Coordinated turns without rudder, and autopilots
Old May 29th 07, 07:14 PM posted to rec.aviation.piloting
Erik
Default Coordinated turns without rudder, and autopilots
Mxsmanic wrote:
Dan writes:
So where is this perfect airplane? I don't know about you, but I need
the rudder pedals to fly the aircraft.
But autopilots apparently do not, and that's what puzzles me.
Autopilots in simulators do not. Actual (that's opposite of virtual)
light aircraft need a rudder. If you turn the yoke, the plane will
bank, turn and eventually become coordinated, but for a while in
the interim, you'll be flying uncoordinated.
Some of these differences are why I disregard anything you may say,
correct or not, because you don't understand the basics of actual
flight regardless of how much of a master h4xor you are in the
simulator.
Old May 29th 07, 07:33 PM posted to rec.aviation.piloting
Mxsmanic
Erik writes:
Autopilots on light aircraft do not, and I'd like to know why.
Old May 29th 07, 08:52 PM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Mxsmanic wrote in
Erik writes:
Why, , youre never going to fly one anyway, fjukkwit.
bertie
Old May 29th 07, 09:42 PM posted to rec.aviation.piloting
Erik
Mxsmanic wrote:
Erik writes:
See, this is why.
Yes, and you're the resident expert why? Here, here's what you do.
At the main screen (at least on 2004) go down to settings, find the
realism settings button. I know that most of yours are all set to
the most unrealistic, but at least uncheck the autorudder box.
That box is checked by default. Then turn off your damn computer
and shut the **** up.
****wit.
Question: Standard rate turns, constant rate turns, and airspeed Robert Barker Piloting 5 April 15th 07 04:47 PM
Coordinated turns and the little ball Mxsmanic Piloting 51 October 11th 06 10:17 PM
Is rudder required for coordinated turns? Mxsmanic Piloting 41 September 24th 06 06:40 PM
DGs and Autopilots Andrew Gideon Products 11 April 14th 05 06:04 PM
Coordinated turning stall and spins Chris OCallaghan Soaring 20 November 18th 03 08:46 PM
