The Revolution Will Not Be Televised wrote:
On Mon, 08 Sep 2003 05:47:33 GMT, Guy Alcala wrote: [welcome back Peter, with your smoking slide-rule] The big deal with the Mk V, and volume behind the cockpit, is that hteat's where the radios live. Going with a smaller/lighter set would allow something like teh Mk IX's 29 Imperial Gallon tank. Not sure what you mean here, as the Mk. VCs were given a 29 Imp. Gal. ferry tank for the Gib-Malta ferry flights. The later Mk. IX/XVI had 66 Imp. gal. rear tanks. The standard fuselage Mk IX/XVI got a 75 Imperial gallon rear fuselage tank, with tear-drop canopy versions with the cut-down fuselage getting 66 gallons. Right. My thinking was for the 29 gallon Gibraltar ferry rear tank, or something pressurised/self-sealing with a similar capacity in the LR Vc, with additional wing tankage for the LR Vc or LR VIII & IX coming from the outboard MG position's, e.g. using the E-wing armament Probably not an option, as we'd need the limited number of .50 cals for flexible nose guns in the Halifax IIIs, if the B-24 deal doesn't come off. or even 2 x Hispanos with 2 x .303 MG's in the inboard cannon position available in the C wing, while stuffing a further 10 gallons or so of fuel in the outboard MG positions, as Pete has pointed out. This would be additional to the Mk VII/VIII wing tanks with their (conservative) 25 gallon capacity which were positioned further inboard of the first cannon mounting. Total here would be for something like 35 gallons in the wings additional to the 85 gallon conventional tankage, 29 gallon rear fuselage tankage and external drop tanks of up to 90 gallons capacity. Seems like it would be a lot easier to boost the forward fuselage capacity of the Mk. V/IX up to 96 gallons by swapping in bigger tanks (we know there's room there), before you add all those other tanks and the associated plumbing. I agree you'd still want the L.E tanks, but let's do the easiest stuff first. The extra 11 gallons in the enlarged forward tanks buys perhaps 10 minutes of cruise coming home: let's be _real_ conservative and call it 30 miles. Then we'll also need to enlarge the oil tank at some point. The outboard tanks you describe are so small that I wonder if they're worth the weight of all the plumbing, plus the extra vulnerability (remember that these tanks feed into the main tanks after room has been made in the latter, so they won't be used in combat - no one's going to transfer fuel while they're fighting). Guy |
Guy Alcala wrote:
The Revolution Will Not Be Televised wrote: On Mon, 08 Sep 2003 05:47:33 GMT, Guy Alcala wrote: snip or even 2 x Hispanos with 2 x .303 MG's in the inboard cannon position available in the C wing, while stuffing a further 10 gallons or so of fuel in the outboard MG positions, as Pete has pointed out. This would be additional to the Mk VII/VIII wing tanks with their (conservative) 25 gallon capacity which were positioned further inboard of the first cannon mounting. Total here would be for something like 35 gallons in the wings additional to the 85 gallon conventional tankage, 29 gallon rear fuselage tankage and external drop tanks of up to 90 gallons capacity. Seems like it would be a lot easier to boost the forward fuselage capacity of the Mk. V/IX up to 96 gallons by swapping in bigger tanks (we know there's room there), before you add all those other tanks and the associated plumbing. I agree you'd still want the L.E tanks, but let's do the easiest stuff first. The extra 11 gallons in the enlarged forward tanks buys perhaps 10 minutes of cruise coming home: let's be _real_ conservative and call it 30 miles. Then we'll also need to enlarge the oil tank at some point. The outboard tanks you describe are so small that I wonder if they're worth the weight of all the plumbing, plus the extra vulnerability (remember that these tanks feed into the main tanks after room has been made in the latter, so they won't be used in combat - no one's going to transfer fuel while they're fighting). Thinking about it further, I don't think the outboard tanks would pass muster. Where would you route the fuel piping, through the gun bays? I'd think that would be absolutely verboten. It makes more sense to try and enlarge the wing L.E. tanks, by not using the inboard cannon station and move the cannon out one station. Delete the O/B MG on each side if necessary, as weight/moment compensation. We might also want to consider developing a drop tank for Mk. VIIIs/IX with VIII tankage to perhaps 125 Imp. Gallons, roughly the internal capacity, just to boost the endurance a bit. We should still be within MTOW limits with the armament installed, while use of the 170 gal. tanks puts the a/c over gross with armament removed. Regardless, it's unlikely we'll ever be able to get a Spit fighter to Berlin and back from the UK. The PR. XI could do it with 216 Imp. Gal. internal (132 in the leading edges) plus a 90 gal. drop tank, but an armed a/c just doesn't have the room for all the fuel. But no matter, by the time we're ready to go there, the RAF will either have its own Mustangs, or be on the continent. Guy |
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 20 | August 27th 03 09:14 AM |
