![]() "Denny" wrote in message oups.com... Your alka seltzer fizzes in water. It all by itself does not detect alcohol... And now for the rest of the story.... Step 1.... Got a clean urine sample cup - meaning unused... Using a sterile syringe I added 1.5cc of denatured alcohol (S-L-X brand) from a previously opened can, which will have an unknown % of absorbed water vapor, to the sample cup... Dropped in a small chunk of Alka Seltzer Original... Faint fizzing noted - you will have to be gimlet eyed to see it - but it does fizz... So, we can assume that "pure" alcohol ( a weak organic acid that always contains absorbed water) will 'fizz' Alka- Seltzer (contains bicarb of soda) if a bit faintly... Step 2.... Added 0.4 cc of warm weak tea ( it was handy) in 0.1cc increments... Fizzing rate essentially doubled, or a bit more, by the time I reached the 0.4 cc value... Easy to see... This is 26% imbibed water in the alcohol... Dunno what effect the pH of the tea had - I assume that word that it might enhance the fizzing from the bicarb... **** the intellectual reason for the tea besides it being in my hand is that water condensed on a metallic surface will be weakly acidic**** Step 3... Dumped the liquid from the cup and added a dash of tap water... Fizzing about tripled the rate from Step 2... Alka-Seltzer does not fizz explosively, like Arm&Hammer bicarbonate of soda would because it is buffered with citric acid... you will need to google on buffering and rate of reactions to understand some of that Unfortunately, for scientific rigor, I do not have any so called gasoline handy to test with... I have one minute to start seeing patients and I suspect they will not be impressed of I reek of the nasty crap they sell for gas these days... denny Thanks Denny, good post, esp. the "so called gasoline" comment... |
![]() "Blueskies" wrote in message t... "Denny" wrote in message oups.com... Your alka seltzer fizzes in water. It all by itself does not detect alcohol... And now for the rest of the story.... Step 1.... Got a clean urine sample cup - meaning unused... Using a sterile syringe I added 1.5cc of denatured alcohol (S-L-X brand) from a previously opened can, which will have an unknown % of absorbed water vapor, to the sample cup... Dropped in a small chunk of Alka Seltzer Original... Faint fizzing noted - you will have to be gimlet eyed to see it - but it does fizz... So, we can assume that "pure" alcohol ( a weak organic acid that always contains absorbed water) will 'fizz' Alka- Seltzer (contains bicarb of soda) if a bit faintly... Step 2.... Added 0.4 cc of warm weak tea ( it was handy) in 0.1cc increments... Fizzing rate essentially doubled, or a bit more, by the time I reached the 0.4 cc value... Easy to see... This is 26% imbibed water in the alcohol... Dunno what effect the pH of the tea had - I assume that word that it might enhance the fizzing from the bicarb... **** the intellectual reason for the tea besides it being in my hand is that water condensed on a metallic surface will be weakly acidic**** Step 3... Dumped the liquid from the cup and added a dash of tap water... Fizzing about tripled the rate from Step 2... Alka-Seltzer does not fizz explosively, like Arm&Hammer bicarbonate of soda would because it is buffered with citric acid... you will need to google on buffering and rate of reactions to understand some of that Unfortunately, for scientific rigor, I do not have any so called gasoline handy to test with... I have one minute to start seeing patients and I suspect they will not be impressed of I reek of the nasty crap they sell for gas these days... denny Thanks Denny, good post, esp. the "so called gasoline" comment... Went down to 'the shore' the other day and was able to check out the fuel pumps for the boats. The label on the pump said "100% Pure Gasoline". So, the implication here is that unless you see a label that says 100% pure, you are most likely getting gasohol. There needs to be a lawsuit or something to get the pumps labeled correctly... |
On Tue, 19 Jun 2007 21:30:38 GMT, "Blueskies"
wrote: "Blueskies" wrote in message t... "Denny" wrote in message oups.com... Your alka seltzer fizzes in water. It all by itself does not detect alcohol... And now for the rest of the story.... Step 1.... Got a clean urine sample cup - meaning unused... Using a sterile syringe I added 1.5cc of denatured alcohol (S-L-X brand) from a previously opened can, which will have an unknown % of absorbed water vapor, to the sample cup... Dropped in a small chunk of Alka Seltzer Original... Faint fizzing noted - you will have to be gimlet eyed to see it - but it does fizz... So, we can assume that "pure" alcohol ( a weak organic acid that always contains absorbed water) will 'fizz' Alka- Seltzer (contains bicarb of soda) if a bit faintly... Step 2.... Added 0.4 cc of warm weak tea ( it was handy) in 0.1cc increments... Fizzing rate essentially