#71
Don Tuite wrote:
On Fri, 8 Jun 2007 19:33:28 -0600, "Jon Woellhaf" wrote: Matt Whiting asked ... "What are the software equivalent of Maxwell's equations?" Knuth A stretch. "GOTO Seen Harmful"? K&R? I don' think that dog's gonna hunt. You've gotta get down to Shannon, which I don't think answers the question wrt programming. If Swain had a contrary opinion, I'd listen to it. Don K&R isn't even close. Knuth is getting closer. I personally think that Nicklaus Wirth has come the closest to software engineering, but even he is more of a computer scientist than an engineer and much the same holds for Dijkstra. Matt |
#72
Bob Noel wrote:
In article , Matt Whiting wrote: I'll agree to disagree. I thought the same as you until I got my EE degree. There is simply no comparison. The Comp Sci degree was a walk in the part compared to EE. And EE's design based on mathematical and physical principles. your CS degree didn't include any numerical analysis? or discrete math? Yes, but that was not used in practice. I'm sure their are some folks who use math in practice, but I've come across VERY few. OTOH, EE, ME and other engineers use their math tools almost daily. The reality is that most software that is developed really is about process and programming, not engineering. Very few programmers can predict in advance exactly how fast their programs will execute. As a structural engineer, I can predict with pretty high accuracy how much my structure will deflect under various loads, what its frequency response will be to excitation from earthquakes or wind, etc. I've only extremely rarely seen anything even close to this in the software world. I almost never used math when working as a software developer. you never did any dsp code? Some of the software developers I'm working with now are doing a considerable amount of math (the exact nature of this application is sensitive so I won't go into details) No, I never had occasion to write DSP code. I worked in control systems and similar embedded systems for process and machine control. Matt |
#73
kontiki wrote:
Bob Noel wrote: you never did any dsp code? Some of the software developers I'm working with now are doing a considerable amount of math (the exact nature of this application is sensitive so I won't go into details) Exactly. It's obvious Matt has never done any serious design and development of bleeding edge software, so he just calls software engineers 'geeks' in order to marginalize the whole thing and make himself feel better. Personally I've met just as many geek hardware guys as software guys and I've worked in both environments. Do you have degrees in both computer science and engineering? If you do, then we can talk further. If you don't, then you don't know what you are talking about. I have degrees in both and they are vastly different. Matt |
#74
kontiki wrote:
Matt Whiting wrote: I'll agree to disagree. I thought the same as you until I got my EE degree. There is simply no comparison. The Comp Sci degree was a walk in the part compared to EE. And EE's design based on mathematical and physical principles. I almost never used math when working as a software developer. FYI I have an EE degree... my minor was in CS. In the areas I have worked I have actually found software more challenging than hardware (and I've done both). Just because you never used your CS knowledge to do much of anything complicated does not mean others don't. Finally... controlling systems in real time demands that you understand the engineering laws of electronics/physics because you design the software to perform the calculations/transforms or whatever else to produce to correct result... as well as perform tasks that check the resulting action to insure it is working then take corrective action if it doesn't. It takes an excellent electrical engineer to design these systems. You can marginalize it all you want. I absolutely agree that it takes an excellent electrical engineer to design these systems! That was my point. And electrical engineer is an engineer. A "software engineer" who has no engineering degree or background is not an engineer. Matt |
#75
Matt Whiting wrote:
Don Tuite wrote: On Fri, 8 Jun 2007 19:33:28 -0600, "Jon Woellhaf" wrote: Matt Whiting asked ... "What are the software equivalent of Maxwell's equations?" Knuth A stretch. "GOTO Seen Harmful"? K&R? I don' think that dog's gonna hunt. You've gotta get down to Shannon, which I don't think answers the question wrt programming. If Swain had a contrary opinion, I'd listen to it. Don K&R isn't even close. Knuth is getting closer. I personally think that Nicklaus Wirth has come the closest to software engineering, but even he is more of a computer scientist than an engineer and much the same holds for Dijkstra. Edgar Codd based his relational database model on predicate logic and set theory. I'd call it the rough equivalent of Maxwell's equations in the database world. Databases are pretty fundamental to a lot of applications, so I don't think it is that much of a stretch. |
