Morgans wrote:
"Jay Honeck" wrote I know you probably realize this, but your observation makes no sense. There is no difference in "power" between avgas and mogas. Actually, there are slightly more BTU's in a gallon of mogas than in a gallon of avgas. If an engine was to have its fixed advanced spark too far forward, the lower octane mogas could produce less power. How so? Matt |
![]() "Matt Whiting" wrote How so? Whem I was much younger, an all cars had points and condensers, I would do my own tune-ups. Sometimes the timing would need to be adjusted. How to do it, if you did not have a timing light handy? I would loosen the distributor bolt, until it was tight enough to move by hand, but not so loose that it would not vibrate around. After that, I would get the engine warmed up, and take it out on the road, and punch it. It was not so obvious if the timing was retarded a bit, until it was really retarded. It was _quite_ obvious when it was too far advanced, as would not have much power, and would knock like crazy. That a good enough answer? -- Jim in NC |
Morgans wrote:
"Matt Whiting" wrote How so? Whem I was much younger, an all cars had points and condensers, I would do my own tune-ups. Sometimes the timing would need to be adjusted. How to do it, if you did not have a timing light handy? I would loosen the distributor bolt, until it was tight enough to move by hand, but not so loose that it would not vibrate around. After that, I would get the engine warmed up, and take it out on the road, and punch it. It was not so obvious if the timing was retarded a bit, until it was really retarded. It was _quite_ obvious when it was too far advanced, as would not have much power, and would knock like crazy. That a good enough answer? Maybe to another question. You didn't address why having the timing advanced too far would cause a greater power loss with mogas than with avgas. And noise from igniting the mixture too soon and detonation are two different phenomenon. Matt |
![]() "Matt Whiting" wrote Maybe to another question. You didn't address why having the timing advanced too far would cause a greater power loss with mogas than with avgas. And noise from igniting the mixture too soon and detonation are two different phenomenon. Sorry, I'll try again. The higher octane of 100LL will allow more advanced spark settings without knock and detonation, than will the lower octane mogas. End result would be that the mogas could show a loss of power, when avgas is still allowing the engine to function normally. I don't disagree with the fact that in normal conditions, and a normal engine, the power of an engine running 100LL or mogas should be virtually the same. -- Jim in NC |
Morgans wrote:
"Matt Whiting" wrote Maybe to another question. You didn't address why having the timing advanced too far would cause a greater power loss with mogas than with avgas. And noise from igniting the mixture too soon and detonation are two different phenomenon. Sorry, I'll try again. The higher octane of 100LL will allow more advanced spark settings without knock and detonation, than will the lower octane mogas. End result would be that the mogas could show a loss of power, when avgas is still allowing the engine to function normally. This is only true for engines that have very advanced ignition timing, which isn't true for most GA piston engines, or engines with very high compression ratios, again, not true for most GA piston engines. Keep in mind that most were designed to run on 80 octane avgas... I don't disagree with the fact that in normal conditions, and a normal engine, the power of an engine running 100LL or mogas should be virtually the same. Yes, I can't imagine many GA piston engines where this wouldn't be the case. Maybe a turbocharged engine running very hot. Matt |
Matt Whiting wrote:
This is only true for engines that have very advanced ignition timing, which isn't true for most GA piston engines, or engines with very high compression ratios, again, not true for most GA piston engines. Keep in mind that most were designed to run on 80 octane avgas... I don't disagree with the fact that in normal conditions, and a normal engine, the power of an engine running 100LL or mogas should be virtually the same. Yes, I can't imagine many GA piston engines where this wouldn't be the case. Maybe a turbocharged engine running very hot. Matt There are plenty of high compression GA piston engines that can't use mogas because the octane requirement is too high. The majority of GA engines are lower octane (something like 78% of the engines IIRC). The majority of the hours flown in piston aircraft however is done by the 21% of aircraft that have higher octane requirements than mogas can offer, my 260 HP O-540-E4B5 included. It is a normally aspirated 6 cylinder engine, but with high enough compression that there is not sufficient detonation margin with less than 96 octane fuel. |
Ray Andraka wrote:
Matt Whiting wrote: This is only true for engines that have very advanced ignition timing, which isn't true for most GA piston engines, or engines with very high compression ratios, again, not true for most GA piston engines. Keep in mind that most were designed to run on 80 octane avgas... I don't disagree with the fact that in normal conditions, and a normal engine, the power of an engine running 100LL or mogas should be virtually the same. Yes, I can't imagine many GA piston engines where this wouldn't be the case. Maybe a turbocharged engine running very hot. Matt There are plenty of high compression GA piston engines that can't use mogas because the octane requirement is too high. The majority of GA engines are lower octane (something like 78% of the engines IIRC). The majority of the hours flown in piston aircraft however is done by the 21% of aircraft that have higher octane requirements than mogas can offer, my 260 HP O-540-E4B5 included. It is a normally aspirated 6 cylinder engine, but with high enough compression that there is not sufficient detonation margin with less than 96 octane fuel. I'd like to see your source of these statistics. Matt |
Fuel Prices For The July Pilgrimage | RST Engineering | Piloting | 46 | June 15th 07 10:45 PM |
Fuel prices | Paul kgyy | Owning | 14 | October 19th 05 10:55 PM |
Fuel Prices | Ross Richardson | Owning | 60 | September 30th 05 02:06 AM |
Fuel Prices | ~R | Rotorcraft | 0 | September 10th 05 03:56 PM |
Fuel Prices | S Green | Piloting | 0 | May 9th 04 09:47 PM |
