On Wed, 17 Sep 2003 20:08:08 -0700, "Tim Ward"
wrote: "Rich S." wrote in message ... Check out item 47065-2VGA at http://www.harborfreight.com/. 4-1/2 HP 21 GALLON CAST IRON VERTICAL COMPRESSOR Two Built-in Universal Quick Connect Couplers for Convenient Air Hose Connection Long-life oil lubricated compressor with precision machined cast iron sleeve Twin capacitor motor with thermal overload protection Wheel kit with 6'' wheels and ergonomic for smooth portability Oil level indicator window for easy maintenance Reduced vibration with rubber foot stabilizers 4-1/2 peak horsepower; 120 volt, 60Hz 125 PSI max; 4.4 CFM @ 90 PSI; 11.1 CFM @ 40 PSI Shipping weight: 152 lbs. $169.99 Rich S. I dunno beans about air compressors, so maybe someone else can explain it to me: The usual wall circuit is 15 Amperes, times 120 volts peak is 1800 watts. 746 watts in a horsepower, so how do you get 4.5 HP out of a wall socket? Tim Ward You DON'T..... John Ammeter |
On Thu, 18 Sep 2003 03:10:59 GMT, John Ammeter
wrote: On Wed, 17 Sep 2003 20:08:08 -0700, "Tim Ward" wrote: "Rich S." wrote in message ... Check out item 47065-2VGA at http://www.harborfreight.com/. 4-1/2 HP 21 GALLON CAST IRON VERTICAL COMPRESSOR Two Built-in Universal Quick Connect Couplers for Convenient Air Hose Connection Long-life oil lubricated compressor with precision machined cast iron sleeve Twin capacitor motor with thermal overload protection Wheel kit with 6'' wheels and ergonomic for smooth portability Oil level indicator window for easy maintenance Reduced vibration with rubber foot stabilizers 4-1/2 peak horsepower; 120 volt, 60Hz 125 PSI max; 4.4 CFM @ 90 PSI; 11.1 CFM @ 40 PSI Shipping weight: 152 lbs. $169.99 Rich S. I dunno beans about air compressors, so maybe someone else can explain it to me: The usual wall circuit is 15 Amperes, times 120 volts peak is 1800 watts. Most of the circuits in our house are 20 amp with ground fault. There is one 30 amp and my den has two 30 amp 220 volt outlets( for the ham station) 746 watts in a horsepower, so how do you get 4.5 HP out of a wall socket? Tim Ward You DON'T..... Ohhh come on John, you can too...It's just I use a 220 volt 50, or 60 amp socket like the one for the kitchen range:-)) Well that and it's mounted on the surface and fed through conduit. It's gotta be close to a 90 foot run from the breaker box. No, I didn't use #14 either:-)) Did I mention it's out in the shop too? Roger Halstead (K8RI EN73 & ARRL Life Member) www.rogerhalstead.com N833R World's oldest Debonair? (S# CD-2) John Ammeter |
746 watts in a horsepower, so how do you get 4.5 HP out of a wall socket? If it were DC, you'd be correct. AC has more or less sinusoidal voltage and current, not necessarily peaking at the same time, and a whole bunch of other stuff I used to know about. Ed Wischmeyer |
![]() "Ed Wischmeyer" wrote in message ... The usual wall circuit is 15 Amperes, times 120 volts peak is 1800 watts. 746 watts in a horsepower, so how do you get 4.5 HP out of a wall socket? If it were DC, you'd be correct. AC has more or less sinusoidal voltage and current, not necessarily peaking at the same time, and a whole bunch of other stuff I used to know about. Ed Wischmeyer Yep, but that makes it worse, not better. I'd expect RMS power to be about 70 % of that 1800 watts. That's about 1300 watts, or less than 2 HP. Tim Ward |
"Tim Ward" wrote in message
... Yep, but that makes it worse, not better. I'd expect RMS power to be about 70 % of that 1800 watts. That's about 1300 watts, or less than 2 HP. Well, if 4.5 hp out of a wall socket isn't enough, how about this one??? Rich "To infinity and beyond!" S. 6 HP, 20 GALLON COMPRESSOR Oil-free design for lower maintenance. Easy-grip cushioned handle. Quick-connect, regulator, dual gauges and tool tray. Horse Power: 6 Power supply: 120V Air pressu 135 PSI maximum Air Delivery: @ 40 PSI: 8.3 CFM @ 90 PSI: 5.8 CFM Tank size: 20 gallon Shipping weight: 100 lbs. Porter Cable# CPF6020 ITEM 45158-1VGA $299.99 |
On Wed, 17 Sep 2003 20:55:03 -0700, Ed Wischmeyer
wrote: The usual wall circuit is 15 Amperes, times 120 volts peak is 1800 watts. 746 watts in a horsepower, so how do you get 4.5 HP out of a wall socket? It's probably more like 15 or 20 amps and that is 115 to 120 volts RMS, not peak. Peak is 1.414, or roughly 162 volts. On single phase they current and voltage should be close enough for all practical purposes to call them in phase. (except during starting) If it were DC, you'd be correct. AC has more or less sinusoidal voltage So, using RMS at 115 volts he's still close. and current, not necessarily peaking at the same time, and a whole bunch of other stuff I used to know about. Roger Halstead (K8RI EN73 & ARRL Life Member) www.rogerhalstead.com N833R World's oldest Debonair? (S# CD-2) Ed Wischmeyer |
![]() "Tim Ward" wrote in message ... I dunno beans about air compressors, so maybe someone else can explain it to me: The usual wall circuit is 15 Amperes, times 120 volts peak is 1800 watts. 746 watts in a horsepower, so how do you get 4.5 HP out of a wall socket? The 120VAC is not the peak voltage, it's the RMS voltage. The peak voltage of a 120VAC system is around 170V. If you take peak volts X peak amps, you get peak VA, then multiply it X the power factor to get the peak watts, divide by 746 / %effeciency to get peak HP. errrr.... I think. |
"Frederick Wilson" wrote in message news:2uX9b.372665$Oz4.149020@rwcrnsc54...
Fred Speculating I wonder what the average time difference is between deciding to build an airplane and actually starting the project. Define "starting the project" :-) Corrie (owner of several sets of plans, a bunch of tools, and a small amount of wood) http://www.itasca.net/~corrie/homebuilt_plane_blog.htm |