#76
Jim Logajan wrote:
Matt Whiting wrote: Don Tuite wrote: On Fri, 8 Jun 2007 19:33:28 -0600, "Jon Woellhaf" wrote: Matt Whiting asked ... "What are the software equivalent of Maxwell's equations?" Knuth A stretch. "GOTO Seen Harmful"? K&R? I don' think that dog's gonna hunt. You've gotta get down to Shannon, which I don't think answers the question wrt programming. If Swain had a contrary opinion, I'd listen to it. Don K&R isn't even close. Knuth is getting closer. I personally think that Nicklaus Wirth has come the closest to software engineering, but even he is more of a computer scientist than an engineer and much the same holds for Dijkstra. Edgar Codd based his relational database model on predicate logic and set theory. I'd call it the rough equivalent of Maxwell's equations in the database world. Databases are pretty fundamental to a lot of applications, so I don't think it is that much of a stretch. Yes, I would tend to agree that the designer of the relational database was engineering software or at least coming very close. However, I disagree that the folks that use relational database and design applications for them are performing engineering. Unfortunately, what is called software engineering is seldom such. I'm sure there are a handful of people in the world, but not many compared to the more traditional engineering disciplines. Matt |
#77
Matt Whiting wrote:
Do you have degrees in both computer science and engineering? If you do, then we can talk further. If you don't, then you don't know what you are talking about. I have degrees in both and they are vastly different. Matt No, I don't have degrees in both, only Electrical Engineering. But I don't put down other engineering disciplines like you do. But hey... like I said.. if it makes you feel better go for it. ;^) |
#78
Matt Whiting wrote:
I absolutely agree that it takes an excellent electrical engineer to design these systems! That was my point. And electrical engineer is an engineer. A "software engineer" who has no engineering degree or background is not an engineer. Whatever... I've interviewed both CS and EE's. Some were excellent engineers, some were **** poor the rest were average and I never found those with an EE degree any smarter (ona average) that those with a CS degree. Attitude counts a lot more with me than what flavor engineering degree one has. But that's me. That's my story and I'm sticking with it. |
#79
![]() "kontiki" wrote in message ... Bob Noel wrote: you never did any dsp code? Some of the software developers I'm working with now are doing a considerable amount of math (the exact nature of this application is sensitive so I won't go into details) Exactly. It's obvious Matt has never done any serious design and development of bleeding edge software, How much of current (and past) software development is "bleeding edge"? so he just calls software engineers 'geeks' in order to marginalize the whole thing and make himself feel better. How many software "engineers" are actually mere "programmers"? I recall many teenagers doing "software". I even recall many such places being called "hobby shops". Personally I've met just as many geek hardware guys as software guys and I've worked in both environments. Im not a software person, but I would suspect, based on the handful of programs I wrote many years ago, that HARDWARE actaully requires/uses engineering principles that software misses, or, being more abstract, doesn't support. IOW, software is more and ART, whereas hardware and other tangibles, are true ENGINEERING projects. |
#80
kontiki wrote:
Matt Whiting wrote: Do you have degrees in both computer science and engineering? If you do, then we can talk further. If you don't, then you don't know what you are talking about. I have degrees in both and they are vastly different. Matt No, I don't have degrees in both, only Electrical Engineering. But I don't put down other engineering disciplines like you do. But hey... like I said.. if it makes you feel better go for it. ;^) I haven't put down any other engineering disciplines. Matt |
Fuel Cells? | Doug Haluza | Soaring | 14 | April 4th 06 04:32 AM |
Rubber fuel cells | Mike Rapoport | Owning | 15 | September 17th 05 12:54 PM |
Powered gliders = powered aircraft for 91.205 | Mark James Boyd | Soaring | 2 | December 12th 04 03:28 AM |
Diamond Aircraft on Hydrogen Fuel Cells | Raul Ruiz | Piloting | 1 | July 13th 03 11:27 PM |
