Paul kgyy writes:
As Maxwell observes, this may just be a simulator limitation. In actuality, a small amount of rudder should be applied when initiating and recovering from a turn, but once in a constant bank turn, the aircraft will normally be in coordinated flight without rudder application. But the autopilot has no control over the rudder, and yet the turn is coordinated. What is it doing to make this possible? |
Mxsmanic wrote in
: Paul kgyy writes: As Maxwell observes, this may just be a simulator limitation. In actuality, a small amount of rudder should be applied when initiating and recovering from a turn, but once in a constant bank turn, the aircraft will normally be in coordinated flight without rudder application. But the autopilot has no control over the rudder, and yet the turn is coordinated. What is it doing to make this possible? Your mental condition, apparently. Bertie |
![]() "Mxsmanic" wrote in message ... Paul kgyy writes: As Maxwell observes, this may just be a simulator limitation. In actuality, a small amount of rudder should be applied when initiating and recovering from a turn, but once in a constant bank turn, the aircraft will normally be in coordinated flight without rudder application. But the autopilot has no control over the rudder, and yet the turn is coordinated. What is it doing to make this possible? Nothing, the turns are not perfectly coordinated, they don't have to be. |
Maxwell writes:
Nothing, the turns are not perfectly coordinated, they don't have to be. The ball hardly moves. It moves a lot more if I attempt to roll into a turn myself without using the rudder. Why? |
![]() "Mxsmanic" wrote in message ... Maxwell writes: Nothing, the turns are not perfectly coordinated, they don't have to be. The ball hardly moves. It moves a lot more if I attempt to roll into a turn myself without using the rudder. Why? HELLO!!! YOU'RE FLYING A DESK YOU MORON!!!! |
Mxsmanic wrote in
: Maxwell writes: Nothing, the turns are not perfectly coordinated, they don't have to be. The ball hardly moves. There's no ball, there's no ruddrr. there's no airplane, fjukkwit. it's a computer.. Bertie |
Question: Standard rate turns, constant rate turns, and airspeed | Robert Barker | Piloting | 5 | April 15th 07 04:47 PM |
Coordinated turns and the little ball | Mxsmanic | Piloting | 51 | October 11th 06 10:17 PM |
Is rudder required for coordinated turns? | Mxsmanic | Piloting | 41 | September 24th 06 06:40 PM |
DGs and Autopilots | Andrew Gideon | Products | 11 | April 14th 05 06:04 PM |
Coordinated turning stall and spins | Chris OCallaghan | Soaring | 20 | November 18th 03 08:46 PM |
