Engine-out procedures and eccentric forces on engine pylons
Old May 24th 07, 12:28 AM posted to rec.aviation.piloting
Erik
Default Engine-out procedures and eccentric forces on engine pylons
TheSmokingGnu wrote:
Erik wrote:
I love the window seat, but dammit, I cannot look at the wing
ever. "Ok, if it didn't flex like that, it would be brittle
and snap. It's supposed to bounce, it's not supposed to break"
But nothing reassures me.
I find it helps in cases like these to watch a few videos of wing
loading tests, so you can see really just *how* far those wings can go
before breaking.
http://www.youtube.com/watch?v=6Uo0C01Fwb8
TheSmokingGnu
Holy crap. I thought the two to three foot deflection
I've seen was a lot. I had no idea that you could turn
an airplane into a U.
Old May 24th 07, 02:03 AM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Mxsmanic wrote in
Long ago it occurred to me that a twin-engine jet running with one
engine out might be putting tremendous eccentric stress on the plyon
and mounting of the running engine (meaning stress not aligned with
the normal thrust vector of the engine). Today it occurred to me that
this might not be true if the pilots adjust the attitude of the
aircraft so that it is flying straight forward. The adjustments would
create opposing forces that not only keep the aircraft in level flight
but also realign the stress on the running engine, as if there were
still two engines and symmetric forces on the pylons.
Does this make sense?
Nope, pretty much the same as everythign else you post.
Bertie
Old May 24th 07, 02:04 AM posted to rec.aviation.piloting
Mxsmanic wrote in
Bob Moore writes:
You should see what those pylons do in heavy turbulence!
The only stress is on the pilot who looks at them. :-)
I've seen engine nacelles swaying merrily to and fro (along the wing
axis) in turbulence but I didn't know if twisting forces applied to
the pylons would be so easily tolerated.
Fjukktard
Bertie
Old May 24th 07, 09:40 PM posted to rec.aviation.piloting
tom laudato[_2_]
I.m wondering if the engineering on wings has changed a bit. I worked for
an airline carrier in the early 60's and we took deliver of the first
boeing 727 built. the company provied us with a very similar video. Its
showed a 727 straped into a cradel and the wings were bent up similar to
what this utube shows..
Difference:
i watched the wings pushed up to where both tips touched each other many
many many times
there was not a failur and i do not remeber exactly how many times but it
was in the dozens. I wonder what the difference is that this wing breaks
after only one raise
tom
.130...
Mxsmanic wrote in
Bob Moore writes:
Fjukktard
Bertie
Old May 24th 07, 10:27 PM posted to rec.aviation.piloting
Bertie the Bunyip
Difference:
many many times
Nope, essentially the same up to the point where they're sticking
Carbon fiber spars in, but the certification standards are the same.
A wing pylon will happily accept a consideraable load in just about
any flight attitude, what it won't accept is s sudden high G load such
as extreme turbulence or an abrupt engine stoppage might cause.
you won't break a wing off too easily, though.
Bertie
Bertie the Bunyip
On 23 May, 17:04, Mxsmanic wrote:
Bob Moore writes:
Nope! Back in my B-707 days, the engine was attached to the pylon
with just three bolts about the size of your forefinger, and each of
these bolts was designed to break-away and release the engine before
it could do damage to the wing.
Well, that's certainly reassuring.
Why, what's it matter to you, you don't fly anyway.
Bertie
Old May 25th 07, 02:56 AM posted to rec.aviation.piloting
Kev
On May 23, 12:04 pm, Mxsmanic wrote:
Bob Moore writes:
Not necessarily. Although it was admittedly caused by maintenance
crew abuse, don't forget the Chicago DC-10 accident, where the engine
came off and caused the deadliest accidental crash in US history.
http://en.wikipedia.org/wiki/America...nes_Flight_191
Old May 25th 07, 03:15 AM posted to rec.aviation.piloting
muff528
"Kev" wrote in message
Bob Moore writes:
Wow! this is spooky! (from the wiki article cited above)................
"The crash in Chicago remains the most deadly single-aircraft accident in
United States history. Another flight with the same number, Delta Air Lines
Flight 191, crashed at Dallas/Fort Worth International Airport in 1985. Most
recently, Delta Air Lines Flight 5191, operated by Comair as Flight 191,
crashed in 2006 killing 49 people. All three carriers have since retired the
flight number 191, as is currently customary after major accidents on most
airlines. In addition, Puerto Rican airline Prinair also had a fatal flight
numbered Flight 191. The only fatal X-15 crash was also Flight No. 191."
Old May 26th 07, 01:03 AM posted to rec.aviation.piloting
Bertie the Bunyip
On May 23, 5:11 pm, Erik wrote:
BDS wrote:
"Bob Moore" wrote...
My wife and I were on a flight a few years back in an A300 IIRC and we were
in seats that gave us a clear view of the engine on the left wing. I was
casually looking out at it when I noticed that it was oscillating back and
forth quite noticeably and considerably, and we were only in light chop at
the time. My first impression was HOLY #$%&! quickly followed by the
realization that since it hadn't come off yet it must be normal.
Judging by how much it was moving around you would have thought it was held
on with bungee cords.
BDS
But nothing reassures me.-
Understandable. I'd feel the same way if I was you.
Bertie
Hide quoted text -
- Show quoted text -
Westland Wyvern Prototype - RR Eagle Engine - Rolls Royce Eagle 24cyl Liq Cooled Engine.jpg Ramapo Aviation Photos 0 April 17th 07 09:14 PM
Saturn V F-1 Engine Testing at F-1 Engine Test Stand 6866986.jpg [email protected] Aviation Photos 1 April 11th 07 04:48 PM
F-1 Engine for the Saturn V S-IC (first) stage depicts the complexity of the engine 6413912.jpg [email protected] Aviation Photos 0 April 9th 07 01:38 PM
1710 allison v-12 engine WWII p 38 engine Holger Stephan Home Built 9 August 21st 03 08:53 AM
Jettisonable Pylons? Jeroen Wenting Military Aviation 3 July 6th 03 05:07 AM
