the worst part of the year ...
Old June 15th 07, 03:44 AM posted to rec.aviation.owning
Blanche
Default the worst part of the year ...
Bob Noel wrote:
Kevin Clarke wrote:
How long does your annual take?
A few days. The quickest was 24 hours. The longest annual
is not something I want to think about...
This is for a cherokee 140.
Ah, remember. There's an annual inspection. *Then* there's all
the work you want done, and all the work needed to fix the
things that the inspection found.
An inspection shouldn't take more than a few days, depending on
how busy the IA is. All the other work, well, that's another
story entirely.....
Old June 15th 07, 11:12 AM posted to rec.aviation.owning
Bob Noel
In article , Blanche
story entirely.....
In my example above, the 24 hour annual included inspection, normal service,
and the replacement of a cracked muffler shroud (including shipping). Brought
it in at 5pm on Friday. Taxi'd it back to my hangar by 5pm Saturday.
My worst case was 9 months for a (*@&#$ IA to just do the inspection. That was
my only annual inspection that was not owner-assisted.
Bob Noel
(goodness, please trim replies!!!)
Old June 17th 07, 05:41 PM posted to rec.aviation.owning
Roger (K8RI)
On Thu, 14 Jun 2007 21:56:47 GMT, Kevin Clarke
Fellow R.A.O folks,
I hate this time of year, annual time. The reason I hate it is because I
am 2 wks in now and counting. How long does your annual take? It was 5
wks last year...
1 to 2 days on a high performance, complex, retract, and they are
thourough.
One year they had to replace the starboard exhaust system, both
silencers, AND the nose gear strut. That took about a week.
thanks,
KC
Old June 17th 07, 05:44 PM posted to rec.aviation.owning
Roger (K8RI)
On Thu, 14 Jun 2007 19:20:47 -0400, "Peter R."
wks last year...
Do you do that thirteen month thing (bring it in on the last week of the 12th
month and have it signed off on the first week of the new month) or are you
fixed to June annuals?
Aren't they supposed to list the "start date" for the annual, not when
they finish. Seems like there was a big ruckus over this a while back.
I ask because if you are fixed at June, you ought to consider switching the
annual month to January or February.
Old June 17th 07, 09:42 PM posted to rec.aviation.owning
Peter R.
That wouldn't make sense, especially for those one or two month annuals.
Peter
Old June 18th 07, 04:34 PM posted to rec.aviation.owning
Paul kgyy
Mine usually takes a week for the inspection report, then anywhere
from another week to (this year) 2 months for the repairs. I brought
it in Jan 12 and picked it up April 1. The bill was proportionate to
the time it took, too.
Old June 18th 07, 09:01 PM posted to rec.aviation.owning
Roger (K8RI)
On Sun, 17 Jun 2007 16:42:42 -0400, "Peter R."
Those two month and longer annuals were the reasoning they used. They
wanted the date from the oldest work, not the most recent. IOW, if a
lot of engine work were done on day one and two months later it was
signed off they wanted to date to go back to the engine work, or first
work done in the annual. Rephrashed, they didn't want an annual where
the oldest work would be more than a year old at the next annual.
Old June 18th 07, 09:18 PM posted to rec.aviation.owning
JGalban via AviationKB.com
Kevin Clarke wrote:
Fellow R.A.O folks,
wks last year...
Mine just went in for annual today. They're also installing a new ELT at
the same time. I expect the whole process (inspection, repairs) will be
finished by friday. I take my plane to a well-equipped, well-staffed shop
and it usually ends up costing quite a bit, but I do get my plane back fairly
quickly. A couple of years ago I had a trip coming up, and they were able to
get my plane back to me in a day and a half (one IA and 3 A&Ps working on it
at the same time).. I suppose it helps that the same shop has been doing all
of my maintenance for the past 17 yrs. :-)
Generally, anything that looks like it might fail within the next year gets
fixed. This usually results in a big labor bill because of all the time
consuming little jobs that have to be done. The bright side is that I rarely
have to take my plane into the shop for repairs until the next annual.
Right now I know two owners who have passed the 7 week mark on their annuals
and associated repairs. They're paying substantially less by using a one-
man outfit, but they're also competing with numerous other owners for that
guy's time. It's worth the extra money for me not to have my plane down for
two months.
Message posted via http://www.aviationkb.com
Old June 19th 07, 05:16 PM posted to rec.aviation.owning
Roger (K8RI)
On Mon, 18 Jun 2007 16:01:21 -0400, "Roger (K8RI)"
I did some up-to-date "checking" and it turns out to be one of those
"IT all depends" on who you draw from the FAA and if you are a
mechanic. Several mechanics in the area were told (a while back) in
no uncertain terms they were to use the start date, BUT if it turns
out to be one of those long annuals AND it's their butt on the line
where they put their signature AND the annual is after all, *just* an
inspection all they'd have to do is look over the earlier stuff and
sign off which makes the conclusion of those inspectors a bit strange.
Officially where the pilot/owner is concerned the only thing the FAA
*normally* has to go by is the date of the mechanics sign off.
As to the length of the annual, there is no real excuse for the
inspection to take more than a day or two. There was a Cherokee 6 on
the field that had some major structural work (position light on top
of the tail hit the over head when being pushed back into a hangar,
folding the empennage) and that only took a couple of weeks part time.
A similar project on a Cherokee 180 only took a couple of days
including paint.
The only real reasons that I can think of for long annuals are long
delivery items that had to be ordered and poor scheduling/organization
at the FBO's.
Old June 19th 07, 05:21 PM posted to rec.aviation.owning
Roger (K8RI)
On Sun, 17 Jun 2007 12:41:09 -0400, "Roger (K8RI)"
Fellow R.A.O folks,
wks last year...
thourough.
Forgot:
AND one of the bladder tanks had to be sent in for a rebuild.
That was my most expensive annual.
Over all I think they've averaged a bit over $1000 including required
repairs with a low of about $480 to a high a bit over $8,000. (nose
gear struts for a Bo are expensive)
thanks,
KC
Our Worst Nightmare? alank Piloting 56 January 10th 07 10:10 AM
Worst weather, ever... Jay Honeck Piloting 121 January 17th 05 08:21 PM
Worst Jokes At Oshkosh Ron Natalie Home Built 3 August 23rd 04 06:30 PM
Be ready for the worst! Ed Byars Soaring 20 April 6th 04 03:03 AM
How about worst looking airliner? Andrew Burke General Aviation 19 January 2nd 04 11:13 PM
