Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
[books] aircraft and engine
Old June 6th 07, 02:06 PM posted to rec.aviation.misc
Brian Whatcott
Default [books] aircraft and engine
On Wed, 06 Jun 2007 11:35:55 GMT, Ron Hardin
That the turbine is spinning doesn't matter to the objection. The exhaust going
to the rear spins it up, the exhaust going to the front slows it down. Net effect,
zero. How does the exhaust keep it spinning?
The compressor in front provides a wall of air as dense as 6 times
standard pressure - so the expanding hot air behind it finds it
energetically advantageous to go backwards, which reinforces the wall
of air
Brian Whatcott Altus OK
Old June 6th 07, 02:19 PM posted to rec.aviation.misc
Ron Hardin
of air
But that back pressure slows the turbine, just as surely as going through the blades
backwards would. Equivalently, the compressor is doing more work the more you ignite
the fuel. What keeps the turbine from slowing to a stop and then everything just
blowing out both front and back?
Ron Hardin
On the internet, nobody knows you're a jerk.
Old June 7th 07, 02:44 AM posted to rec.aviation.misc
Brian Whatcott
On Wed, 06 Jun 2007 13:19:36 GMT, Ron Hardin
of air
If I arrange to share the motive power between compressing input air,
and accelerating exhaust air, the compressor is a load. and
accelerating the exhaust is a load.
The compressor does not normally stop if I supply energy as fuel.
And the exhaust does not normally stop if I keep supplying fuel.
Old June 7th 07, 11:26 AM posted to rec.aviation.misc
Ron Hardin
The question is, though, why the combustion products don't just blow
out both ends. _All_ the turbine blades are compressors, from the point
of view of the gasses.
Ron Hardin
Old June 9th 07, 02:20 AM posted to rec.aviation.misc
Brian Whatcott
On Thu, 07 Jun 2007 10:26:40 GMT, Ron Hardin
Ah, I see Ron's issue - thinking that a compressor blade is
functionally identical to a power turbine blade. Their curvatures are
different with respect to the airflow, in fact.
But I have spent too much time on this question
Regards
Brian W
Old June 9th 07, 11:22 PM posted to rec.aviation.misc
Ron Hardin
Well, you might try the idea of leverage. Together with the fact that
more gas goes out than comes in, to keep it from falling afoul of
some law preventing perpetual motion machines.
Ron Hardin
Aircraft Photo Books Hal Aviation Photos 1 May 30th 07 03:19 AM
Aircraft Instrument Books? jcarlyle Soaring 6 November 28th 06 11:20 PM
Aircraft Books David R Townend Home Built 0 July 6th 05 05:54 PM
FA: -- WAR - AVIATION - AIRCRAFT CARRIERS - Box of Books Ron Hartman Aviation Marketplace 0 May 16th 05 03:18 AM
FS Aircraft books and profiles Ken Insch Military Aviation 1 February 16th 04 07:59 AM
