#61
Guy Alcala writes: I'll step with some trepidation into Pete's territory here as he explains this stuff far better than I do, but we've been keeping him busy doing calcs. The high aspect ratio wing provides good L/D ratios, increasing range performance as well as lift at low angles of attack. Here's how the a/c's aspect ratios stack up, from low to high: Stirling 6.72:1;. B-17, 7.58:1; Halifax (early) 7.81:1; Lancaster 8.02:1; Halifax (late) 8.51:1; B-24, 11.55:1; B-29, 11.48:1. As you can see, the B-24, designed a couple of years later than the British heavies and five years or so after the B-17, has a much higher aspect ratio wing, and the B-29 follows this practice. The wing area of the B-24 was considerably lower than the others, for low drag. Good altitude performance requires some combination of low wing-loading (high wing area for weight), engine thrust, and aspect ratio. While the B-24 had good engine power at altitude and a high aspect ratio, it also had high wing-loading compared to its contemporaries (not the B-29). It had better altitude performance than the British a/c because of its engine supercharging, not its wings. The B-17, with similar supercharging as the B-24 had a higher combat and service ceiling, because although it had a moderate aspect ratio wing it also had far lower wing-loading, and was able to fly slower. The B-24 cruised between 10-20 mph IAS faster than the B-17, but then it had to to be comfortable. The crews hated having to fly in company with B-17s. It's also easier to make lower aspect ratio wings of the same area stronger for the same weight, because the stresses can be spread over a longer (and thicker) root, which is one reason why a/c like the Stirling and B-17 have reputations for being able to take lots of wing damage and survive, and why a/c like the B-24 had opposite reps. However, the lower aspect ratio wing requires more area to get the same lift at the same AoA, increasing drag. A good job, Guy. If you don't mind, I'll dig a little deeper. into some details. The selection of Aspect Ratio and Wing Area are one of those tradeoff deals. A high Aspect Ratio means that the Induced Drag (Drag due to lift) is lower, for a given Lift Coefficient, and a low wing loading means that the Coefficient of Lift can be lower. This is really important at relatively low Equivalant Air Speeds, where the wing is working hard to keep the airplane flying. As the speed goes up, the Lift Coefficient decreases with the square of the speed, and the Induced Drag coefficient drops with square of the lift coefficient, so it decreases quite rapidly. Depending on what fraction of the total drag is Induced Drag, Aspect Ratio might not be all that important. I'll add the Stirling to the list, BTW. It should make an interesting contrast to the Lancaster in terms of how the tradeoffs fall. "Quest for Performance", L.K. Loftin, NASA History Office, 1985, available online, has a quite good explanation and analysis of the directions that designing high performance airplanes took through the first 80 or so years. The data tables list the following values for the various airplanes. Airplane: Aspect Ratio Wing Loading Cruise Speed L/Dmax B-17G 7.58 38.7 182 12.7 B-24J 11.55 53.4 215 12.9 B-29 11.50 69.1 253 16.8 Altitudes in cases would be 25,000', (Critical Altitude for the turbosupercharged engines, in each case) and all speeds are True Airspeed. Note that the B-24 and B-29 have almost identical Aspect Ratios, but the B-29 has a significantly higher wing loading. In general, this means that the B-29 will have more induced drag than the B-24. But it also cruises much faster. This is due to the lower total drag of the airplane due to the much more streamlined shape. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
#62
"Gord Beaman" ) writes: Mike Marron wrote: In other words, in your scenario above when the pilot increases the wing angle of incidence (7-deg's), he simultaneously adjusts his pitch and throttle settings as needed so as to remain stabilized on the glideslope. He just doesn't gaily "pop the AoI switch" and then react to what the airplane does...he thinks ahead and anticipates what the airplane will do and plans accordingly (e.g: "fly the plane" and pitch for airspeed power for altitude" etc.). Of course Mike, I understand that but I just broke it down so that it's easier for me to describe. I still don't see what this AoI control will do _other_ than give the pilot better downward visibility for landing and less drag for high speed operation. Is there some other aspect that I'm not seeing?...or is that it in a nutshell?... No, that's pretty much it, really. The wing, for purposes of lift, doesn't care particularly much what the attitude of teh fuselage is. The variable incidence wing on the F-8 allowed better visibility, and, as Guy said, better deck clearance, but it also allowed a shorter and stronger main landing gear. This was pretty important in the Crusader, as the loads on the gear as it trapped on the carriers of the day were pretty much pushing the limit of what would work. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
