Head orientation in turns--how is it taught for aviation?
Old June 10th 07, 10:25 PM posted to rec.aviation.student,rec.aviation.piloting
Default Head orientation in turns--how is it taught for aviation?
Like many A/C, my single tin-can has this aerodynamic thing where if
you really lean into the bank, it prevents her from wanting to return
to wings level. Normally not a problem, but I now suffer from
disorientosis. It stems from 26 yrs on MSFS since v 1.0 in 1983, where
like even in versions today, the airplane will stay at any bank angle
once set. See, I coincidentally make only $647/month like O/P, and
can't afford what they get for joysticks even off eBay. I use keypad
control. Reality in simming is for wusses; just do what the sim
programmer expects.
It got really bad when I was earning my IFR ticket, because I had to
use rudder under the hood, to let the thing slew back toward that
displaced,vertical needle thingy on an ILS. On my Baron in MSFS over
many years, it became ingrained to just use asymmetric thrust to do
that, due to high rudder forces. To maintain GS, I also just used
pitch in my Baron, cause you can't twiddle thrust and do too many
things at once, like also constantly reminding self to keep body erect
despite the efficacy of leaning. It's also just so unintuitive to bank
to fly a straight course, especially when you can't feel a bank, and
they persistently teach you to ignore senses anyway, and you're like
in solid cloud when it's 200-1/2 for real.
Disorientosis really set in when I got glider time, and that bird had
this silly piece of yarn taped to the windscreen. You step on the
ball, but opposite the yarn. But nobody even an ATP can remember that
in solid cloud near ILS minimums.
I did overshoot a rwy once in my actual tin can post an ILS in actual
to mins, using high power to make rudder more effective and pitch for
GS, and thence FAA wanted this 809 ride, whatever. The FAA guy was so
impressed with my technique, crossed needles down to the MM, he asked
me if I had disorientosis. Naw, I lied, but do you fly MSFS? He said
every day; real neat sim. Actual flyin' just don't get no better than
that.
F--
Old June 11th 07, 02:19 AM posted to rec.aviation.student,rec.aviation.piloting
Viperdoc
So here we go again- he asks an apparently innocent question, and then
argues with all of the helpful responses from experienced and knowledgeable
pilots. It's getting boring, although MX bashing is developing into an art
form.
The fact is- flying largely relies on visual cues, not vestibular (applies
to VMC flying). Of course, all of the aviation physiologists at flight
surgeon school could be as irrational as MX, but not likely.
After flying many hours of acro, I've never wondered where my head was! It's
all about coming out on axis, the right attitude and altitude- and you put
your head and vision where it's needed to see that the other stuff is right,
nothing more.
IFR flying on the other hand, particularly at night, is another story. Then,
of course, the focus is on the instruments, and needing to ignore any other
cues.
My most memorable example of this was in the centrifuge at FS school. We
started from 1g sitting still, to around 1.5g, but with the bucket now at 90
degrees. It was a strong sensation of getting pitched forward and inward. At
least I was able to do the 9g ride without a GLOC, and this is what it's all
about.
Who cares where one looks when all he's doing is sitting in a chair, and his
only option is to look forward at the screen? It's kind of sad and pathetic,
although annoying as well.
Old June 11th 07, 02:25 AM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
"Viperdoc" wrote in
. net:
knowledgeable pilots. It's getting boring, although MX bashing is
developing into an art form.
(applies to VMC flying). Of course, all of the aviation physiologists
at flight surgeon school could be as irrational as MX, but not likely.
No,it isn't likely.
Seen a cross bred Cairn terrior that was as irrational as him, once
though. Crazy bitch.
Berti e
Question: Standard rate turns, constant rate turns, and airspeed Robert Barker Piloting 5 April 15th 07 04:47 PM
CAP Orientation Pilot? Robert M. Gary Piloting 7 August 3rd 05 02:22 AM
ADV: AVIATION T-SHIRTS & HEAD GEAR Kates Saloon and Knife Emporium General Aviation 0 December 30th 03 11:37 AM
ADV: GREAT AVIATION T-SHIRTS & HEAD GEAR Kates Saloon and Knife Emporium Aviation Marketplace 0 December 30th 03 11:36 AM
sounds of aviation navigation equipment as head on a scanner radio Dan Jacobson Instrument Flight Rules 5 December 4th 03 07:27 PM
