Coordinated turns without rudder, and autopilots
Old June 1st 07, 05:37 AM posted to rec.aviation.piloting
Mxsmanic
Default Coordinated turns without rudder, and autopilots
Bob Crawford writes:
Table driven models are only "perfect" at the (often very few) points
in the table (and even there depends upon the accuracy of the
measurements). Elsewhere they too are only approximations, the
accuracy of which depends upon how well the real world contour matches
the interpolation method chosen.
They can be made much more accurate than theoretical models, and they are
provably accurate with respect to the real aircraft at demonstrable points,
which is useful for certification.
Question: Standard rate turns, constant rate turns, and airspeed Robert Barker Piloting 5 April 15th 07 04:47 PM
Coordinated turns and the little ball Mxsmanic Piloting 51 October 11th 06 10:17 PM
Is rudder required for coordinated turns? Mxsmanic Piloting 41 September 24th 06 06:40 PM
DGs and Autopilots Andrew Gideon Products 11 April 14th 05 06:04 PM
Coordinated turning stall and spins Chris OCallaghan Soaring 20 November 18th 03 08:46 PM