#63
"Gord Beaman" wrote in message ... Mike Marron wrote: In other words, in your scenario above when the pilot increases the wing angle of incidence (7-deg's), he simultaneously adjusts his pitch and throttle settings as needed so as to remain stabilized on the glideslope. He just doesn't gaily "pop the AoI switch" and then react to what the airplane does...he thinks ahead and anticipates what the airplane will do and plans accordingly (e.g: "fly the plane" and pitch for airspeed power for altitude" etc.). Of course Mike, I understand that but I just broke it down so that it's easier for me to describe. I still don't see what this AoI control will do _other_ than give the pilot better downward visibility for landing and less drag for high speed operation. Is there some other aspect that I'm not seeing?...or is that it in a nutshell?... a) Improved visibility over the nose, that's good. b) Greater clearance for the tail, that's good. c) Thrust line stays closer to horizontal. Good? Not sure... Any thing else? A & b would seem significant when making carrier landings. |
#64
In article , Guy Alcala
writes Dave Eadsforth wrote: snip To enlarge on my 'thick wing section' description, and working from memory of a book read long ago (which can be fatal), I recall that Davis conceived of a wing section that was based on a mathematically deformed circle, which he believed would give a more laminar flow. The thicker, 'teardrop-shaped' aerofoil section that resulted was also very useful structurally, given that he wanted to combine it with a high aspect ratio wing. Of course, any wing section inboard of the engines was going to have its airflow messed up considerably by a few minor essentials; like engine nacelles and de-icing boots etc etc, but the wing outboard of the engines may have performed as Davis believed it should during cruise. snip He was quite irritated that Consolidated didn't provide full covers for the main gear wheel wells, as he felt that defeated much of the drag reduction. Guy Some penny-pinching accountant at work perhaps? I was always mystified by the fact that the Spitfire didn't get full wheel-well covers until late in the war - they went to all that trouble gluing split peas all over the wing to optimise the placement of flush and round headed rivets and missed out on some thing that seems even more obvious (unless the drag from the wheel well really was inconsequential up to speeds of 400 mph or so - but that seems a bit counter instinctive). Cheers, Dave -- Dave Eadsforth |
#65
In article , Dave Eadsforth
writes Some penny-pinching accountant at work perhaps? I was always mystified by the fact that the Spitfire didn't get full wheel-well covers until late in the war - they went to all that trouble gluing split peas all over the wing to optimise the placement of flush and round headed rivets and missed out on some thing that seems even more obvious (unless the drag from the wheel well really was inconsequential up to speeds of 400 mph or so - but that seems a bit counter instinctive). I think originally it simplified the gear retraction 'hydraulics'. The first Spits had a hand pump to retract the gear, which required IIRC 27 pumps to fully retract it. I guess the full wheel well covers probably came along with the retractable tail wheel (possibly more important?) as well? -- John |
#66
Guy alcala wrote in message
Vader states that the Mk VIIIs had the 'C' wing, which implies that the Mk. IXs should have been able to be given LE tanks with little difficulty. I'm under the impression that the substantive changes to the Mk. VII/VIII were in the fuselage, and except for the tanks the wings were identical. Does anyone actually KNOW what the structural/internal changes were from the Mk.V/IX etc. to the Mk. VII/VIII? We all know about the tail wheel, but there had to be more than that. More information from Morgan and Shacklady, Spitfire weights, tare / take off / maximum VA 4,981 / 6,416 / 6,700 VB 5,065 / 6,622 / 6,700 VC (B wing) 5,081 / 6,785 / 7,300 VC (C Wing) 5,081 / 7,106.5 / 7,300 So if this is correct an extra 16 pounds was added, presumably to the fuselage, between the B and C versions. The book is also saying the VC version is not defined by the wings fitted, A or B or C wings, there is something else. The VC was a definite change, and able to carry 600 pounds more