Coordinated turns without rudder, and autopilots
Old May 29th 07, 03:43 AM posted to rec.aviation.piloting
Mxsmanic
Default Coordinated turns without rudder, and autopilots
Paul kgyy writes:
As others have posted, most lightplane autopilots don't adjust the
rudder for adverse yaw when turning, so you do get a few seconds of
slightly uncoordinated flight. However at normal cruise speeds this
creates no hazard or discomfort.
So in theory I should be able to turn myself with ailerons only in the same
way, without the need to use the rudder to stay coordinated. What's the
secret? Each time I try to turn at the same rate that the AP manages, I have
If flying close to stall, the autopilot should be turned off even for
straight and level flight. If the airplane is on the verge of
stalling and starts to turn because of engine p-factor or any other
reason, the autopilot will attempt to correct with aileron. This may
actually induce stall on one wing, producing sudden wing drop and a
potential spin.
I have an aversion to stalls and I usually stay well away from them. The AP
will put the aircraft into a stall if airspeed is too low to maintain altitude
easily (I don't know if this is an artifact of simulation or just like the
real thing--I know my simulated autopilot doesn't have all the modes of the
real one).
Old May 29th 07, 06:14 AM posted to rec.aviation.piloting
Maxwell
"Mxsmanic" wrote in message
Paul kgyy writes:
same
have
potential spin.
AP
altitude
real one).
It's honestly just one of those things that do not hold true to form on PC
simulators. But turns do not always have to be perfectly coordinated.
Especially shallow ones initiated by wing levelers or low end autopilots.
Old May 29th 07, 07:37 PM posted to rec.aviation.piloting
Mxsmanic
Maxwell writes:
simulators.
Real autopilots on real aircraft do not necessarily have control over the real
rudders, and yet they execute real coordinated turns without those rudders.
How do they do it?
Why are they more coordinated when performed by the autopilot than when
performed by the pilot (without rudder)?
Autopilots often put the aircraft into a standard-rate turn, which isn't
exactly shallow, even if it isn't terribly steep.
Old May 29th 07, 09:02 PM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Mxsmanic wrote in
Maxwell writes:
on PC simulators.
the real rudders, and yet they execute real coordinated turns without
those rudders. How do they do it?
They don't fjukkwit.
Bertie
Old May 29th 07, 11:25 PM posted to rec.aviation.piloting
Maxwell
Maxwell writes:
PC
simulators.
real
rudders.
How do they do it?
They don't.
They are not.
No, it's not.
Old May 30th 07, 03:40 AM posted to rec.aviation.piloting
Paul kgyy
They also start the turn rather gradually, which minimizes the adverse
yaw.
If I hand-fly a standard rate turn, the rudder application only lasts
for maybe 3 seconds at the beginning and end of the turn.
Old May 30th 07, 06:07 AM posted to rec.aviation.piloting
Mxsmanic
Paul kgyy writes:
yaw.
They turn quickly considering that they are not touching the rudder. I want
to know how they do it.
Old May 30th 07, 06:20 AM posted to rec.aviation.piloting
Maxwell
Paul kgyy writes:
yaw.
want
They don't and you know it. You're just trolling.
Old May 30th 07, 01:07 PM posted to rec.aviation.piloting
Mxsmanic wrote in
Paul kgyy writes:
adverse yaw.
I want to know how they do it.
Tough ****, noone is going to tell you.
Unless you send me $300
Bertie
Old May 31st 07, 05:31 PM posted to rec.aviation.piloting
Erik
Bertie the Bunyip wrote:
Mxsmanic wrote in
Paul kgyy writes:
adverse yaw.
You're forgetting about the $1500 pain in the ass troll charge.
MX, that's in US dollars, none of that euro crap.
Question: Standard rate turns, constant rate turns, and airspeed Robert Barker Piloting 5 April 15th 07 04:47 PM
Coordinated turns and the little ball Mxsmanic Piloting 51 October 11th 06 10:17 PM
Is rudder required for coordinated turns? Mxsmanic Piloting 41 September 24th 06 06:40 PM
DGs and Autopilots Andrew Gideon Products 11 April 14th 05 06:04 PM
Coordinated turning stall and spins Chris OCallaghan Soaring 20 November 18th 03 08:46 PM
