#111
Mxsmanic wrote in
: Robert M. Gary writes: Do you believe that a pilot at the top of a loop can experience possitive G's? Absolutely. You'll never ever do a loop fjukkwit. Bertie |
#112
That's the point you idiot- there is no change in direction during a
vertical roll. "Mxsmanic" wrote in message ... Viperdoc writes: Think about it- a roll on the vertical does not apply any g to the airplane. Any change in direction accelerates the airplane, and thus applies Gs to it. During a vertical roll there is no acceleration in the z or y axes. Any change in direction accelerates the airplane. |
#113
Got it. What happens to the g force acting on me as a pilot if I start
in straight and level, unaccelerated flight, and then I use down elevator and enter a descent? On Jun 13, 12:56 am, Mxsmanic wrote: writes: What happens to the g force acting on me as a pilot if I start in straight and level, unaccelerated flight, and then I initiate a coordinated turn? The net force increases, as it results from both that induced by gravity (which is constant) and that induced by your acceleration torwards the center of the turn. In a coordinated, level turn, the force vector will be normal to the airframe, and so you will have the impression that you are climbing initially; when you finish the turn you'll have the impression that you are descending briefly. This assumes that you keep your head level with the wings. |
#114
On Jun 13, 7:15 am, "Viperdoc" wrote:
That's the point you idiot- there is no change in direction during a vertical roll. Kinda like trying to run underwater, isn't it? Making the point, that is ![]() |
#115
#116
Viperdoc writes:
That's the point you idiot- there is no change in direction during a vertical roll. You cannot change the attitude, direction, altitude, etc., of the aircraft without changing its direction in some plane, and that requires acceleration. |
#117
Interesting. So if I enter a coordinated turn, the G force increases.
If I enter a descent, the G force decreases. What happens if I do both of these things simultaneously? On Jun 13, 2:31 pm, Mxsmanic wrote: writes: Got it. What happens to the g force acting on me as a pilot if I start in straight and level, unaccelerated flight, and then I use down elevator and enter a descent? As you descend, you are accelerated downward. This acceleration is subtracted from the constant acceleration imposed by gravity. If your acceleration downward is less than 1.0 G, you experience a diminished G force, unchanged in direction. If it is equal to 1.0 G (which would be quite a feat), you will experience no G force at all. If it is greater than 1.0 G (unlikely indeed), you'll feel a negative G force tending to lift you out of your seat. These changes persist only for as long as you are accelerating downward; once you are descending at a steady rate, you will again experience exactly 1.0 G. writes: What happens to the g force acting on me as a pilot if I start in straight and level, unaccelerated flight, and then I initiate a coordinated turn? The net force increases, as it results from both that induced by gravity (which is constant) and that induced by your acceleration torwards the center of the turn. In a coordinated, level turn, the force vector will be normal to the airframe, and so you will have the impression that you are climbing initially; when you finish the turn you'll have the impression that you are descending briefly. This assumes that you keep your head level with the wings. |
#118
oups.com... Interesting. So if I enter a coordinated turn, the G force increases. If I enter a descent, the G force decreases. What happens if I do both of these things simultaneously? Blue Screen of Death? |
#119
On Jun 14, 7:08 am, "El Maximo" wrote:
wrote in message oups.com... Interesting. So if I enter a coordinated turn, the G force increases. If I enter a descent, the G force decreases. What happens if I do both of these things simultaneously? Blue Screen of Death? ROTFL |
#120
Why?
mike "Mxsmanic" wrote in message ... If it is equal to 1.0 G (which would be quite a feat), |
Dispelling the Myth: Hillary Clinton and the Purple Heart | Otis Willie | Naval Aviation | 0 | February 21st 06 05:41 AM |
Impossible to ditch in a field (almost) | mindenpilot | Piloting | 29 | December 11th 04 11:45 PM |
bush: impossible to be AWOL (do vets give a sh!t) | B2431 | Military Aviation | 7 | September 8th 04 04:20 PM |
cheap, durable, homebuilt aircrafts- myth or truth? | -=:|SAJAN|:=- | Home Built | 27 | January 8th 04 09:05 AM |
The myth that won't die. | Roger Long | Piloting | 7 | December 19th 03 06:15 PM |