weight, presumably mainly by strengthening the undercarriage. The second production VC AA874 (Merlin 45) was weighed with A, then B then C wings, weights in pounds, CoG in inches wing / tare / tare CoG / all up weight / all up CoG A / 5,048 / 2.31 / 6,499 / 10.9 B / 5,048 / 2.31 / 6,737 / 10.9 C / 5,048 / 2.31 / 6,969 / 7.65 The mark VI, the pressure cabin version of the V, weights, tare 5,227 pounds, take off 6,797, maximum 6,850. AB450 was the prototype mark VII. It was a standard mark V with the following modifications, extended wing tips, 4 bladed propeller, retractable tail wheel, tail parachute fin guard, Merlin 61 with twin underwing radiators. The certificate of design general description was "This aeroplane is the prototype of the F Mk VII and F Mk VIII production Spitfires. Components of existing types with some modifications as used as indicated. Fuselage Spitfire Mk VI with the forward bay reinforced for Merlin 61 engine. Spitfire F Mk 20 tail unit, Spitfire Mk V elevator and rudder. Mainplane Spitfire F VC with spar flanges reinforced and lead ballast added in outer portions of the wings. Main chassis Spitfire F Mk VC leg and support structure. Spitfire F Mk VII production wheel and tyre equipment. Tail chassis, Spitfire F Mk VII production. Tare weight 5,201 pounds, maximum all up 8,000." Production VII tare weight 5,947 pounds or 5,887 pounds, depending on the hood used, take off 7,928 pounds, maximum 8,000 pounds. This indicates there probably was some fuselage strengthening between the prototype and production. Morgan and Shacklady state the mark VIII had the fuselage further strengthened over the mark VII, with the VIII weights as Tare 5,806 pounds, take off 7,779 pounds maximum 8,000 pounds. This looks like the VII without the extra wing tips and pressure cabin gear. Mark VIII 2 cannon and 4 browning, weights in pounds and CG in inches tare 5,861 and 0.2 landing 6,710 and 4.9, normal load 7,831 and 5.9, 30 gallon overload tank 8,131 and 6.4, 90 gallon overload tank 8,648 and 7.0. The figures are repeated for a 4 cannon version, interestingly tare weight is the same but all the other weights are around 200 pounds more, and the CG figures 0.1 to 0.3 greater. CG measured aft of datum. Since a pair of 20 mm cannons came in at around 200 pounds and 4 brownings at around 100 pounds this would seem to indicate tare weights are with the armament removed. F Mark IX tare 5,816 pounds, take off 7,295.5 pounds, maximum 7,500 pounds. After notes about overload tanks and bombs comes the entry "ballast 92.5". F IXE tare 5,816, take off 7,181.5, max 7,500. Perhaps a look at the PR IV which was the PR version of the V and normally had the cameras located behind the cockpit, they also carried radio, TR 1133 or 1143. Tankage front fuselage 48 upper 37 lower, same as mark V, 2 x wing leading edge tanks 66.5 gallons each, total 218 gallons. Oil tank 18 gallons in port wing between ribs 9 and 12. Tare weight 4,935 pounds, take off weight 7,148 pounds (W), 7,155 (X), 7,119.5 (Y). Max permissible 6,500 pounds (yes six thousand five hundred, a typo I presume). Tail ballast 17.5 pounds. W version 2 x F8 20 inch split vertical fanned between fuselage frames 13 and 15 inclined 10 degrees to the vertical and 20 degrees to each other. X version 2 F24 14 split vertical fanned and 1 F24 8 or 14 inch oblique mounted as W version with oblique over front F24. Inclined 8.5 degrees to the vertical and 17 degrees to each other. Y version, F52 36 inch vertical used only for bomb damage assessment, mounted between frames 13 and 14. PR VII, same as IV except, Tankage front fuselage 48 upper 37 lower, same as mark V, rear fuselage 29, total 114. Oil 5.8 gallon, in tank under engine. No radio. Weights tare 4,985 pounds, take off 6,584 pounds, maximum 6,590. CoG moved forward as fuel was consumed. Cameras, G installation, F24 5 or 8 inch vertical (front) and F24 8 or 14 inch vertical (rear) between frames 13 and 14 and 1 F24 8 or 14 inch oblique mounted above front camera. Some PR VIII had A wing armament. From Spitfire by Peter Moss, the initial hand converted PR versions from Spitfire I had a 29 gallon fuel tank under the pilot's seat and a 64 pound camera installation behind the cockpit, no radio though. It all worked because there was 32 pounds of removable ballast in the tail to compensate for the mark I moving to a heavier 3 bladed propeller. If the ballast figures are correct there is obviously some room for extra fuselage tanks, the maximum take off weight comes into play though. It appears 315 British gallons of 100 octane fuel comes to 2,240 pounds, for 80 Octane fuel 300 gallons weigh 2,240 pounds. Geoffrey Sinclair Remove the nb for email. |
#67
Geoffrey Sinclair wrote in message ...
