buy or rent a 2006 182
Old May 25th 07, 05:08 PM posted to rec.aviation.owning
Dan Luke
Default buy or rent a 2006 182
Since it looks very much like I will be sans airplane in a week or so, I've
been kicking around options for future flying.
My general bad feeling about owning an airplane in Mobile notwithstanding,
there's still a chance I could buy another airplane if renting a 2006 Cessna
182T from the local flight school doesn't work out. So I ran a few numbers
to see how buying and renting the same model airplane would compare, based on
costs here in Mobile:
o Rent
100 hrs/yr @ $190/hr. $19,000
Renter's ins., $1M smooth $3,185 (?)
Total $22,185
o Buy slightly used '06 182T, fly 100 hrs/yr
Engine overhaul setaside @ $12.50/hr $1,300
Fuel, 13gph @ $4.85/gal $6,305
Shelter @ $180/mo. $2,160
Insurance, $1M smooth $3,185
Annual (during warranty) $750
Oil & Filters $100
Cost of money @ 6% on $310K + tax $20,460
Total $34,260
Dan
? at BFM
Old May 25th 07, 07:52 PM posted to rec.aviation.owning
Montblack
("Dan Luke" wrote)
Oil & Filters $100
Total $34,260
Not sure what your mission is, but:
http://www.ionaircraft.com/
Have considered the ION? g
I just got a call from Steve, he'd like some help this afternoon. Taxi
testing - with canopy on this time, etc.
Here's some FunFacts:
1. 99 inch canopy ..... The view will be unmatched!
2. Jabiru 3300 .......... 1/3 the fuel burn of the 182 :-)
3. Airspeed(?) .......... Flight tests later this spring
4. Cockpit noise ...... In theory (until flight tests can verify this) we
think it will be relatively quite.
5. Pricing (?) ............. Not sure if that's a pre-OSH or a post-OSH
decision?
6. Removable wings!!
7. Chick magnet? Um, sure. The goal is to fly well and look cool doing it.
It's designed to be a fun AND capable plane.
8. Quick build times and AFFORDABLE!! Two bedrock principles at ION. (My
words, but also, my observations.)
When you order one, it will arrive in your driveway as a primered fuselage
with the outside length (run) of each boom needing attaching/sanding the
joint/etc. The elevator tail section will require a similar 'sectioned
piece' to be mated to the rest of the empennage. Cables and pulleys will
have access panels - for you to get in there and do that.
The NEW 120 hp engine will come pre-tested from Jabiru.
The canopy will come from one of the leading canopy makers in the country -
to your driveway.
Same with the landing gear.
Same with the (removable) wings - like a quick build kit from Vans. :-)
51% rule?
Yes! There's still plenty to do even after all the components are delivered
to you.
On the flip side, the jigging has been done for you - in the form of a
delivered fuselage. (Have I mentioned it will be primer'd?)
Options:
Canopy tinting
Seat choice
Avionics
You'll paint the fuselage.
Wings polished, or painted?
It's a homebuilt - it's yours do equip as you see fit. Basically, get as
fancy as you want.
I'd like us to play "customer" on ION #2, after OSH, to see how long one
will (really) take to ...assemble.
That'll be up to Steve. g
Montblack
I'm off to ION World Headquarters for the afternoon ....or as Steve calls
it, the left side of Al's hangar.
Old May 25th 07, 08:21 PM posted to rec.aviation.owning
john smith
I only pay about $750/year with AVEMCO for $1M renters insurance.
Old May 25th 07, 08:52 PM posted to rec.aviation.owning
Deadstick
o Rent
Total $22,185
Oil & Filters $100
Total $34,260
Dan
? at BFM
Unless you find a way to use it as a tax write-off, generally at 100hr
flight time per year its less expensive to rent than to own. Renters
insurance shouldn't cost you more than $2000.
Old May 25th 07, 10:37 PM posted to rec.aviation.owning
Dan Luke
What hull value does that cover?
Dan
? at BFM
Old May 25th 07, 11:19 PM posted to rec.aviation.owning
Vaughn Simon
"Dan Luke" wrote in message
o Rent
Total $22,185
Yes but what amount of hull is covered at that cost? Last I checked, you
can't even buy enough renter's hull insurance to cover half of the value of that
plane. I don't understand why people rent expensive planes when they can't
insure themselves.
Old May 26th 07, 12:14 AM posted to rec.aviation.owning
Kyle Boatright
One thing to consider is that with an aircraft you own, you'll have equity.
Depending on the term of your loan and the speed at which the aircraft
depreciates, that equity could be positive or negative (aarg)..
Beyond the equity issue, there is something to be said for being able to
schedule the aircraft at your convenience and for the ability to maintain
and upgrade the aircraft to your standards.
KB
I've been kicking around options for future flying.
Cessna 182T from the local flight school doesn't work out. So I ran a few
numbers to see how buying and renting the same model airplane would
compare, based on costs here in Mobile:
o Rent
Total $22,185
Oil & Filters $100
Total $34,260
Dan
? at BFM
Old May 26th 07, 12:19 AM posted to rec.aviation.owning
B A R R Y
Unless you can find the right partnership.
Old May 26th 07, 12:28 AM posted to rec.aviation.owning
Dan Luke
Roger that.
I've owned '87D for seven years. I don't know if I'll be able to stand going
back to renting. We'll see.
Dan
? at BFM
Old May 26th 07, 12:32 AM posted to rec.aviation.owning
Dan Luke
Cool looking bird, but I need a long range IFR cruiser.
Dan
? at BFM
New ships available for rent. [email protected] Soaring 0 August 14th 06 10:58 PM
Rent a Garmin 396? Dan Piloting 10 April 6th 06 01:03 AM
How to rent out my airplane Isaac McDonald Owning 27 August 26th 04 06:22 AM
Where to rent in Anchorage, AK 'Vejita' S. Cousin Piloting 5 April 12th 04 05:38 AM
Rent a Cessna 180 or 185 Doug Piloting 0 October 18th 03 07:54 PM