doubled, or a bit more, by the time I reached the 0.4 cc value... Easy to see... This is 26% imbibed water in the alcohol... Dunno what effect the pH of the tea had - I assume that word that it might enhance the fizzing from the bicarb... **** the intellectual reason for the tea besides it being in my hand is that water condensed on a metallic surface will be weakly acidic**** Step 3... Dumped the liquid from the cup and added a dash of tap water... Fizzing about tripled the rate from Step 2... Alka-Seltzer does not fizz explosively, like Arm&Hammer bicarbonate of soda would because it is buffered with citric acid... you will need to google on buffering and rate of reactions to understand some of that Unfortunately, for scientific rigor, I do not have any so called gasoline handy to test with... I have one minute to start seeing patients and I suspect they will not be impressed of I reek of the nasty crap they sell for gas these days... denny Thanks Denny, good post, esp. the "so called gasoline" comment... Went down to 'the shore' the other day and was able to check out the fuel pumps for the boats. The label on the pump said "100% Pure Gasoline". So, the implication here is that unless you see a label that says 100% pure, you are most likely getting gasohol. There needs to be a lawsuit or something to get the pumps labeled correctly... And you would sue who? In Michigan the pumps are required to have a lable. That lable states this fuel meets Michigan quality standard something or other. Nothing is said about Alcohol. Back in the 70s the labels stated This gas contains 10% Ethenol or something to that effect. Maybe Denny know why it was changed. |
![]() "Roger (K8RI)" wrote in message ... On Tue, 19 Jun 2007 21:30:38 GMT, "Blueskies" wrote: "Blueskies" wrote in message t... Went down to 'the shore' the other day and was able to check out the fuel pumps for the boats. The label on the pump said "100% Pure Gasoline". So, the implication here is that unless you see a label that says 100% pure, you are most likely getting gasohol. There needs to be a lawsuit or something to get the pumps labeled correctly... And you would sue who? In Michigan the pumps are required to have a lable. That lable states this fuel meets Michigan quality standard something or other. Nothing is said about Alcohol. Back in the 70s the labels stated This gas contains 10% Ethenol or something to that effect. Maybe Denny know why it was changed. Yes, that is my and a few others' point. It seems that any other product sold in the USA has some sort of truth in labeling requirement. The feds dropped the requirement to indicate ethanol in the gasoline a few years ago, and since that time the so-called gasoline is getting cut with higher and higher levels of ethanol. This is giving all of us lower and lower gas mileage per gallon burned. This would never happen with any other product sold in the USA. It is false marketing and should be challenged. Just happened to catch CSPAN this afternoon, and they were debating the so-called energy bill. Amazing the comments from both sides, and not one mention about how inefficient it is to make ethanol from corn! Believe it or not, the dems were arguing for marked based corn prices, while the republicans were trying to get price controls in place. Jay's Iowa senator is all for this corn subsidy stuff...simply baffling... |
Looks like they thought they were aligning with national standards. From
a timeline report by that state's Renewable Fuels Commission: "2003—Michigan State Legislature adopts and Governor Jennifer Granholm approves property tax incentives for the manufacturing and blending of biodiesel fuel. State legislation for mandatory labeling of 10% ethanol blends at Michigan service station gasoline pumps is changed to be consistent with national voluntary label standards..." It is interesting, as I'd thought the first gasahol was 15% ethanol, but there's no way to know whether local blends are ten, fifteen or some random percent. Makes it hard to test performance, doesn't it? Roger (K8RI) wrote: In Michigan the pumps are required to have a lable. That lable states this fuel meets Michigan quality standard something or other. Nothing is said about Alcohol. Back in the 70s the labels stated This gas contains 10% Ethenol or something to that effect. Maybe Denny know why it was changed. |
On Thu, 21 Jun 2007 18:29:52 -0700, Stella Starr
