Gasohol
Old June 23rd 07, 02:40 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Default Gasohol
On Jun 3, 8:02 am, "Peter Dohm" wrote:
"David Lesher" wrote in message
B A R R Y writes:
Ken Finney wrote:
I already am, but there an STC for diesels in 172s.
Running on Jet-A, not Biodiesel.
Which is just kerosene...
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
There are really three of issues (that I can recall) he
1) A diesel will run on any hydrocarbon fuel that it can pump and meter.
2) Different seals and hoses are compatible with different
chemicals--although it would be no surprise to find that all were compatible
with biodiesel.
3) Certified aircraft/engines require fuels authorized in the type
certificate and/or an STC.
My understanding is that biodiesel is compatible with all common
elastomeric components used in diesel systems. It has somewhat
higher lubricity and detergent properties compared with petroleum
diesel.
So the first tankful might clean enough crud out of the fuel system
to
foul the fuel filter. After changing that filter, the engine should
run
cleaner.
One reported problem with biodiesel is that it gels at low
temperatures.
FF
How scary is gasohol? Charles Talleyrand Owning 27 March 1st 04 11:39 AM
