Coordinated turns without rudder, and autopilots
Old May 28th 07, 04:59 PM posted to rec.aviation.piloting
Luke Skywalker
Default Coordinated turns without rudder, and autopilots
On May 28, 8:11 am, Ron Natalie wrote:
Dan wrote:
On May 27, 5:44 pm, Mxsmanic wrote:
How do autopilots make coordinated turns even when they cannot control the
rudder?
If they don't control the rudder, they do not make coordinated turns!
--Dan
Boy we have the blind leading the blind here.
The whole point of that big vertical slab of metal sticking out of the
ass-end of your airplane is to provide a natural tendency for the
aircraft to fly coordinated. The pedals are just there for the
outlying conditions (low speed, high AOA for example) and fine
adjustment.
Ron...
oh my goodness...get some time with a good book on the subject and
then a CFI.
Robert
Old May 28th 07, 06:26 PM posted to rec.aviation.piloting
Andrew Sarangan
rudder?
--Dan
adjustment.
Ron...
then a CFI.
Robert- Hide quoted text -
Ron is correct. The vertical fin makes the airplane weather-vane into
the wind, and that's what co-ordination is all about. The rudder is
there only to help the vertical stab do this job.
A perfect airplane will not need rudder.
Old May 28th 07, 08:12 PM posted to rec.aviation.piloting
Dan[_1_]
rudder?
--Dan
adjustment.
Ron...
then a CFI.
A perfect airplane will not need rudder.- Hide quoted text -
- Show quoted text -
So where is this perfect airplane? I don't know about you, but I need
the rudder pedals to fly the aircraft.
--Dan
Old May 28th 07, 08:53 PM posted to rec.aviation.piloting
Dudley Henriques[_2_]
"Dan" wrote in message
control the
rudder?
turns!
--Dan
adjustment.
Ron...
then a CFI.
--Dan
Basically the vertical stabilizer is there for directional stability and to
control yaw; the rudder is there to change yaw. This is VERY basic, but you
can say that the rudder is there to keep the tail alligned with the nose
Rudder use to acheive the objective of keeping the tail lined up with the
nose can accurately be said to be relative to aircraft type and airspeed.
You need a fair amount of rudder to handle yawfor example in a typical light
general aviation type airplane to execute a coordinated turn entry and exit.
On the other hand however, in a T38, you can fly a complete aerobatic
sequence including point rolls with both feet planted firmly on the floor of
the rudder tunnels.
Dudley Henriques
Old May 29th 07, 03:36 AM posted to rec.aviation.piloting
Mxsmanic
Dudley Henriques writes:
So how does the autopilot do it? As far as I understand, autopilots in small
aircraft don't generally have control over the rudder, and yet they can
execute coordinated turns.
Old May 29th 07, 08:50 PM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Mxsmanic wrote in
the nose can accurately be said to be relative to aircraft type and
airspeed. You need a fair amount of rudder to handle yawfor example
in a typical light general aviation type airplane to execute a
It doesn't, fjukkkwit.
bertie
Old May 30th 07, 03:45 AM posted to rec.aviation.piloting
Capt. Geoffrey Thorpe
"Mxsmanic" wrote in message
light
exit.
small
What in the world makes you think that an autopilot can make a "coordinated"
turn without using the rudder if a pilot can't? That's complete and utter
nonsense.
If you have "observed" this then, either A) Your simulation falls a bit
short in terms of simulating how the simulated autopilot works - I assume
it's easier to program a simulated autopilot without adding the "make it
appear un-coordinated" feature. Or, B) You only think that the autopilot
does a much better job than a pilot does - perhaps you are a bit ham-fisted
with your simulation - without ever being in in airplane, it would be easy
to not realize what you are doing given the lack of feedback and the fact
that no one has ever "flown" with you - I find that I "overcontrol" when
flying a sim...
Geoff
Old May 30th 07, 06:03 AM posted to rec.aviation.piloting
Mxsmanic
"Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com writes:
Presumably a pilot can; I want to know how. And nobody has been able to tell
me thus far.
flying a sim...
Or (C) nobody here has a clue and nobody wants to admit it, even though their
argument among themselves makes it obvious.
Do you know how it's done, or don't you?
Old May 29th 07, 01:11 PM posted to rec.aviation.piloting
Denny
the rudder tunnels.
Dudley Henriques- Hide quoted text -
I've always wanted to fly a 38 but never had the opportunity...
My Super Viking was one of those few GA machines with adequate tail
volume that you could fly instrument approaches with your feet on the
floor... Conversely, you could fly the plane nicely without ailerons
just using that powerful rudder...
One of the little tricks I do when 'unbrain washing' the pilots I have
helped over the years, is to say to them that: "you have just snapped
the cables to the ailerons and the elevator... now fly me back to the
airport without touching the yoke!"... Some have been totally
helpless... A few have almost instantly figured it out.. And most need
only be shown how for a few seconds... The majority have been amazed
after they successfully herded the plane a dozen miles back to the
airport and it is gratifying to see the light bulb in their head
suddenly light up as they begin to understand how the controls
actually work...
denny
Old May 29th 07, 10:53 PM posted to rec.aviation.piloting
Viperdoc[_3_]
The same is pretty much true for the F-16, at least from my less than 100
hours experience. It's usually feet on the floor, and the flight control
system works the various control surfaces..
Question: Standard rate turns, constant rate turns, and airspeed Robert Barker Piloting 5 April 15th 07 04:47 PM
Coordinated turns and the little ball Mxsmanic Piloting 51 October 11th 06 10:17 PM
Is rudder required for coordinated turns? Mxsmanic Piloting 41 September 24th 06 06:40 PM
DGs and Autopilots Andrew Gideon Products 11 April 14th 05 06:04 PM
Coordinated turning stall and spins Chris OCallaghan Soaring 20 November 18th 03 08:46 PM
