Matt Whiting wrote:
wrote: You're right about a barrel roll, of course, I like that you can rotate the wings through 360 degrees and maintain 1 G. You could also, I think, start the 'roll' with an upward velocity component of 320 feet a second and end it level, but hardly at the same altitude (you'd be 1600 feet higher). An even more interesting question would be, is there an airplane that can fly this flight path? I think it would take massive control surfaces to be able to pull a G with the yoke. I'm not an aerobatic pilot, but pulling 1G with the elevator isn't hard on any airplane I've flown. Matt Actually Matt, all you need to do with most g meters is to "tweak" the stick with an instant of positive pitch pressure and release it. You will register over 1 g just doing that :-)) Dudley Henriques |
Dudley Henriques wrote:
Matt Whiting wrote: wrote: You're right about a barrel roll, of course, I like that you can rotate the wings through 360 degrees and maintain 1 G. You could also, I think, start the 'roll' with an upward velocity component of 320 feet a second and end it level, but hardly at the same altitude (you'd be 1600 feet higher). An even more interesting question would be, is there an airplane that can fly this flight path? I think it would take massive control surfaces to be able to pull a G with the yoke. I'm not an aerobatic pilot, but pulling 1G with the elevator isn't hard on any airplane I've flown. Matt Actually Matt, all you need to do with most g meters is to "tweak" the stick with an instant of positive pitch pressure and release it. You will register over 1 g just doing that :-)) Dudley Henriques Unfortunately, I've never had the pleasure of flying a g meter equipped airplane! Matt |
Dispelling the Myth: Hillary Clinton and the Purple Heart | Otis Willie | Naval Aviation | 0 | February 21st 06 05:41 AM |
Impossible to ditch in a field (almost) | mindenpilot | Piloting | 29 | December 11th 04 11:45 PM |
bush: impossible to be AWOL (do vets give a sh!t) | B2431 | Military Aviation | 7 | September 8th 04 04:20 PM |
cheap, durable, homebuilt aircrafts- myth or truth? | -=:|SAJAN|:=- | Home Built | 27 | January 8th 04 09:05 AM |
The myth that won't die. | Roger Long | Piloting | 7 | December 19th 03 06:15 PM |
