Snowbird writes:
MSFS has for a long time been known to have a rather inaccurate flight model. MS tends to focus on the eye candy aspects of simulation. Which aspects are inaccurate? In my own experience, the stall/spin entry behavior is an easily explored area which quite clearly reveals the inadequacies of MSFS' flight modeling as compared to the real world. And it reflects of course as well in other areas of the flight envelope. A coordinated turn is neither a stall nor a spin. Years ago I flew extensively with a popular WWII networked combat airplane simulator (Warbirds). One of its claims to fame was that its flight dynamics model was based on actual real-time calculation of the motional differential equations that govern the flight dynamics of an aircraft. This in contrast to the "simplistic table-driven flight dynamics model of the mainstream PC simulators" probably referring to MSFS. Table-driven models are often more accurate. They don't have to calculate anything; they just look up the data taken from the real aircraft. They don't work in exceptional regimes of flight because the data for those in the tables are either absent or incorrect (as the real aircraft may have never been flown in those regimes to gather the data). But they work better than physics calculations in normal regimes of flight because they are guaranteed to match the real aircraft--after all, they are just reproducing what the real aircraft did in those cases. Physics models are better at handling all regimes of flight, since they calculate behavior on the fly. However, they rarely match the real aircraft precisely, because inaccuracies in the model are extremely difficult to correct completely enough to reproduce real-world behavior in flight, especially in real time. It's much easier to just measure the real aircraft and put that in a table. Additionally, if you want to certify a simulation, table-driven simulation is a lot easier to certify because it's very easy to make the simulation match a specific real-world aircraft. Marketing talk aside, I found that simulator MUCH more realistic in the flight dynamics modeling than MSFS. Especially at the edges of the flight envelope, where the differences between different airplanes were very significant. See above. I don't fly at the edges of the envelope--on that path lies danger. |
OK- one more time: I fly a real Baron with an autopilot, and I can
categorically tell you that the autopilot does not command a coordinated turn. However, the plane itself does not have a lot of adverse yaw, and even at a standard rate turn it only goes around half a ball into the turn on the TC. It is not noticeable by any seat of the pants criteria. This is the way a real Baron flies, and I have been in more than a few. If you believe that your game is more accurate than a real plane with a real pilot, you are more delusional than you appear. Your game lacks an accurate representation of the actual behavior of a real plane, as it also does for the Extra, where it is especially weak. Unless you've flown a real Baron (or Extra) as well as played MSFS, you have no basis of comparison. |
Viperdoc writes:
OK- one more time: I fly a real Baron with an autopilot, and I can categorically tell you that the autopilot does not command a coordinated turn. However, the plane itself does not have a lot of adverse yaw, and even at a standard rate turn it only goes around half a ball into the turn on the TC. It is not noticeable by any seat of the pants criteria. I'm in the Baron right now. With altitude and heading hold set, the ball moves about 3/4 out of its cage as the AP rolls into a turn, then settles at about 1/5 of the way out of the cage during the turn. It moves about 2/3 out of the cage as the aircraft rolls back to level flight. If I turn off the altitude hold, the excursions are a bit worse, and the aircraft loses 1200 feet or so in altitude during a 90-120-degree turn (from stable flight at 3000). This is the way a real Baron flies, and I have been in more than a few. See above. If you believe that your game is more accurate than a real plane with a real pilot, you are more delusional than you appear. If you believe the simulation is grossly inaccurate, you haven't tried the simulation. Unless you've flown a real Baron (or Extra) as well as played MSFS, you have no basis of comparison. My main handicap is that I don't know what the excursions of the ball represent in terms of magnitude. The ball is pegged to the right and left stops during even the gentlest turns on the taxiway, which implies that it must be very sensitive, but since I have no sensation in this sim I try to keep it centered, and that is not easy. I'll have to practice turns with no rudder to see if I can meet or exceed the performance of the AP. The simulated AP is a KFC 225, but not all AP modes are simulated (however, this may not be correlated with the accuracy of the modes that are simulated). |
"Mxsmanic" wrote in message
... ... What errors are there in the simulated model? Be specific. The autopilot makes coordinated turns even though it is not supposed to be connected to the rudder. Specific enough? -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
"Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in
news:ttOdnbCk1rJ_gsPbnZ2dneKdnZydnZ2d@wideopenwest .com: Specific enough? Wouldn't have thought so. Bertie |
Question: Standard rate turns, constant rate turns, and airspeed | Robert Barker | Piloting | 5 | April 15th 07 04:47 PM |
Coordinated turns and the little ball | Mxsmanic | Piloting | 51 | October 11th 06 10:17 PM |
Is rudder required for coordinated turns? | Mxsmanic | Piloting | 41 | September 24th 06 06:40 PM |
DGs and Autopilots | Andrew Gideon | Products | 11 | April 14th 05 06:04 PM |
Coordinated turning stall and spins | Chris OCallaghan | Soaring | 20 | November 18th 03 08:46 PM |
