Thanks - did you notice the thread titled Gasohol? That cites a document and
others have concurred that there are some states now where you can not buy Methanol free fuel. Back to the 100LL it seems...and think about all those mogas STCs that have just become invalid. -- Jim Carter Rogers, Arkansas "Gary" wrote in message oups.com... Most if not all Mogas today has Methanol in it as a replacement for the oxygenation agent MTBE. Gas pumps are not typically labled as to alcohol content. Both Petersen and EAA autogas STC's are not valid with autofuels containing alcohol. At a recent IA seminar held by the FAA we were reminded that even with an autogas STC if an airplane is operated using a fuel containing any alcohol that the airplane would be considered by them to be "unairworthy". Unairworthy to the FAA also means uninsured to most aviation underwriters. So you won't have a problem until you have a problem! Methanol is hydroscopic which means it holds water. This water will, over time, rust the steel parts in the fuel system. Gary Plewa On May 31, 6:42 am, Ron Natalie wrote: Rip wrote: Jim, sadly there is no mogas STC for the Navion, with any engine. Rip Yep, I even talked to Petersen about this (the EAA doesn't touch 6 cyls). All they knew was they had tested it and it had failed the vapor lock test. They couldn't remember which engine, fuel system, or model Navion they had used. |
Question about wings on Continental Airlines plane? | [email protected] | Piloting | 5 | December 13th 06 02:50 AM |
Continental 757 18R @ MCO | Glen in Orlando | Aviation Photos | 4 | November 30th 06 03:15 AM |
Continental O-200 ? | Stealth Pilot | Home Built | 48 | September 23rd 06 06:32 PM |
Continental 0-200 | Robert | Home Built | 0 | August 31st 05 11:57 AM |
Continental IO-360 question | Jeff P | Owning | 0 | September 21st 03 08:03 PM |
