Myth: 1 G barrel rolls are impossible.
Old June 15th 07, 03:40 PM posted to rec.aviation.piloting,rec.aviation.student
Default Myth: 1 G barrel rolls are impossible.
And he could report the very same sensations actual pilots feel.
As a matter of fact, I flew that barrel roll once in the past 24
hours, at 1 g actual.
On Jun 15, 10:06 am, "El Maximo" wrote:
ps.com...
Here's a very realizable one g roll for any airplane -- it just
depends on one's frame of reference. I'll choose the sun, and get a
slow 1 G barrel roll with an 8000 mile diameter in 24 hours. Depending
on the direction the airplane is tied down, it could be backwards.
MX could even 'fly' that one g
  #173
Old June 15th 07, 05:34 PM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Mxsmanic wrote in
george writes:
Graveyard spiral dive
Which probably isn't a coincidence, since pilots likely get into these
precisely because they maintain "normal" G forces.
Nope, wrong again, fjukktard.
Bertie
  #176
Old June 15th 07, 08:27 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
El Maximo writes:
It's called orbital velocity
http://electronics.howstuffworks.com/satellite3.htm
Any object following a ballistic trajectory (disregarding aerodynamic effects)
is in orbit.
  #177
Old June 15th 07, 08:30 PM posted to rec.aviation.piloting,rec.aviation.student
El Maximo
"Mxsmanic" wrote in message
effects)
is in orbit.
And your point is?
  #178
Old June 15th 07, 09:26 PM posted to rec.aviation.piloting,rec.aviation.student
george
On Jun 15, 4:42 pm, Mxsmanic wrote:
george writes:
Berties right!
You are every thing he says..
FYI a noninstument rated pilot entering IFR conditions has about 90
seconds of life remaining.
The resulting high speed spiral dive is a result losing all visual
references and becoming disorientated in cloud...
  #180
Old June 15th 07, 09:28 PM posted to rec.aviation.piloting
Mxsmanic wrote in
El Maximo writes:
effects) is in orbit.
nope.
Wrong again
Not even curious as to how I know you're wrong?
Bertei
Dispelling the Myth: Hillary Clinton and the Purple Heart Otis Willie Naval Aviation 0 February 21st 06 05:41 AM
Impossible to ditch in a field (almost) mindenpilot Piloting 29 December 11th 04 11:45 PM
bush: impossible to be AWOL (do vets give a sh!t) B2431 Military Aviation 7 September 8th 04 04:20 PM
cheap, durable, homebuilt aircrafts- myth or truth? -=:|SAJAN|:=- Home Built 27 January 8th 04 09:05 AM
The myth that won't die. Roger Long Piloting 7 December 19th 03 06:15 PM
