![]() an easy way to have a line freeze and turn the plane into a glider. Then why don't cars have line freezing trouble with E-10 gas? Here in Minnesota, gas line freezeups have essentially disappeared because of the mandated E-10. It is the only good thing about gasahpol though........... I think a major reason not to use E-10 in certificated aircraft is the ~5% power reduction. |
On Jun 3, 10:50 pm, nrp wrote:
an easy way to have a line freeze and turn the plane into a glider. Then why don't cars have line freezing trouble with E-10 gas? Here in Minnesota, gas line freezeups have essentially disappeared because of the mandated E-10. It is the only good thing about gasahpol though........... I think a major reason not to use E-10 in certificated aircraft is the ~5% power reduction. Alcohol is an emulsifier that keeps water mixed with gasoline. It is also an antifreeze that supresses the freezing temperature of water. If you have a car that has ice in the fuel line, adding alcohol will melt it. -- FF |
On Jun 23, 3:12 am, clare at snyder.on.ca wrote:
On Fri, 22 Jun 2007 18:46:05 -0700, wrote: On Jun 3, 10:50 pm, nrp wrote: an easy way to have a line freeze and turn the plane into a glider. Then why don't cars have line freezing trouble with E-10 gas? Here in Minnesota, gas line freezeups have essentially disappeared because of the mandated E-10. It is the only good thing about gasahpol though........... I think a major reason not to use E-10 in certificated aircraft is the ~5% power reduction. Alcohol is an emulsifier that keeps water mixed with gasoline. It is also an antifreeze that supresses the freezing temperature of water. If you have a car that has ice in the fuel line, adding alcohol will melt it. And adding a bit more water makes the water and alky drop out od suspension. Called Phase Separation. It's temperature sensitive, so in a plane at ground level you may still have gasahol, but at 4000 feet, you are about 16 degrees F. colder - and that may be enough to trip the phase separation. Bad Ju-Ju when the engine gets a gulp of watered down hooch when it's expecting gasoline. On 2 stroke engines (ultralights, snowmobiles etc) when this happens the engine not only looses fuel, but it looses lubrication too, because the separated hooch has no oil in it. It's at the bottom of the tank, where the pickup is, so pistons are often destroyed before the driver/pilot even knows he has a problem. The alcohol will also produce a greater temperature drop in when it evaporates in the carburetor, increasing the danger of carb ice, something that is seldom a problem in cars, especially those with fuel injection.... -- FF |
I ran out of gas twice with my latest vehicle. I had it before the gasohol
change and I knew where it ran out because I intentionally ran it out while I was carrying gas for the plane. Since gasohol, I've run out twice well above the empty mark set before. Had to shake the car some to get it going when I put gas in, too. mike "Bryan Martin" wrote in message ... With gasohol, the gas stations no longer have to bother draining out the accumulated water from their tanks. The small amount of water that condenses out in the tanks simply dissolves into the next load of gasohol that gets poured into the tank and you pump a little bit of it into your car every time you fill up. Of course, if you get too much water in the gas, it settles out to the bottom of the tank and takes all the alcohol with it. You end up with a mixture at the bottom that won't burn worth a damn and the rest of the gasoline with a much reduced octane rating. |
Gasohol | Blueskies | Piloting | 240 | July 6th 07 12:42 AM |
Gasohol | Blueskies | Owning | 233 | June 30th 07 03:50 AM |
How scary is gasohol? | Charles Talleyrand | Owning | 27 | March 1st 04 11:39 AM |
