Head orientation in turns--how is it taught for aviation?
Old June 12th 07, 04:27 AM posted to rec.aviation.piloting
Maxwell
Default Head orientation in turns--how is it taught for aviation?
.130...
Dudley's right, you're wrong,. You're twisting the argument to suit
yourself, changeing the language and rules as you go...
No I'm not.
Reference my post from this morning.
----- Original Message -----
Newsgroups: rec.aviation.piloting
Sent: Monday, June 11, 2007 11:39 AM
Subject: Head orientation in turns--how is it taught for aviation?
I'm not talking about Bob's tea trick. Obvoiusly, positive Gs and
coordination is the key there. And I'm not sure I understand or agree with
your post. But I think it might be possible we having a terminology issue
here with the definition of a barrel roll.
I fully admit barrel rolls as defined by most pilots require more than
"exactly 1g", and usually a little negative, depending on the desired
flight
path. Also, doing a near 1g roll as I mentioned, more than 1g will be
required to set up the manuver, and return to level flight afterwards. But
I
disagree that it one needs to deviate much from 1g to roll the wings of an
aircraft 360 degrees if flying an arc. Depending on the arc and corkscrew
of
your flight path, you can roll with very little if not no stress on the
aircraft.
Old June 12th 07, 04:37 AM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
"Maxwell" wrote in
.130...
No I'm not.
Yeah right..
Bertie
Old June 12th 07, 04:53 AM posted to rec.aviation.piloting
Maxwell
.130...
"Maxwell" wrote in
.130...
No I'm not.
Yeah right..
No, you mean yeah, correct.
Old June 12th 07, 05:11 AM posted to rec.aviation.piloting
"Maxwell" wrote in news:WMobi.97857$vE1.10405
@newsfe24.lga:
.130...
"Maxwell" wrote in
.130...
No I'm not.
Yeah right..
No, I meeant you're a fjukkwit in the same league as mxsmanic.
Bertie
Old June 12th 07, 12:51 PM posted to rec.aviation.piloting
Maxwell
.130...
@newsfe24.lga:
.130...
"Maxwell" wrote in
.130...
No I'm not.
Yeah right..
Gotcha!
Old June 12th 07, 03:46 PM posted to rec.aviation.piloting
"Maxwell" wrote in news:WMvbi.560843$2Q1.316920
@newsfe16.lga:
.130...
@newsfe24.lga:
.130...
"Maxwell" wrote in
.130...
suit
No I'm not.
Yeah right..
Gotcha!
No, you didn't.
Bertei
Question: Standard rate turns, constant rate turns, and airspeed Robert Barker Piloting 5 April 15th 07 04:47 PM
CAP Orientation Pilot? Robert M. Gary Piloting 7 August 3rd 05 02:22 AM
ADV: AVIATION T-SHIRTS & HEAD GEAR Kates Saloon and Knife Emporium General Aviation 0 December 30th 03 11:37 AM
ADV: GREAT AVIATION T-SHIRTS & HEAD GEAR Kates Saloon and Knife Emporium Aviation Marketplace 0 December 30th 03 11:36 AM
sounds of aviation navigation equipment as head on a scanner radio Dan Jacobson Instrument Flight Rules 5 December 4th 03 07:27 PM
