#151
I don't know how anyone can make it more clear than that. If you don't
believe this, you have never done barrel rolls and should do so, with appropriate plane and instructor, before saying any more. Dudley Henriques wrote: Not sure exactly where you are with this, but as what you are saying pertains to barrel rolls begun from level flight or from a position with the nose below the horizon, don't forget that the entire gist of the misunderstanding that has been running rampant on this thread about barrel rolls and doing them at 1 positive g can be centered and completely focused on the fact that it's the ENTRY and the EXIT of the roll, and how these two factors interplay into the roll itself that is causing all the confusion. The one factor that can't be taken out of the barrel roll scenario is that no matter how you cut it, if PITCH is a factor in a barrel roll, there will be an indication on a g meter above 1 g as that pitch change is being made. In a normal barrel roll you have pitch change as the nose transverses the roll in it's helical path. If a barrel roll requires the nose of the aircraft to be above the horizon during the entry and then again brought back to the horizon during the recovery (as it does) you will absolutely be showing more than 1 positive g on the g meter during the roll, and if it's a retaining double needle g meter, after the roll when you bring the airplane home........period! This is a fact of life. As soon as the aircraft's nose shows a positive nose rate in PITCH as it's raised during the roll entry and then again during the recovery as it's raised again to level flight, that g meter will leave 1 and show more than 1 positive g. Now here is the part that is causing all the confusion. ONCE the nose has been raised above the horizon (and that over 1 g has been registered on the g meter) as you feed in aileron you can PLAY WITH THE BACK PRESSURE being applied and EASE OFF the positive g to a LOWER LEVEL if desired over the top of the roll, but that level can't be unloaded below 1 g or the arc of the roll will be destroyed. It's the COMBINATION of roll and pitch that is producing the roll arc and those TWO pressures MUST be maintained to produce the roll. So the bottom line is simply that to do a barrel roll where the nose must be both above and below the horizon line starting from level flight you need over 1 g during the entry and exit, but you can reduce the g to 1 through the top of the roll if desired. Dudley Henriques |
#152
You're right about a barrel roll, of course, I like that you can
rotate the wings through 360 degrees and maintain 1 G. You could also, I think, start the 'roll' with an upward velocity component of 320 feet a second and end it level, but hardly at the same altitude (you'd be 1600 feet higher). An even more interesting question would be, is there an airplane that can fly this flight path? I think it would take massive control surfaces to be able to pull a G with the yoke. On Jun 14, 9:55 pm, Matt Whiting wrote: wrote: Jim, you don't have to do the physics for a 1 g roll. click on stanford.edu/~sigman/one_g_roll.html for a really neat analysis. Page down toward the end of sigman's article to see the actual flight paths that it takes. It's a neat read. Oh, for the nonbelievers in Newton and vector analysis and such (Mx whatever comes to mind) don't bother. A very nice analysis and it confirms that you can't execute a barrel roll from straight and level flight while maintaining 1G. You either lose a lot of altitude and end up in a steep dive or you have to pull up (and thus exceed 1 G) if you want to end up at the starting altitude. Case closed. :-) Matt |
#153
oups.com... Jim, you don't have to do the physics for a 1 g roll. click on stanford.edu/~sigman/one_g_roll.html for a really neat analysis. Page down toward the end of sigman's article to see the actual flight paths that it takes. It's a neat read. Oh, for the nonbelievers in Newton and vector analysis and such (Mx whatever comes to mind) don't bother. Hmmmm....some of the trajectories for varying "initial roll angles" look kinda like my drawing somewhere above in this thread. Especially the ones to the left side of the graph with higher initial angles. Only I was trying to imagine a scenario where you end up straight and level rather than finishing in a high-speed dive as Siegman's model shows. I was thinking more along the lines of pulling up the nose throughout the maneuver to induce the 1g, resulting in a corkscrew dive which you would gradually flatten until the end of the roll. By pulling up the nose to create the g-force you would not have to accelerate downward to "outrun" the acceleration of gravity. Of course Siegman's model more closely approximates a barrel roll where I think I ended up with a gradually opening spiraling dive. Mine was just a thought experiment....no math involved. :-) |
#154
I think by chosing an initial climb rate of 320 fps (!!) you can do
