John Theune writes:
What makes you think they do not control the rudder? The absence of rudder movement, and the expense of providing servos for the rudder as well as the ailerones. It's possible that autopilots on transport aircraft do control the rudder, but the small ones for small aircraft apparently do not. |
Mxsmanic wrote in
: John Theune writes: What makes you think they do not control the rudder? The absence of rudder movement, and the expense of providing servos for the rudder as well as the ailerones. It's possible that autopilots on transport aircraft do control the rudder, but the small ones for small aircraft apparently do not. Uou're a fjukkwit and you know nothing about airplanes. bertie |
Question: Standard rate turns, constant rate turns, and airspeed | Robert Barker | Piloting | 5 | April 15th 07 04:47 PM |
Coordinated turns and the little ball | Mxsmanic | Piloting | 51 | October 11th 06 10:17 PM |
Is rudder required for coordinated turns? | Mxsmanic | Piloting | 41 | September 24th 06 06:40 PM |
DGs and Autopilots | Andrew Gideon | Products | 11 | April 14th 05 06:04 PM |
Coordinated turning stall and spins | Chris OCallaghan | Soaring | 20 | November 18th 03 08:46 PM |
