Darrel Toepfer wrote:
Ron Hardin wrote: Of course, the exhaust blowing out the front turns the turbine backwards, and the exhaust blowing out the back turns it forwards. You're where you started, in explaining it. Doubtful... The starter motor spins it in a set direction. You'd have to reverse the polarity, if electrically driven... The only fear is that of a "hot start" which has already be explained. Or perhaps if you had a massive tailwind and no means of turning the plane into the wind for startup... That the turbine is spinning doesn't matter to the objection. The exhaust going to the rear spins it up, the exhaust going to the front slows it down. Net effect, zero. How does the exhaust keep it spinning? -- Ron Hardin On the internet, nobody knows you're a jerk. |
On Wed, 06 Jun 2007 11:35:55 GMT, Ron Hardin
wrote: ... That the turbine is spinning doesn't matter to the objection. The exhaust going to the rear spins it up, the exhaust going to the front slows it down. Net effect, zero. How does the exhaust keep it spinning? The compressor in front provides a wall of air as dense as 6 times standard pressure - so the expanding hot air behind it finds it energetically advantageous to go backwards, which reinforces the wall of air Brian Whatcott Altus OK |
Brian Whatcott wrote:
On Wed, 06 Jun 2007 11:35:55 GMT, Ron Hardin wrote: .. That the turbine is spinning doesn't matter to the objection. The exhaust going to the rear spins it up, the exhaust going to the front slows it down. Net effect, zero. How does the exhaust keep it spinning? The compressor in front provides a wall of air as dense as 6 times standard pressure - so the expanding hot air behind it finds it energetically advantageous to go backwards, which reinforces the wall of air Brian Whatcott Altus OK But that back pressure slows the turbine, just as surely as going through the blades backwards would. Equivalently, the compressor is doing more work the more you ignite the fuel. What keeps the turbine from slowing to a stop and then everything just blowing out both front and back? -- Ron Hardin On the internet, nobody knows you're a jerk. |
On Wed, 06 Jun 2007 13:19:36 GMT, Ron Hardin
wrote: Brian Whatcott wrote: The compressor in front provides a wall of air as dense as 6 times standard pressure - so the expanding hot air behind it finds it energetically advantageous to go backwards, which reinforces the wall of air Brian Whatcott Altus OK But that back pressure slows the turbine, just as surely as going through the blades backwards would. Equivalently, the compressor is doing more work the more you ignite the fuel. What keeps the turbine from slowing to a stop and then everything just blowing out both front and back? If I arrange to share the motive power between compressing input air, and accelerating exhaust air, the compressor is a load. and accelerating the exhaust is a load. The compressor does not normally stop if I supply energy as fuel. And the exhaust does not normally stop if I keep supplying fuel. Brian Whatcott Altus OK |
But that back pressure slows the turbine, just as surely as going through the blades backwards would. Equivalently, the compressor is doing more work the more you ignite the fuel. What keeps the turbine from slowing to a stop and then everything just blowing out both front and back? If I arrange to share the motive power between compressing input air, and accelerating exhaust air, the compressor is a load. and accelerating the exhaust is a load. The compressor does not normally stop if I supply energy as fuel. And the exhaust does not normally stop if I keep supplying fuel. The question is, though, why the combustion products don't just blow out both ends. _All_ the turbine blades are compressors, from the point of view of the gasses. -- Ron Hardin On the internet, nobody knows you're a jerk. |
On Thu, 07 Jun 2007 10:26:40 GMT, Ron Hardin
wrote: Brian Whatcott wrote: But that back pressure slows the turbine, just as surely as going through the blades backwards would. Equivalently, the compressor is doing more work the more you ignite the fuel. What keeps the turbine from slowing to a stop and then everything just blowing out both front and back? If I arrange to share the motive power between compressing input air, and accelerating exhaust air, the compressor is a load. and accelerating the exhaust is a load. The compressor does not normally stop if I supply energy as fuel. And the exhaust does not normally stop if I keep supplying fuel. The question is, though, why the combustion products don't just blow out both ends. _All_ the turbine blades are compressors, from the point of view of the gasses. Ah, I see Ron's issue - thinking that a compressor blade is functionally identical to a power turbine blade. Their curvatures are different with respect to the airflow, in fact. But I have spent too much time on this question Regards Brian W |
On Thu, 07 Jun 2007 10:26:40 GMT, Ron Hardin wrote: Brian Whatcott wrote: But that back pressure slows the turbine, just as surely as going through the blades backwards would. Equivalently, the compressor is doing more work the more you ignite the fuel. What keeps the turbine from slowing to a stop and then everything just blowing out both front and back? If I arrange to share the motive power between compressing input air, and accelerating exhaust air, the compressor is a load. and accelerating the exhaust is a load. The compressor does not normally stop if I supply energy as fuel. And the exhaust does not normally stop if I keep supplying fuel. The question is, though, why the combustion products don't just blow out both ends. _All_ the turbine blades are compressors, from the point of view of the gasses. Ah, I see Ron's issue - thinking that a compressor blade is functionally identical to a power turbine blade. Their curvatures are different with respect to the airflow, in fact. But I have spent too much time on this question Well, you might try the idea of leverage. Together with the fact that more gas goes out than comes in, to keep it from falling afoul of some law preventing perpetual motion machines. -- Ron Hardin On the internet, nobody knows you're a jerk. |
Aircraft Photo Books | Hal | Aviation Photos | 1 | May 30th 07 03:19 AM |
Aircraft Instrument Books? | jcarlyle | Soaring | 6 | November 28th 06 11:20 PM |
Aircraft Books | David R Townend | Home Built | 0 | July 6th 05 05:54 PM |
FA: -- WAR - AVIATION - AIRCRAFT CARRIERS - Box of Books | Ron Hartman | Aviation Marketplace | 0 | May 16th 05 03:18 AM |
FS Aircraft books and profiles | Ken Insch | Military Aviation | 1 | February 16th 04 07:59 AM |