this 1 G roll and end up level but 1600 feet higher, or at a lower rate , maybe 160 fps, and end up at the same altitiude as you started, but going down 160 fps. (superposiiton works!) I sure can not think of a 1 g track that would get you straight and level from a dive, unless the dive took you through the center of the earth. Hey, there's the answer. You have to go really fast so that your fall rate is compensated by the earth being a sphere. That would be pretty fast! This part of the thread belongs over in the physics newsgroup. On Jun 14, 10:34 pm, "muff528" wrote: wrote in message oups.com... Jim, you don't have to do the physics for a 1 g roll. click on stanford.edu/~sigman/one_g_roll.html for a really neat analysis. Page down toward the end of sigman's article to see the actual flight paths that it takes. It's a neat read. Oh, for the nonbelievers in Newton and vector analysis and such (Mx whatever comes to mind) don't bother. Hmmmm....some of the trajectories for varying "initial roll angles" look kinda like my drawing somewhere above in this thread. Especially the ones to the left side of the graph with higher initial angles. Only I was trying to imagine a scenario where you end up straight and level rather than finishing in a high-speed dive as Siegman's model shows. I was thinking more along the lines of pulling up the nose throughout the maneuver to induce the 1g, resulting in a corkscrew dive which you would gradually flatten until the end of the roll. By pulling up the nose to create the g-force you would not have to accelerate downward to "outrun" the acceleration of gravity. Of course Siegman's model more closely approximates a barrel roll where I think I ended up with a gradually opening spiraling dive. Mine was just a thought experiment....no math involved. :-) |
#155
#156
Matt Whiting wrote:
Dudley Henriques wrote: There is a special case where you can unload the airplane in roll to increase the roll rate. It's done in fighters all the time in ACM. You can experience it in your everyday light aerobatic airplane by doing an aileron roll from a nose high roll set position, then as the airplane goes past the first knife edge position, go forward on the pole to unload the wings but not enough to go negative. Keeping the aileron in hard while you do this increases the roll rate and as a side effect flattens the roll in pitch at the same time making it prettier :-) Why does this work? Matt Several factors effect roll rate, roll acceleration and roll inertia. Basically why this works is that unloading the airplane while rolling (aileron roll basically, not a slow roll) minimizes much of the effectiveness issues experienced by the ailerons especially at low airspeeds and high load factors when the wings are generating a fair amount of lift. Anytime you want to maximize the roll rate, unloading will achieve this. The exact point where the rate is maximized by unloading will vary from aircraft to aircraft but basically the rule still applies. Dudley Henriques |
#157
Matt Whiting wrote:
wrote: You're right about a barrel roll, of course, I like that you can rotate the wings through 360 degrees and maintain 1 G. You could also, I think, start the 'roll' with an upward velocity component of 320 feet a second and end it level, but hardly at the same altitude (you'd be 1600 feet higher). An even more interesting question would be, is there an airplane that can fly this flight path? I think it would take massive control surfaces to be able to pull a G with the yoke. I'm not an aerobatic pilot, but pulling 1G with the elevator isn't hard on any airplane I've flown. Matt Actually Matt, all you need to do with most g meters is to "tweak" the stick with an instant of positive pitch pressure and release it. You will register over 1 g just doing that :-)) Dudley Henriques |
#158
#159
george writes:
Graveyard spiral dive Which probably isn't a coincidence, since pilots likely get into these precisely because they maintain "normal" G forces. |
#160
1. If I enter a coordinated turn, I experience an increase in Gs.
2. If I enter a descent, I experience a decrease in Gs. If I do these two things at the same time, it is possible to enter a descending turn without any change in Gs. Yes. Note, however, that you must _accelerate_ downward, and not merely drift downward at a constant rate. Right. A major part of your argument in this thread has been that it is impossible to change the direction in which the plane is travelling without accelerating the plane. Your own analysis, based on my questions, clearly shows that it is possible to change the direction the plane is going in without deviating from the 1G being exerted. Note that the I am not denying that the aircraft is accelerating in this situation. But it is doing so without a change in force being felt. So where your argument breaks down is in the assumption that if changing the direction requires acceleration, then acceleration will require a change in G force. I am not saying that this is, in of itself, proof of the possibility of the 1G barrel roll. It does, however, clearly indicate a flaw in your argument. I find it odd that you find it so hard to believe that people can believe that changes in direction are possible without accelerations being felt, given that by your own admission, these people are actually correct. Of course, all combinations are indeed possible. But this interesting special case of the situation exists, doesn't it, in which there is no change in the force felt by the pilot? Yes. It sounds a lot like a spin. What? It sounds very little like a spin - try entering a spin with no change in G force! |
Dispelling the Myth: Hillary Clinton and the Purple Heart | Otis Willie | Naval Aviation | 0 | February 21st 06 05:41 AM |
Impossible to ditch in a field (almost) | mindenpilot | Piloting | 29 | December 11th 04 11:45 PM |
bush: impossible to be AWOL (do vets give a sh!t) | B2431 | Military Aviation | 7 | September 8th 04 04:20 PM |
cheap, durable, homebuilt aircrafts- myth or truth? | -=:|SAJAN|:=- | Home Built | 27 | January 8th 04 09:05 AM |
The myth that won't die. | Roger Long | Piloting | 7 | December 19th 03 06:15 PM |