The Stirling wingspan was 99 feet 1 inch versus the B-17 103 feet 9 inches, it was also the thickest wing, able to carry bombs in cells within the inner wing. three cells on each side capable of carrying 500 pound bombs at least. I should add the Halifax also had 3 cells in each wing for 500 pound bombs, from Halifax : an illustrated history of a classic World War 2 bomber by Kenneth A. Merrick. Geoffrey Sinclair Remove the nb for email. |
#68
(Peter Stickney) wrote:
[B-24 vs. B-29 wing specs snipped for brevity] But it also cruises much faster. This is due to the lower total drag of the airplane due to the much more streamlined shape. Not to mention the Superfort's extra *4,000* total horsepower and four humongous four-blade 17-ft. diameter props! -Mike Marron |
#69
"John Keeney" wrote:
"Gord Beaman" wrote: Mike Marron wrote: In other words, in your scenario above when the pilot increases the wing angle of incidence (7-deg's), he simultaneously adjusts his pitch and throttle settings as needed so as to remain stabilized on the glideslope. He just doesn't gaily "pop the AoI switch" and then react to what the airplane does...he thinks ahead and anticipates what the airplane will do and plans accordingly (e.g: "fly the plane" and pitch for airspeed power for altitude" etc.). Of course Mike, I understand that but I just broke it down so that it's easier for me to describe. I still don't see what this AoI control will do _other_ than give the pilot better downward visibility for landing and less drag for high speed operation. Is there some other aspect that I'm not seeing?...or is that it in a nutshell?... As I mentioned in my response to you (the important part that you snipped), besides just increasing the visibility, the variable incidence wing also enabled the sleek and very fast fighter to maintain the slower speeds required for carrier ops. In other words Gord, the variable incidence wasn't designed to give the F-8 "less drag for high speed operation," it was designed to give the F-8 MORE drag (as the result of more LIFT) for SLOW speed operation in order to land aboard carriers. Also, if you peddle back to that website that you posted depicting a close-up of the Crusader's wing in the raised position, you will clearly see how the raised portion of the wing assembly directly above the fuselage is flat as a sheet of plywood and protrudes right into the relative wind -- effectively functioning as a speed brake. a) Improved visibility over the nose, that's good. b) Greater clearance for the tail, that's good. c) Thrust line stays closer to horizontal. Good? Not sure... Any thing else? I could be wrong, but I don't see any reason why the thrust line staying closer to horizontal would be a "bad" thing. In the event of a waveoff the pilot simply has to light the burner and go around w/o making any drastic adjustments in angle of attack because the raised wing is already configured for takeoff. A & b would seem significant when making carrier landings. Agreed. Although the 20-30 kt. wind over the deck is laminar and smooth, the part curling down over the fantail is not which can cause a sudden increase in rate of sink at precisely the most inopportune time (e.g: ramp strike!) -Mike Marron |
#70
In article , Mike Marron
writes Not to mention the Superfort's extra *4,000* total horsepower and four humongous four-blade 17-ft. diameter props! That brings a comparison between the B-29 and Shackleton wings/engines into the equation I guess. -- John |
| Thread Tools | |
| Display Modes | |
| Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 20 | August 27th 03 10:14 AM |
