On 2007-06-21 22:58:36 -0400, vincent norris said:
An aileron roll is actualy not dissimilar to a Barrel roll in flight path. You obviously didn't learn to do barrel rolls in the U.S.Navy. vince norris A lot of people mistakenly classify an aileron roll as a narrow offset barrel roll thinking the natural arc the nose describes as it raises before roll initiation and then lowers due to drag during the back side of the roll resembles a barrel roll. Seen from the ground, especially to a novice, an aileron roll, especially an aileron roll performed in a low performance airplane with a slow roll rate can indeed APPEAR to be a narrow offset barrel roll. For the aileron roll, the nose is raised and set, then aileron applied with just a touch of inside rudder to nullify the adverse yaw then released. As the aircraft rolls with aileron, drag begins to pull the nose down. The result of this, especially if no forward stick is introduced to "trim out" the roll through inverted, is for the nose to dish out the bottom of the roll which viewed from the ground can easily be mistaken for a deliberate maneuver resembling a barrel roll. Although it's true the nose does raise and lower during a normal aileron roll,an aileron roll is still basically performed on the longitudinal axis of the airplane using aileron or spoiler (can even be aided by differential tails in some fighters) as the prime roll control and doesn't meet the 3 dimensional rule through space that defines the helical arc of a barrel roll. Even this should not be mistaken for the 90 degree offset at inverted barrel roll as taught by the Navy. The Navy version, and indeed anyoneperforming a helical 90 degree heading offset through inverted is doing the classical version of a barrel roll; the version most often taught as a precision training maneuver. So you are as I'm sure you already know, perfectly correct. This explanation I hope might help others to understand this a bit better. Dudley Henriques |
Dispelling the Myth: Hillary Clinton and the Purple Heart | Otis Willie | Naval Aviation | 0 | February 21st 06 05:41 AM |
Impossible to ditch in a field (almost) | mindenpilot | Piloting | 29 | December 11th 04 11:45 PM |
bush: impossible to be AWOL (do vets give a sh!t) | B2431 | Military Aviation | 7 | September 8th 04 04:20 PM |
cheap, durable, homebuilt aircrafts- myth or truth? | -=:|SAJAN|:=- | Home Built | 27 | January 8th 04 09:05 AM |
The myth that won't die. | Roger Long | Piloting | 7 | December 19th 03 06:15 PM |
