Gasohol
Old June 3rd 07, 12:38 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Blueskies
Default Gasohol
"Jay Honeck" wrote in message ups.com...
You know I've been wondering: Does the Alka Seltzer trick really check to
see if alcohol is present? I'm no chemist, but I wonder if the Alka Seltzer
is just reacting with the water that most alcohols will attract from the
moisture in the air.
How about it? Any chemists in the group? If the mogas were blended with
alcohol with low water content, would the Alka Seltzer fizz at all? Maybe
the best test is still the "line on the beaker" test.
Well, we've been down this road before, back when the Alky test first
came on the scene. Some chemist here ended up concluding that the
test was valid, but I'm always open to hearing other thoughts on the
matter.
If the danged test DIDN'T work, that could ruin my whole day...
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Seems to me the best test would be to do the alka seltzer test right alongside the 'water to the line' test, using the
same fuel sample, preferable a known dirty gasoline sample...
Old June 3rd 07, 02:55 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Peter Dohm
Default Gasohol
"Blueskies" wrote in message
et...
to
Seltzer
with
Maybe
matter.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Two of the more knowledgeable contributors have stated that the Alka Seltzer
reacts with the water.
Logically, one could split a fuel sample into two parts and test both.
Then, if the fuel passes the AlkaSeltzer test and fails the "line on the
beaker" test; then Clare and Bob will have been proved correct and we will
have also gained a means to determine that fuel has alcohol added, but has
not absorbed moisture.
However, if the Alka Seltzer fizzes and the combined water and alcohol rises
above the "line on the beaker"; then the fuel will have failed both tests
and nothing at all will have been proved--because, as far as I know, the
"line on the beaker" does not seperately determine the amounts of water and
alcohol in the fuel sample.
Really, the only way that I know to correctly "do the science" is to
purchase a small amount (perhaps a liter) of anhydrous ethanol from a
medical supply and perform a series of tests on a variety of
samples--including samples of known pure and dry avgas and mogas. For the
moment, I am unwilling to undertake the project, and also I believe that
Clare and Bob are correct.
Peter
Old June 7th 07, 03:45 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Dave[_5_]
Default Gasohol
matter.
Just to satisfy my curiosity, I did the Alka Seltzer test on a sample
of Regular Unleaded (87 Octane) - the stuff I put in my lawn mowers.
No fizz. I buy it at
the pumps of a local supermarket chain in North Carolina. Dunno where
the State stands on Gasohol, but I don't see any Alcohol Notification
Stickers there (the pumps at some other local gas stations have
stickers stating that the gas MAY contain alcohol)
David Johnson
Old June 7th 07, 04:29 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Morgans[_2_]
Default Gasohol
Do you live in a county that has required emissions control testing for
cars? They have the red and white stripe inspection stickers.
I ask, because it is in these counties that are required to add an
oxygenator to the gas in the summer months. That is most likely alcohol.
I don't know when the addition to the fuel begins or ends. I would have to
say right about.......NOW ! ! !
When did you purchase said tested gas?
Jim in NC
Old June 7th 07, 10:09 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Blueskies
Default Gasohol
"Dave" wrote in message oups.com...
matter.
David Johnson
There is no requirement for any gas station nationwide to put any notification on their pumps. Only some very few states
have tried to add the notification.
Try the 'water to the line' test when you have a chance...
Old June 2nd 07, 02:52 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
clare at snyder.on.ca
Default Gasohol
On Fri, 1 Jun 2007 23:01:22 -0700, "J. Severyn"
"Orval Fairbairn" wrote in message
news snip
I tried the Alka Seltzer trick on some denatured alcohol -- no result.
It did not fizz!
Regards,
John Severyn
KLVK (all mogas has alky in my area, making my STC no good at all)
Seltzer reacts with water.
Posted via a free Usenet account from http://www.teranews.com
Gasohol Blueskies Piloting 240 July 6th 07 12:42 AM
Gasohol Blueskies Owning 233 June 30th 07 03:50 AM
How scary is gasohol? Charles Talleyrand Owning 27 March 1st 04 11:39 AM
