![]() "SS2MO" wrote in message oups.com... On May 30, 7:13 pm, "Blueskies" wrote: Is it true that there is no longer any requirement to label gasoline contaminated with alcohol? Good article hehttp://motorcycleinfo.calsci.com/Gasoline.html I just did the add water to gas test on a couple of local gas sources and all contain alcohol, and none of the pumps said anything about it. The feds just dropped the requirement to label the pumps and we all missed it? Jay, where do you fill the grape from and how do you know there is no evil alcohol in it? When MTBE was outlawed, the only feasable alternative to add oxygen to gasoline was alcohol. This is mandated in ceartin parts of the country - mostly the east and west coasts plus mant of the major cities. Many states have followed suit and now require 5 or 10% alcohol to be add to auto gas. Some states require that the retail pumps lable that the gasoline contains alcohol - some states do not. Currently retailers can save money by adding alcohol to the gasoline because the alcohol is less expensive than gasoline, so they can blen it in and sell it to you as auto gasoline - you may not know it. Any percentage of alcohol in the gasoline will void your auto gas STC. There are many pushing for a national requirement for alcohol to be added to auto gas. Old news... Current news, the feds passed the law in 2005 that all auto fuel will contain alcohol. Non alcohol auto gas will be available for FBO's to purchase and sell as auto gas for aviation, but anyone buying auto gas at a retial outlet and taking it to the airport in 5 gallon containers will need to check it for alcohol. EAA has a method on line to tell you how to check it. I recently did a presentation on auto gas with alcoho for an aviation group, added 10% alcohol to pure 87 octane auto gas - then some samples I added water - then lowered the temps on all samples to below freezing. First thing was that the alcohol would not stay mixed with the auto gas - it would seperate out. Second thing is that alcohol absorbs water - so you could not see the water in the alcohol/auto gas mixture, but when the temp was lowered to below freezing the water froze and ice settled out to the bottom. Is the so called cold weather auto fuel minus alcohol? I don't think so... All said - I will not be using auto gas in my plane - it looked like an easy way to have a line freeze and turn the plane into a glider. Just gotta be sure there is no alky in there... |
Gasohol | Blueskies | Piloting | 240 | July 6th 07 12:42 AM |
Gasohol | Blueskies | Owning | 233 | June 30th 07 03:50 AM |
How scary is gasohol? | Charles Talleyrand | Owning | 27 | March 1st 04 11:39 AM |
