![]() Given the issue with alcohol, and the fact it is injected at the last stage - truck loading -- why aren't the STA owners such as EAA running campaigns to set up procedures for FBO's to procure untainted autogas? I can see the average truck loading terminal saying "we can't do that" until they get a memo saying that they can... -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
![]() "David Lesher" wrote in message ... Given the issue with alcohol, and the fact it is injected at the last stage - truck loading -- why aren't the STA owners such as EAA running campaigns to set up procedures for FBO's to procure untainted autogas? I can see the average truck loading terminal saying "we can't do that" until they get a memo saying that they can... -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 I really doubt that the terminal operators are so ignorant as to make that a problem. OTOH, there are some real problems for the FBO to overcome. One FBO owner, who I know, stopped selling gasolene several years ago--saying that he sometimes suspected that he lost more to evaporation than he pumped. That was certainly an exageration, but the point was well made that the sales did not justify the overhead--so now he only pumps Jet A, and gasolen powered aircraft must taxi elsewhere on the field for their fuel. For many, if not most, E-zero mogas would be an additional grade of fuel in a low volume market--and one which would require additional infrastructure, and also licensing, maintenance, and inspection of same. Obviously, many also operate rental aircraft which they would prefer to run on the most appropriate fuel. However, untill we are willing to guarantee them a reasonable volume of sales, I don't see how they can do it. (They to never bet on another man's game, but I will hazard a guess that an FBO needs to use a full devivery every other month to keep the product available--and at least twice that much to offer it at a competitive price. Any requirement for above ground storage may also increase the required volume.) Just my $0.02 Peter |
"Peter Dohm" writes:
Given the issue with alcohol, and the fact it is injected at the last stage - truck loading -- why aren't the STA owners such as EAA running campaigns to set up procedures for FBO's to procure untainted autogas? I really doubt that the terminal operators are so ignorant as to make that a problem. Ha! OTOH, there are some real problems for the FBO to overcome. One FBO owner, who I know, stopped selling gasolene several years ago--saying that he sometimes suspected that he lost more to evaporation than he pumped. That's a "selling autogas" problem; vice "finding un-Ethenol'ed autogas to sell" one. Agreed the first may be an issue.. BUT if you have a gaggle of STA'ed aircraft owners based there and you but not evry EatHerAndGetGas sells what they want and need.... -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
![]() "David Lesher" wrote in message ... "Peter Dohm" writes: Given the issue with alcohol, and the fact it is injected at the last stage - truck loading -- why aren't the STA owners such as EAA running campaigns to set up procedures for FBO's to procure untainted autogas? I really doubt that the terminal operators are so ignorant as to make that a problem. Ha! OTOH, there are some real problems for the FBO to overcome. One FBO owner, who I know, stopped selling gasolene several years ago--saying that he sometimes suspected that he lost more to evaporation than he pumped. That's a "selling autogas" problem; vice "finding un-Ethenol'ed autogas to sell" one. Agreed the first may be an issue.. BUT if you have a gaggle of STA'ed aircraft owners based there and you but not evry EatHerAndGetGas sells what they want and need.... If this special clean gas w/o alcohol is brought to the airport and kept there, doesn't it pretty much miss the point of the autogas STC? The whole idea was to be able to use normal autogas in these old low compression engines. |
"Blueskies" wrote: If this special clean gas w/o alcohol is brought to the airport and kept there, doesn't it pretty much miss the point of the autogas STC? The whole idea was to be able to use normal autogas in these old low compression engines. I thought one objective was to avoid using the 100LL in engines that were prune to lead fouling. -- Bob Noel (goodness, please trim replies!!!) |
Bob Noel writes:
If this special clean gas w/o alcohol is brought to the airport and kept there, doesn't it pretty much miss the point of the autogas STC? The whole idea was to be able to use normal autogas in these old low compression engines. I thought one objective was to avoid using the 100LL in engines that were prune to lead fouling. I thought that autogas was popular for several reasons: a) lead b) price ..... Gas bought by a FBO or club should be free of highway taxes but I suspect will instead incur aviation fuel taxes... -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
And if you thought lead was bad, those prunes REALLY gum up the works.
{;-) Jim -- "Work like you don't need the money, love like you've never been hurt, and dance like no one is watching." --Satchel Paige "Bob Noel" wrote in message ... I thought one objective was to avoid using the 100LL in engines that were prune to lead fouling. -- Bob Noel (goodness, please trim replies!!!) |
"RST Engineering" wrote: And if you thought lead was bad, those prunes REALLY gum up the works. aw ... nuts. :-( -- Bob Noel (goodness, please trim replies!!!) |
RST Engineering wrote:
And if you thought lead was bad, those prunes REALLY gum up the works. {;-) Jim Nope. He was talking about an old engine. It needs the prunes to keep the works from gumming up. I think most of the guys here know that. 8*) |
![]() I thought one objective was to avoid using the 100LL in engines that were prune to lead fouling. Yeah, we are into the summer time haul the grandkids routine where I burn oodles of avcrap because I am fueling faster than I can haul it and I am fueling at strange airports and some are really strange... Fat Albert's engines are already grumping at me about it... denny |
How scary is gasohol? | Charles Talleyrand | Owning | 27 | March 1st 04 11:39 AM |
