Coordinated turns without rudder, and autopilots
Old May 30th 07, 01:38 AM posted to rec.aviation.piloting
Matt Whiting
Default Coordinated turns without rudder, and autopilots
Ron Natalie wrote:
Matt Whiting wrote:
Then you should know that the vertical stab can't prevent yaw, it can
only help eliminate yaw once it occurs as it can't provide any
restoring force until some degree of yaw occurs. A rudder an prevent
yaw from occurring in the first place. Fundamental difference here.
Nope. In most flight regimes if you displace the rudder you are
generating yaw not preventing it. What you are trying to wrap
your brain around is that you can use the rudder to accellerate
the responsiveness of the vertical stabs natural tendencies,
but by your own admission, in coordinated flight the stab is
streamlined.
No, I'm trying to get you to wrap you brain around the fact that the
rudder can act preemptively to prevent a departure from coordinated
flight. The vertical stab can not act preemptively. Fundamental
difference.
Matt
Question: Standard rate turns, constant rate turns, and airspeed Robert Barker Piloting 5 April 15th 07 04:47 PM
Coordinated turns and the little ball Mxsmanic Piloting 51 October 11th 06 10:17 PM
Is rudder required for coordinated turns? Mxsmanic Piloting 41 September 24th 06 06:40 PM
DGs and Autopilots Andrew Gideon Products 11 April 14th 05 06:04 PM
Coordinated turning stall and spins Chris OCallaghan Soaring 20 November 18th 03 08:46 PM
