Head orientation in turns--how is it taught for aviation?
Old June 12th 07, 12:04 AM posted to rec.aviation.student,rec.aviation.piloting
Maxwell
Default Head orientation in turns--how is it taught for aviation?
"Erik" wrote in message
Mxsmanic wrote:
Erik writes:
3) Meet me in real life, I'll beat the living daylights out of
you just to make me feel better. Yep, violent, but who gives
a ****?
District attorneys do. You've established premeditation, for one thing.
It's
a really bad idea to threaten people in writing, especially in written
forms
that will be archived indefinitely and exposed to public view. It can
work
against you in ways you may not at all suspect.
Bull ****.
If you ever disappear the list of documented suspects will be so long, I
seriously doubt the authorities would even begin to look. You are clearly
the poster child for justifiable homicide.
  #142
Old June 12th 07, 12:38 AM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
"Maxwell" wrote in
news:2007061101084716807-dhenriques@rcncom...
Bertie is correct. Barrel Rolls are perhaps the most misquoted and
misunderstood maneuver done in an airplane.
Basically, you can do a barrel roll as loosely or as tight as the
airplane's flight envelope will allow. You can also enter a BR from
many different flight conditions involving many different g loadings.
The main thing to remember about barrel rolls is that they are a 3
dimensional maneuver through 3 dimensional space and that the common
denominator in a barrel roll regardless of the g used is that it will
remain POSITIVE all the way around. The one exception to this would
be after the pull and roll application, you can unload the airplane
over the top and drop the g to +1 if you like to loosen the roll
rate, but that g must be regained during the recovery.
Basically, you will be somewhere over +1g in the entry as you raise
the nose, then at some positive +g throughout the roll ranging from
as unloaded as you want to loosen up the airplane or as high a
positive g and tight a roll as the envelope will allow. As long as
the airplane transverses 3 dimensions through the roll, it's a barrel
roll. I've done them as loose as a 90 degree change of direction at
the top apex in a P51,the F8F, and several jets including the T38,
and as tight as a corkscrew in a Pitts S1Sl which was highly loaded
with +g and extremely tight.
Bob Hoover's rather famous Iced tea stunt in the Shrike is probably
responsible for much of the misconception about barrel rolls. He does
them fairly loose and with just enough positive g on the airplane to
keep the glass from spilling without stressing the airplane. The
"secret" to Bob's tea trick is simply his smoothness through the roll
as much as keeping positive g on the tea. It's really this smoothness
that makes this stunt possible, as although positive g will keep the
tea inside the glass. (You can actually POUR tea as you're rolling
the airplane but ONLY if you're as smooth as Hoover :-)
The reason smoothness is so necessary for the tea trick is that even
though you might have positive g on the airplane and in effect doing
a barrel roll, if you are not perfectly coordinated through the roll
(any excessive yaw for example) your tea will slide off the glare
shield laterally and you don't want that......not if you're Bob
Hoover anyway :-) So it's positive g for the roll, and smoothness and
perfect coordination for the tea stunt.
I'm not talking about Bob's tea trick. Obvoiusly, positive Gs and
coordination is the key there. And I'm not sure I understand or agree
with your post. But I think it might be possible we having a
terminology issue here with the definition of a barrel roll.
Nope. The thing is, you can`t do anything at all at one G except
straight and level flight.
Period, Endo fo story, finnito spaghettio. Nothing to do with
terminology or anything else. It's just a BS legend that has been
repeated so many times that it's dug it's own groove in the urban legend
record.
Bertie
  #143
Old June 12th 07, 12:41 AM posted to rec.aviation.piloting
"Maxwell" wrote in
news:2007061116042375249-dhenriques@rcncom...
On 2007-06-11 12:39:10 -0400, "Maxwell" said:
No. Barrel rolls do NOT go negative generally. If you went negative
you would change the roll arc and destroy the roll. You can unload to
0 g through the top however without destroying the roll arc, but if
you do, you have to reapply positive g almost immediately as you pass
through inverted to regain the roll arc. As I said, you can do a
barrel roll at any positive g; as tight or as little as the flight
envelope for the aircraft will allow up to 90 degrees of flight path
direction change at the roll apex.
Generally the roll profile will be the application of positive g
above +1 from the roll initiation (either from level flight or from a
slight dive offset to gain energy if needed) followed by coordinated
roll and back pressure into the roll arc maintaining positive g with
varying back pressure to maintain the roll arc through the roll and
through the recovery back to the entry heading.
You can NOT at any time during a barrel roll, allow the g to go
negative as doing so will instantly destroy the arc of the roll.
Dudley Henriques
No it won't, and yes you can.
Nope.
You';re wrong dude.
That's OK, you can go on being wrong. I don't have to fly with you.
Bertie
  #145
Old June 12th 07, 12:43 AM posted to rec.aviation.piloting
Mxsmanic wrote in
Maxwell writes:
A 1g barrel roll can be done, but the required trajectory of the
aircraft is not going to be one that is necessarily eye pleasing for
ground demonstration purposes.
Any maneuver that involves a change in altitude will involve forces
exceeding 1 G at some point.
Nope, wrong again fjukktard.
Bertie
  #149
Old June 12th 07, 12:50 AM posted to rec.aviation.piloting
Mxsmanic wrote in
Nomen Nescio writes:
By already being in a climb at "one altitude" and maintaining it
through "another".
At some point your vertical speed must change, and then your net
acceleration will change as well.
Wrong!
It's not!
It is constant for all practical purposes.
Nope.
If one G is defined as 32.2 ft/sec/sec, it can be done. I'll leave it
to you to figure out how.
It cannot be done, and you cannot demonstrate otherwise.
I could if you would get into an airplane,
But you wont.
Bertie
  #150
Old June 12th 07, 12:51 AM posted to rec.aviation.piloting
george wrote in news:1181596437.557910.199630
@a26g2000pre.googlegroups.com:
On Jun 12, 1:53 am, "ManhattanMan" wrote:
Bertie the Bunyip wrote:
I think he probably tried Viagra, but found it only made him
taller.
Boom! Head shot!
Or straight over the top :-)
You are awarded the kooks tail and both ears
Thenkew.
Bertie
Question: Standard rate turns, constant rate turns, and airspeed Robert Barker Piloting 5 April 15th 07 04:47 PM
CAP Orientation Pilot? Robert M. Gary Piloting 7 August 3rd 05 02:22 AM
ADV: AVIATION T-SHIRTS & HEAD GEAR Kates Saloon and Knife Emporium General Aviation 0 December 30th 03 11:37 AM
ADV: GREAT AVIATION T-SHIRTS & HEAD GEAR Kates Saloon and Knife Emporium Aviation Marketplace 0 December 30th 03 11:36 AM
sounds of aviation navigation equipment as head on a scanner radio Dan Jacobson Instrument Flight Rules 5 December 4th 03 07:27 PM
