it takes 1m as the reference altitude for a wind increase factor of 1.0, an altitude of 18m has an increase factor of 18 to the 1/7th power. This is 1.51 which indicates that the wind at 18m is 51% faster than at 1m. Comparing 1m to 2m which is approximately correct to compare a Bo wing to 182 wing, the increase factor is 2 to the 1/7th power which is 1.1. Thus the wind velocity at 2m is 10% greater than at 1m. So, if the wind at 1m is 20 MPH then the wind at 2m would be expected to be 22 MPH. If the wind at 1m is 40 MPH it would be expected to be 44 at 2m. That's a lot of words to prove that the difference is irrelevant for the purpose of this discussion. No way anybody tells the difference from 20 - 22 mph or 40 - 44 mph. 4 MPH is the difference between stalling at not stalling if you are already flying only 2 MPH above the stall. Whether that is relevant depends on the circumstances, no doubt. I never said anything different. I'm simply correcting your statement that wind speed is constant with height above the ground - which it isn't. Having a 10% higher headwind when touchdown in a 182 vs. a Bo or Piper is significant with respect to landing and takeoff distance. Check your POH if you don't think a 10% difference in wind makes a performance difference. Matt |
directional gyro inlet filter | dlevy | Owning | 2 | October 9th 06 03:00 PM |
Is every touchdown a stall? | Mxsmanic | Piloting | 84 | October 4th 06 05:16 PM |
Directional Traffic System | Rich | Products | 3 | October 10th 05 10:04 AM |
Shipping damage to directional gyro? | Marv | Home Built | 2 | April 20th 05 01:34 PM |
FA:Directional Gyro 4000C-1 Autopilot Mitchell | Joel Stolarski | Aviation Marketplace | 0 | July 18th 04 06:43 AM |