wrote: Looks like they thought they were aligning with national standards. From a timeline report by that state's Renewable Fuels Commission: "2003—Michigan State Legislature adopts and Governor Jennifer Granholm approves property tax incentives for the manufacturing and blending of biodiesel fuel. State legislation for mandatory labeling of 10% ethanol blends at Michigan service station gasoline pumps is changed to be consistent with national voluntary label standards..." It is interesting, as I'd thought the first gasahol was 15% ethanol, but there's no way to know whether local blends are ten, fifteen or some random percent. Makes it hard to test performance, doesn't it? In Michigan I think it's 10% and has been. Alcohol costs more than gas now days. The only reason it's priced so low is due to subsidies. Our early Gasohol was 10% here although back then I don't think there was a standard. OTOH back then it took nearly 1 1/2 to two gallons of fuel to make one gallon of ethanol. Roger (K8RI) wrote: In Michigan the pumps are required to have a lable. That lable states this fuel meets Michigan quality standard something or other. Nothing is said about Alcohol. Back in the 70s the labels stated This gas contains 10% Ethenol or something to that effect. Maybe Denny know why it was changed. |
![]() "Roger (K8RI)" wrote in message ... On Thu, 21 Jun 2007 18:29:52 -0700, Stella Starr wrote: Looks like they thought they were aligning with national standards. From a timeline report by that state's Renewable Fuels Commission: "2003-Michigan State Legislature adopts and Governor Jennifer Granholm approves property tax incentives for the manufacturing and blending of biodiesel fuel. State legislation for mandatory labeling of 10% ethanol blends at Michigan service station gasoline pumps is changed to be consistent with national voluntary label standards..." It is interesting, as I'd thought the first gasahol was 15% ethanol, but there's no way to know whether local blends are ten, fifteen or some random percent. Makes it hard to test performance, doesn't it? In Michigan I think it's 10% and has been. Alcohol costs more than gas now days. The only reason it's priced so low is due to subsidies. Our early Gasohol was 10% here although back then I don't think there was a standard. OTOH back then it took nearly 1 1/2 to two gallons of fuel to make one gallon of ethanol. Which then gets you 75% of the mileage of 'pure gasoline'. |
On Fri, 22 Jun 2007 11:04:03 GMT, "Blueskies"
wrote: "Roger (K8RI)" wrote in message ... On Thu, 21 Jun 2007 18:29:52 -0700, Stella Starr wrote: Looks like they thought they were aligning with national standards. From a timeline report by that state's Renewable Fuels Commission: "2003-Michigan State Legislature adopts and Governor Jennifer Granholm approves property tax incentives for the manufacturing and blending of biodiesel fuel. State legislation for mandatory labeling of 10% ethanol blends at Michigan service station gasoline pumps is changed to be consistent with national voluntary label standards..." It is interesting, as I'd thought the first gasahol was 15% ethanol, but there's no way to know whether local blends are ten, fifteen or some random percent. Makes it hard to test performance, doesn't it? In Michigan I think it's 10% and has been. Alcohol costs more than gas now days. The only reason it's priced so low is due to subsidies. Our early Gasohol was 10% here although back then I don't think there was a standard. OTOH back then it took nearly 1 1/2 to two gallons of fuel to make one gallon of ethanol. Which then gets you 75% of the mileage of 'pure gasoline'. Alcohol has 60% of the energy in gas. If 10% of the gas is Alcohol then you have only lost 6% (0.1 X 0.6 = 0.06), but as the Alcohol acts as an octane booster , *theoretically* they should be able to save a bit in the refining process to produce the lower octane gas that they boost back up with the alcohol. In the end though it's probably close to a wash as far as cost. Corn futures are already going up and look at the price of beef which is corn fed. Anything that uses corn is already on the way up which means it will be more (maybe much more) expensive to produce Ethanol using corn as will be any thing else that contains, or eats corn. Having been a farmer in a previous life and still owning the old family farm, as an educated guess I'd say the price of cord will easily double within the next couple of years, subsidies or no subsidies. It has the bonus of the *possibility* of eliminating some farm subsidies, but even without the subsidies the higher prices will still cost the tax payer more. In the long run we need to become independent from foreign oil as well as reducing emissions. Currently all ways of doing this cost more than that expensive foreign oil. I think I mentioned it before, but now they want to build a coal fired, 750 megawatt power station on the SE corner of Midland. (MI). http://www.ourmidland.com/site/index... =578054&rfi=8 (watch out for line wrap in some readers) Caution, lots of spin in article. :-)) This figures out to be about a mile long train of coal every other day. Even if they run 80% of the sulphur and 90% of the mercury recovered from the stack gas it still leaves a staggering amount of pollution. |
Gasohol | Blueskies | Piloting | 240 | July 6th 07 12:42 AM |
How scary is gasohol? | Charles Talleyrand | Owning | 27 | March 1st 04 11:39 AM |
